Question about RCA RT2280 System
RCA RT2280 schematic
Sound cuts out all channels at once. Something common to Cable, Analog and Optical
SOURCE: surround cuts out???
Are you useing a digital audio cable when its cutting on & off? How long between the on & off? I have the same problem when I use a digital audio cable or a coaxial audio cable from my DVD player. To use the surround (6 CH) feature you need to use the 6 channel RCA jacks and if what ever your hooking up dosent have the RCA outputs your out of luck. My DVD player does have the 6 channel outputs and they work but the digital cables won't work. What are you connecting to it? I think something is wrong with the digital circuit board in mine, I would like to replace it and see. Reading your manual will help understand the 6 channel RCA and fiber optic digital cables. I hope any of this helped.
Posted on Jul 09, 2007
SOURCE: RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Posted on Dec 28, 2008
dunnbiker
  • 8546 Answers
SOURCE: my rca rt2380bk is not
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RT2380-Home-Theater-Systems-manual/id/402ag602/t/2/
Page 19. Match the input name you're using for the PS's video with the optical audio label.
Posted on Apr 09, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have an old rca
Perhaps the Direct TV box menus would shed some light on why it's sending PCM stereo instead of Dolby Digital 5.1.
Posted on Aug 07, 2011
SOURCE: RCA 2280 Optical Input w/PS3
DVD channel also has optical.
Posted on Dec 11, 2011
YAMAHA DSP-AX1 SOUND CUTTING IN AND OUT OF FRONT CENTRE CHANEL
Check if the sound comes from a digital source like an optical cable or the one that generally the color is orange (not the common red and white, nor the yellow terminals) then check also if this ocurr with certain music. Let me know
Jan 18, 2014 | Yamaha DSP-A1000 5-Channel Amplifier
Hoooking up surround sounds with optical cable surround system is RT2280 AHHH please help my husband is driving me crazy to get it fixed and he cannot figure it out. Superbowl must be in surround sou
Make sure the digital setting (optical/coaxialor analog)is correct.
If youre connection is differet from default setting
1.select the source
2.press function
3.rotate multi jog to toggle among optical/coaxil/analog to match
yuor connection.
your selection will be stored automatically.
every time you press the source button the input setting(dvd/opti)
will be show on display.
heres a link to the manual go tto page 21 advanced settings.
http://www.google.co.uk/url?sa=t&rct=j&q=surround+sound+RT2280+AHHH&source=web&cd=4&cad=rja&ved=0CEMQFjAD&url=http%3A%2F%2Fsupport.radioshack.com%2Fsupport_audio%2Fdoc66%2F66651.pdf&ei=G2QMUbKqMOOY0QWJlYBw&usg=AFQjCNG2gc-bExNRynH2JEV22sR-L_ggDg&bvm=bv.41867550,d.d2k
Feb 02, 2013 | RCA RT2280 System
No sound from tv, dvd, cable. Speaker test does work. Sound stopped suddenly when channel was changed.
What does this mean: "when channel was changed"? TV channel?? Would that mean a remote command was issued? How about FM (no external cabling)?
Page 23...
http://www.retrevo.com/support/RCA-RT2280-Home-Theater-Systems-manual/id/402ag600/t/2/
Sep 02, 2011 | RCA RT2280 System
Hi, when I plug my TV's optical out into the Nakamichi AV8's optical input, and switch to "DVD/Optical" (after hitting "Digital Input" buttno) ... no sound comes out. I have...
Maybe assign it?
If the digital TV-related audio actually originates elsewhere (Cable Box?) you could skip the TV and use the Cable Box as the audio source. Nothing is gained by flinging an audio or video signal around the room to be handled (but not improved) by any device. I have no video entering my receiver and nothing but bare bones analog audio going to my TV in case I want to just watch the news or something else lo-fi.
Jul 14, 2011 | Nakamichi AV-8 5.1 Channels Receiver
Sound has static using optical connection on some channels. if I use analog connection sound is better but cuts out about every 3 minutes
Optical digital cables are more finicky than coaxial ones. The seating has to be precise and there can be no small radius bends or kinks in them. Evaluate the routing.
I'd use coaxial if I had the choice.
Two major benefits:
1) cheap standard RCA cable that you can run pretty much as far as you want in the home environment;
2) they can multiply your available coaxial digital jacks because they can be 'shared' between two digital sources or end-units by employing an RCA splitter cable.
You just have to remember to turn OFF the device you're not using at any particular moment so you don't have a 3-way digital conversation garbling things up.
Jan 07, 2011 | Harman Kardon AVR 320 Receiver
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sound issues with HDMI connection.
manape7
It depends on the device that you are connecting to the HDMI Cable to. Some devices like LCD monitors are not designed to pull audio from the HDMI channel. In those cases you will need to use the Optical or Analog audio output. Note when you do this you wil need to change the settings in the audio setting option to select those outputs.
Let me know if you have any problems or questions
Issken
http://www.fixya.com/users/issken
May 30, 2010 | Sony Playstation 3 (PS3) Console
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Nov 14, 2009 | RCA RT2280 System
RCA RT2280 System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
