Question about Epson PowerLite 7250 Multimedia Projector
How to adjust double image on epson powerlite 7250
The projector is displaying double images. the red bule and green are not alined.
SOURCE: One of our Epson PowerLite projectors was working
We found that the bulb was dim because it was about to burn out. The projector's filter han't been kept clean, causing it to run hot, which in turn shortened the bulb's life.
Posted on Dec 10, 2009
SOURCE: flashing red light
Hi ProjDoc, i have the same issue.... Can you tell me where I could order a Ballast, and how to replace it on my Epson projector?
Posted on Jan 07, 2010
SOURCE: My Epson Powerlite 5350 has a ghost image. Any
I've got the same problem on two Epson EMP7300.
I believe (from reading about other projectors) that the ghost image can be adjusted with RS232 codes.
Does anyone know how to do this?
Posted on Feb 24, 2010
  • 629 Answers
SOURCE: I have a double image
often, this is related to the connection between your computer and projector. try to use another set of working VGA cable and change the screen resolution to 800 by 600 when using the projector. It may also help to test the projector on another computer to help isolate the issue.
Posted on Sep 16, 2010
BILLatNASA
  • 3 Answers
SOURCE: How do I reset the lamp hours on an epson
EPSON PowerLite 7250
Reset the lamp counter hours in 3 steps
1. Make sure, your projector is ON
2. Hold down the Help and Menu buttons for 5 seconds.
The "A.S." screen will appear.
3. Hold down the Tracking and Tracking - buttons for 5 seconds.
Posted on Sep 20, 2010
Powerlite 420 image upside down. How do I turn it around?
you will need to change the projection mode in order to flip the image:
Turn on the projector and display an image
hold down the A/V Mute button on the remote control for 5 seconds (whilst it is pointing at projector). Image will disappear then reappear flipped.
To change back, repeat this process
Nov 24, 2014 | Epson V11H348020 - PowerLite 4200W...
Epson 460 powerlite hooked to smartboard green light blinking and no image.
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Dec 06, 2012 | Epson PowerLite 410W LCD Projector
My Epson Powerlite 5350 has a ghost image. Any recommendation on how to adjust the projector to remove this symptom?
Jan 24, 2010 | Epson PowerLite 5350 Multimedia Projector
How do I reset the lamp hours on an epson powerlite 7250 projector after replacing the bulb?
Dec 05, 2009 | Epson Office Equipment & Supplies
Lcd projector projects images upside down???
if you go through the projectors setup menu you will find the option to invert / flip and rotate image adjust as required
REgards Al "alastech"
May 29, 2009 | Epson PowerLite 62c Multimedia Projector
Epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Apr 01, 2009 | Epson PowerLite® S4 LCD Projector
Images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
Mar 14, 2009 | Epson PowerLite® S4 LCD Projector
Double Image
It's may be the video cable from the PC. I had the exact same problem with my Epson projector today. Treat y
Oct 06, 2006 | Epson PowerLite 5000 Multimedia Projector
Epson PowerLite 7250 Multimedia Projector Logo
143 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
