Question about Marantz SR5001
HDMI does not work anymore
I plugged in and out the cables a couple of times while the device was on. Now the device does not recognize the HDMI signal anymore.
Cannot get the hdmi to work
My Tv won't recognize my computer when connected via HDMI [Solved ...
www.tomsguide.com/.../57797-4-recognize-computer-connected-hdmi
4 days ago - 43 posts - ‎36 authors
I too was able to get the HDMI output to work and then later on stop working. ... I'm also experiencing this issue, but still can't make the TV ... Audio over TV problem using HDMI cable
Jun 30, 2015
When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
My TV doesn't accept PC HDMI [Solved]
Dec 7, 2012
More results from www.tomsguide.com
TV won't recognize laptop when connected via HDMI ...
Dec 26, 2015 | Televison & Video
I used to connect my tv with my laptop using an HDMI cable, and all of a sudden, it just does not work anymore. What can I do?
Hi Cyril Lott,
There is a possibility that the HDMI cable might have failed so try connecting another known good HDMI cable and check if that helps.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Apr 12, 2015 | Dell Computers & Internet
TV won't recognize PC through HDMI port anymore
Thanks for all the background, super detailed! I had a similar problem on a new Samsung that was really flaky with my HDMI from a raspberry pi. Would have to do all kinds of unplugging, cycling power etc like you're doing to get it to work. Once on it would work until I turned the tv off (actually doesn't turn off, but goes to sleep) and back on. Finally figured out that the resolution I was outputting wasn't supported, BUT sometimes it would work. Once I changed the resolution to a supported resolution it worked all the time.
Mar 26, 2014 | Televison & Video
Computer not recognizing HDMI, but recognizes VGA
i would try go to - graphic properties(options) and try to browse for display options, if nothing's there than browse for update for your graphic card drivers on laptop producer website or hdmi drivers
Feb 11, 2014 | HP Computers & Internet
No video from HDMI inputs, it does recognize the any-net but no picture at all
Sometimes the HDMI needs a particular order to recognize a device. You may need to have the DVD turned on before the tv or visa versa for it to work.
Nov 30, 2013 | Samsung UN55C7000 55 in. TV
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
Vchip rest. Inputs won't show HDMI
Make sure you have a good hdmi cable, and make sure you have a signal. Try another HDMI slot, and see if that helps. If nothing works, unplug the HDMI inputs and turn the set off overnight. Then plug each HDMI plug in one at at time, and turn the device on. This helped in a couple of instances I know of.
Since I don't know the model you have, the following blog may or may not be helpful to you:
http://forums.logitech.com/t5/Harmony-Remotes/JVC-TV-input-problem/td-p/241569
Good luck, and hope this helps.
Apr 07, 2011 | JVC Televison & Video
Sanyo DP46840 purchased less than 1 week ago from Walmart. Worked fine for first couple of days, now HDMI connections don't work. monster cable works on other lcd tv and all video sources. rest TV...
Hi gregschirk,
I bought the same model and I am experiencing a similar problem. My HDMI components worked fine before. Now both my cable box and DVD player will not be recognized as HDMI systems. It thinks they are DVI to HDMI connections. Good picture but no sound. Would like to know if there is a fix for this.
Thanks Gilbo72
Nov 27, 2010 | Sanyo Televison & Video
When i go to hook up a hdmi cable to my philips flat screen it wont recognize that i have a hdmi plugged into it. so what could that be the tv? the hdmi works with my other tv though
This model has 4 HDMI inputs, do you get same problem in each HDMI input?
Did you checked HDMI input with any other video source like dvd player or PS3 etc instead of cable box?
Below are few helpful tips to connect HDMI input..
1. Ensure that your HDMI cable is certified.
2. Press SOURCE on the remote control to switch to another source and then switch back to the HDMI source.
3. Reset the accessory device and the TV.
• Turn on the TV
• Select the HDMI channel
• Turn on the accessory device
4. While the TV and the accessory device are powered on, unplug either end of the HDMI cable and then reinsert the cable.
Try above options and if tv still does not show picture of any video source through HDMI then it seems problem of HDMI processor located on main board, visual check is needed by qualified tech or call Philips if tv is under warranty.
Hope these info will help you.
Thanks.
Nov 26, 2010 | Philips 42PFL7403D/27 42 in. LCD TV
Marantz SR5001 Logo
49 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
