Question about Scheu (BG150T) Heater
NEED IGNITOR FOR UNIVERSAL model K150 FAS manufactured by SCHEU PRODUCTS
HAVE AN EXECELLENT HEATER WITH A BAD IGNITER. DOESN'T HAVE AN IGNITOR BUTTON, BUT IGNITES WHEN PLUGGED IN
2 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: reddy heat/scheu kerosene space heater no ignition
Typical kero heater uses either a spark ignition or a hot surface. The hot surface igniter is very fragile. A small bump may break the elements. Flame is detected by a photocell, signal is sent to the lockout relay board. Change the igniter costs about 50 bucks.
Posted on Nov 29, 2007
Oven will not heat up
when you ask a question you should send the brand name and model number off of the machine you need help with.if it's gas check the ignitor,if you can see the orange glow from the ignitor as soon as you see it start to glow if the flame doesn't ignite within 40 seconds the ignitor is bad.if you can't see it remove the racks and the bottom floor of the stove so you can see it,if it doesn't glow check the ignitor for continuity to see if it's bad.if the broil works and the bake doesn't 90 percent of the time it will be the ignitor.if it's electric send more info.
Jan 05, 2012 | Kitchen Ranges
Bake does not work
most likely you have a bad ignitor,this is the first thing that goes,if it glows and doesn't ignite the flame within 40 seconds after it starts to glow the ignitor is still bad even though it glows orange.if it's a flat ignitor it takes 3.2 amps for the ignitor to open the gas valve and ignite the flame,if it's a round ignitor it takes 2.5 amps to fire it up.you don't have to shut the gas down,if it's a fairly new machine no electricity will go to the ignitor either if it's shut off but you can shut the breaker down if you want.the machines are not like the older machines where you lite it with a match,they are electronic ignition so check the ignitor first,if it doesn't glow at all you can check the ignitor for continuity with a meter.if you need any more help send the full model number off of the machine,open the bottom draw under the oven door,look on the frame,left or right side and you'll see a tag with the model number on it.good luck and happy new year.
Dec 30, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven does not heat up
most likely you have a bad ignitor,if it glows and it doesn't ignite the flame within 40 seconds the ignitor is bad.just because it glows doesn't mean it's good.
Dec 12, 2011 | Frigidaire Gallery 30" Self-Cleaning...
I have a magic chef ovan/mic unit, when I press the bake option and set the temp the igniter goes on but the gas does not kick in. model # 54FN-5TKVWM
even though the ignitor glows it doesn't mean it's good it opens the gas valve by amps not just because it glows,if you turn on the stove and when you see it glow if the flame doesn't ignite within 40 to 50 seconds you have a bad ignitor.if you leave it alone for a few minutes does the flame ignite?the only other thing it could be is a bad gas valve but most likely it will be the ignitor
Sep 25, 2011 | Magic Chef Ovens
Heater blower goes on an smells like gas and doesn't light
The ignitor is not working. I don't know what kind of ignition your heater has but it is either a thermal ignitor or a spark ignitor. In either case the problem could be in the ignitor or the board that supplies the power to the ignotor.
First of all, be careful while looking into the system when the gas comes on because it could unexpectedly ignite and burn you.
If your unit contains an ignitor it should glow brightly when the gas starts. If it is glowing then it is probably not glowing brightly enough or not in the right place and therefore needs to be either replaced or repositioned. If it is not glowing then you should measure the voltage using a volt/ohm meter going to the ignitor. If it reads about 115 then the ignitor is broken and needs to be replaced. If it reads much lower voltage then the board that supplies power to it probably has a problem on it. It may be a defective relay, bad solder joint or some other problem. I would first re-solder the relay connections to the board and see if that fixes it. Otherwise the board will need to be replaced.
If the unit has a spark ignitor and you hear a spark sound it may be too low power or the spark probe might be in the wrong place and therefore not delivering the spark to the fuel air mixture. If you don't hear the spark then you may have a bad relay or bad solder joint to it.
Please let me know how this works out. Thank you.
Sep 03, 2011 | Hayward Gas Swimming Pool Heater 100k Btu...
Lower oven will not common. The button to ignite the oven doesn't light up to start .
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 24, 2011 | KitchenAid Ovens
The oven of my Chef 635 model GSC6635SLP doesn't ignite (no gas comes out in oven, yes from plates), the ignition element is working, there is electricity in terminals connected to thermo valve but it...
heatman101
Jul 13, 2011 | Ovens
Amana arg7102w gas range broiler works fine but regular oven doesn't heat up, viewed igniter from the back while turned on and see igniter glow but no gas flowing, can't find service manual online...
heatman101
Jul 12, 2011 | Amana Microwave Ovens
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Reddy Heater R50A will not ignite
yep.plug the unit in and look in the back of unit.should see an orange glow.if you don't the glow bar is not comming on
Feb 23, 2009 | Reddy Heater-30-55,000 BTU Variable
Scheu (BG150T) Heater Logo
54 people viewed this question
Top Scheu Heating & Cooling Experts
Stuart Slabber
Level 1 Expert
Tom Chichester
Daryl Gleaton
Are you a Scheu Heating and Cooling Expert? Answer questions, earn points and help others
