Question about QSC MX1500A 2-Channel Amplifier
Peavey CS-800 PA power amp 1 channel is out
Channel ''B'' works fine. Channel ''A'' is out. I have checked virtually every component in channel ''A''. I have test equipment. I have compared resistance and diode meter readings between the good and bad channels I have been an electronics tech for over 30 years. This one has me stumped. The -85V is low at about -55 volts only on the bad channel. I have a schematic, but I can't figure this one out. I have meters, a scope, and also a curve tracer. I have metered all the output transistors - they checked good...someone has replaced 2 of the output transistors previously as they are not the same as the others. Channel ''B'' ' s outputs are all the same like the majority of the parts in channel ''A''. I am hesitant to swap the outputs or the driver boards as I am afraid to damage anything in the good ''B'' channel therefore losing my ability to compare 1 to the other...I have about 10 or 12 hours into this now and I am about to return it to the owner and tell them I can't fix it. any help is greatly appreciated Thanks Bill
    Champion:
  • 211 Answers
Hi Bill,
It's a log time ago that I repaired those amps., but I give it a shot.
There's a speakerprotection after the finals, what I remember it's a triac (SAC187, or something like that).
You will find it at a small pcb at the back of the amp. Normally it has three legs but the centre is cut away. If it's down you will measure 0 Ohm at the output, also with a switched off amp.
Thats all I can remember, it was about 25 years ago.
Maybe it helps,
Gerard
Posted on Jan 30, 2009
Hi. i have a peavey cs-800 serial 5A-02115255. when i power on then the fuse blow. anyone here have any ideal what is the problem/?. i do not have a schematic if any one here have could you email it to me at Nam.Nguyen@bnsf.com. thank in advance.
thanks
Nam Nguyen
Posted on Dec 16, 2009
    Genius:
  • 1,175 Answers
I work on these too.
I would replace all the high-watt emitter resistors(in the bad channel) and if you have a REAL transistor tester , check the whole "bad string" of transistors for gain match
Peavey also uses dual series diodes that they wire thru the heatsinks(at least on the guitar amps). Thats a usual suspect.
If you ask peavey tech support nicely..they'll get you a schema if you dont have one
Posted on Jan 27, 2009
I have connected a laptop to a Phonic MM 1002a mixer, Do you need to use both Channel A & B on Peavey M - 2600 Mark V Stereo Am
This depends on what you are trying to do. If you want a mono output from the amp switch it to mono mode and go into one input on the amp, this will mean the amp only works mono.
If your source is stereo you will need to use two inputs on the mixer and pan them both to the side you will be sending to the amp. This will cost you two mono inputs on the mixer though.
If you have anything stereo this is the route you will need to take but I don't see why you would want to do this as surely you'd be better running everything stereo (two channel) and panning any mono signals where you want them and leaving stereo as stereo.
Jan 02, 2014 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
No Power to A channel
check output transistors also the driver transistors.
Jul 28, 2013 | Peavey CS® 2000 Amplifier
I want to no wat this parts number is Q4025p for a peavey cs 800
2 Channel Peavey CS-800 Amp (800 Watts) ... Peavey CS-800x 800 Watt PA Stereo power Amplifier. The Part in question Q4025P is an alternistor. Two SCRs back to back that may have shorted out if it is not working.
Apr 11, 2012 | Peavey Audio Players & Recorders
Peavey PV 8.5C DDT is activated on channel A even al low volume, channel B works fine. All 8 power transistors on both channels were found OK. Driver transistors and 15V zener diodes are all OK as well....
Check your speakers and Cables. I had some speakers that traveled in my small trailer and the vibrations of the trailer caused the diaphram to back off my horns. Once I got the speakers fixed the DDT light on my power amp stopped staying on so much.
Jan 07, 2010 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
I have a peavey cs-800x that i used to DJ
check first for loose connections or bad connectors. you might try to replace the cables just to check as isolating each channel. hope this helps
Aug 20, 2009 | Peavey PV-3800 2-Channel Amplifier
Eq on channel a doesn't work on 2 units
It could be an internal ground connection on the EQ that's broken ( maybe inside the connector) ..I repaired numerous peavey products and broken grounds are common.
Feb 11, 2009 | Peavey EQ215FX Home Equalizer
CS-800 buzz in channel a
First a couple of questions:
1) Is the level of buzz controlled by the volume control? Based upon your initial post I would think yes.
2)When you say you want to use the other amp as a regular amp, do you mean to drive a single speaker or more?
Dan
Feb 06, 2009 | QSC MX1500A 2-Channel Amplifier
Peavey 1500 PA amplifier, no output from channel A
is amp configured correct
use same input and same speaker on both sides
check output fuse on A
if fuse ok then problem is inside unit
get tech to open and check all input and output wiring
Jan 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Open Questions:
See all QSC MX1500A 2-Channel Amplifier Questions
QSC MX1500A 2-Channel Amplifier Logo
3,183 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
