Question about Park ing Sensor System With Four Sensors
Require wiring diagram & colour code for parking sensors 2012 peugeot 508
2012 peugeot 508
I have a peugoet 508 2lt .the desiel gauge is stuck on 1/4 tank of fuel and do not move beyond that mark?
You should check out www.reliable-store.com they have info on repair, service, wiring diagram, electrical diagram, fuse diagram, troubleshooting, PCV, owner's/service/repair/parts manual, fault codes, error codes, etc everything on all vehicles. must check it out
Feb 26, 2018 | Peugeot Cars & Trucks
Golf MKV. 1. What is the wiring colour code for the brake lights? 2. What is the location and colour code for the ACC? Where is it located on the car?
The only thing that I can do is provide a possible source for wiring diagrams. VW guards their technical information and no free diagrams or repair manual are around unless someone downloads one at a VW owners forum (I suggest you join a few)
http://bbbind.com/free_tsb.html
Feb 22, 2017 | Car Audio & Video
My Peugeot 508 1.6 petrol engine 2012 sedan carbon builds up on values. My question is how can I clean the carbon
fix the reason for the carbon in the first place
it is excessive fuel or oil consumption
as to cleaning carbon off the valves , there are very few products that will do that
you can ask specialist engineering shops for products that may work but the real fix is to pull the head and clean the valves and fix the reason the caused the problem
Dec 23, 2016 | Peugeot Cars & Trucks
1997 Ranchero Outback, 4.0i inline 6 engine. Where can I get color coded diagram?
diagram showing spark plug wires to Coil pack? - Ford Truck ...
www.ford-trucks.com > ... > Small Chassis Trucks > Aerostar
Apr 8, 2014 - now I cannot find a diagram for the Driver's Side wire positions at the Coil... (the Passenger side wires are 1-2-3, starting from the front of the engine, simple enough); The Coil pack ... But the Driver's Side wires are not in a Sequence of 4-5-6, instead ... 1997 Ford Aerostar 4.0L RWD (purchased May 2012) Camshaft Position Sensor (CMP) wiring pigtail replacement
May 8, 2012
Help! 1994 4.0L Ranger misfiring & hesitating under load?
Oct 31, 2011
1994 F150 starter wires
Jul 16, 2011
Coolant Loss - 4.0L OHV Lower Intake Gasket
Apr 21, 2004
More results from www.ford-trucks.com
Sep 30, 2015 | Ford Cars & Trucks
Hi,I have a 2.4lit 2008 Toyota Camry and I require a wiring diagram for the maf sensor. My Haynes manual does not show this at all.Thanks
You can not tune a MAF Sensor,leave it as it was designed
The MAF measures air flow & that info is needed along with other
data to adjust fuel trim & other things
The maf has to know your altitude to work correctly
You never get a Haynes or other manuals for any reason
You buy manufacture factory publications & wiring books,that
are your exact vehicle & of some actual value
Mar 15, 2014 | 2008 Toyota Camry
Parking sensor wiring / reversing light wiring
Pretty much universal is the color coding on vehicle lights. Brown, or another color with a brown tracer/stripe, is always the running lights. You wont see an all brown wire on these newer vehicles. Always another color with the proper color tracer. Brown=run & tail-tag lights, green is right turn and brake light, yellow is left turn and brake light, and black is the ground wire to the lights. Inside cab and under dash, You need look closer for these colored tracers.all ground wires are white. This is what I've found.
Nov 12, 2017 | Cars & Trucks
I have a peugeot 306 somebody has cut stereo wiring block off so i am looking for wiring diagram preferly coloured coded thanks
Easist way to solve that problem is ,go get enouther harness for it from a auto wrecker from the same kind of car, Then the wires will all match up, Just reconnect one buy one at a time,
Nov 11, 2012 | Peugeot 306 Cars & Trucks
Fitting trailer wiring to peugeot partner van. need to know van wiring colours, dont match trailers wiring colours
Hello, if you have a test light handy with a sharp tip on one side than, start with your parking lights on and check to see which wire it is, if you have a heavy bag of potatoes or similar, you can use this when it comes to the brake lights :)
Feb 18, 2011 | 2006 Peugeot 604
Need a wiring diagram please
wiring diagram or colour code for kenwood cd player model kdc-5108
Nov 16, 2009 | Kenwood KDC-W3534A CD Player
Park ing Sensor System With Four Sensors Logo
47 people viewed this question
Top Park Home Security Experts
Lawrence Oravetz
Are you a Park Home Security Expert? Answer questions, earn points and help others
