Question about Brother XL-3510 Mechanical Sewing Machine
Needle postion is it possible to change the needle position on this model?
  • 4 Answers
If you mean left or right with a straight stitch, then yes. You use the stitch width selector - you will notice a small raised section in 3 locations, they mark, far left, center and far right.
Posted on Mar 26, 2009
I don't know how to change needle postion when changing the foot to another one my machine is a brother xl 3022
Here's a manual for your machine:
Brother XL 3010 Operation Manual
It appears that your machine does not have the ability for the user to change the needle position. Instead, it seems that the selection of the specific stitch pattern determines where the needle is positioned, ie #1 appears to set the needle in the left position but other stitch and width selection will move the needle position.
Oct 16, 2017 | Brother Sewing Machines
Needle locked in right position
Remove the needle holder using a tool suitable for it and remove the needle and fix it again in the correct position and continue the stitching in zig zag .
Thank You
Sep 13, 2008 | Husqvarna Viking 1
How to change the needle position?
Google your machine make and model with Users Manual.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Oct 23, 2014 | Sewing Machines
Feeds dogs are lowered even when in the up position
Check to see if there is a bunch of thread under the needle plate preventing the feed dogs from returning to run position.
This may mean having to take the needle plate off and really looking
Jul 29, 2012 | Brother CS-6000
Fabric will not feed through feed dog
check the feed dogs in the needle plate area, you should be able
to feel them with your index finger, if you can't feel them, check for
a lever or knob that sets the up & down postion of the feed dogs.
the name of the machine & model number are not mentioned in the
question. do you have a manual?
Jun 03, 2012 | Sewing Machines
Brother sewing machine model 732 (pretty old machine) compal star My machine was sewing forward up to today. I broke a needle changed that since when it wants to go backwards...any ideas what to do I have...
have you checked the reverse lever to see what position it's in?
if the needle broke at the tip end check in the bobbin area for needle fragments
it is possible that a broken needle can jam up or even get the machine out of time.
it may need to be serviced
Aug 03, 2011 | Brother Sewing Machines
How do you position the needle/ with which lever or dial? location?
Your model doesn't have a specific needle position adjustment. But you could try this - set it to the shell stitch or lingerie stitch on the stitch selector but leave the stitch width setting on zero, this may move the needle to the left most position with any luck.
Other possibility is to put it in a step of the buttonhole sequence, but again leave stitch width on zero and see if this moves the needle bar to the right or left for you.
Feb 07, 2011 | Elna 2007 Mechanical Sewing Machine
Thread skips
Well, Hello Kim. Once the Needle for the machine is changed, there is a good possibility of the timing of the stitches being altered and hence the problem.
  •  Firstly, make sure that the needle is in correctly with the scarf of the needle towards the hook. Take the needle plate off and the presser foot off.
  • Turn the handwheel towards you until the needle is in the lowest position, and on the needle bar you will see two lines somewhere near where the needle bar enters the machine.
  • When the needle is in the lowest position, the top line of the two lines should be flush with the body of the machine.
Jan 05, 2009 | Consew 206RB
Singer 758 adjustments for needle position and stich width
Found this below that may help confirm timing? As for the zig zag one thought is to check for end play in the upper shaft. At the left hand end of the shaft (under the top cover) there is an white plastic "bushing" with one slotted screw - this can be adjusted to take up the slack. It is possible that this bushing is split by the screw which may make it come out of adjustment. Check the other collars on this shaft are tight (hex) - by the belt and near the drive gear. P.S. double check the zig-zag cam is in the correct position (set to straight sew - centre position to install the cam - check instructions).
Timing
Turn the handwheel towards you until the needle is in the lowest position and observe two lines on the needle bar at the place where it comes out of the machine. You have to see these lines. When you find those, you have to tilt the machine on its back and you will see that on the right hand side there is a belt coming down onto a gear like piece on the timing shaft. Move your eyes to the left and the next thing that you will see is a large round gear on the feed shaft. Now that we have determined the difference between the feed shaft and the timing shaft, follow the feed shaft to the left and there will be a small metal piece there with two metal screws on it. Next to that to the left is a stationary metal peice that has a bump on it. You must see these two things to adjust your machine.
Now, to determine if your machine is out of time, turn the handwheel towards you (always turn it towards you) until the needle is in the lowest postion again. Observe the two lines on the needle bar, turn the handwheel toward you until the bottom line goes in the exact place where the top line was. Now look at the needle and hook. The hook should be directly behind the needle. If it is not, we go back to the bottom of the machine on the gear like metal piece that the belt rides on and loosen the two screws that are in the piece. Now if you will remember, this is on the timing shaft. When these two screws are loose, the hook will become moveable. Place the tip of the hook directly behind the needle without moving the needle bar (remember that the needle bars bottom line was placed where the top line was). When you have accomplished this, tighten the screws on the belt gear.
Now you have to determine whether the feed is in time. Again, place the needle in the lowest postion, rise the low line to where the top line was, and see if the line on the feed shaft is directly next to the bump on the stationary metal piece. If not, without moving the handwheel at all (because it must stay in this position to time it), loosen the two screws on the feed shaft piece and align the two lines together. Then tighten the two screws, make a few rotations with the handwheel, and again, put the needle in its lowest position and rise the bottom line to where the top line was. Inspect the two lines on the feed shaft and the hook behind the needle.
If these did not stay in adjustment, re-do the entire process, but be more careful not to move the handwheel when making the tightening adjustment. If you re-do this and it still does not stay in adjustment, you need to replace your timing belt,
Jan 01, 2009 | Sewing Machines
Needle position
perhaps the needle is not in straight or is bent.
Oct 22, 2008 | Brother CS-8072 Computerized Sewing...
Brother XL-3510 Mechanical Sewing Machine Logo
119 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
