Question about Onkyo TX-SR605 Receiver
Use JBL Creature speakers (pc speakers) through tv
Any help welcome.
I currently run my JBL Creatures through my tv, I plug a jack into the amp/woofer and the other jack into the headphone socket on my tv, this allows me to control the volume with my tv remote, unfortunately, the sound is not as great as it should be.
If i just run rca to rca the sound is as it should be, but i cannot control the sound with my tv remote.
Bit of a catch 22 situation.
anyone got any ideas.
Dave
  • david_hankin Jan 25, 2009
    Thankyou, I have already tried the menus on the tv, but no joy.
    the tv is a Samsung PS42QHDX plasma tv.
    I have also thought about runnning jack from woofer to sky + box then optical audio out from sky + box to optical audio on plasma??
    Dave
There may be a setting in the TV's menu to set fixed or variable output for the rca's. You want variable. Some have two sets of audio outputs for fixed and variable. Depends on the TV. Check those two things. If no help let me know what the TV is and we'll see what we can do.
Posted on Jan 25, 2009
Where to Find my Serial Number?
The serial number is at the bottom of the subwoofer.
Aug 21, 2012 | JBL Creature III 2 Speakers
Humming sound cumin from my creative inspire 4.1 woofer
Make sure that you've fully pushed in the jack to the sound card.....maybe you've not connected the jack into the correct socket on your soundcard as there are usually 3 identical sockets...but only 1 is the correct one. Sometimes colour-coded green. Try it in each one in turn. If you have headphones, try plugging them in as you will hear sound in them when you've got the correct socket!
Apr 27, 2012 | Creative Labs Audio Players & Recorders
How do i connect the following speakers to a tv?
Look for a headphone jack plugin on the TV, and if you have one then plug the speakers into that. Otherwise if you only have RCA audio jacks on the TV (red/white plug-ins), you'll need an RCA male/stereo female adapter. I did a quick search and found this one on Amazon for $1.49:
http://www.amazon.com/Male-3-5mm-Stereo-Female-Y-Cable/dp/B000I23TTE
You could probably find one at Radioshack or a local electronics store otherwise.
Also, in case you need it, here's a link to the owner manual:
http://www.jbl.com/resources/Brands/jbl/Products/ProductRelatedDocuments/en-US/OwnersManual/Creature%20OM%20Rev%20A.pdf
Sep 06, 2011 | JBL CREATURE II Computer Speakers
I am an active duty soldier and i am stationed in germany. I watch alot of tv using my laptop to stream. i currently have my laptop hdmi'ed to my tv. how do i get the sound from my computer to my Bose...
there is "headphone" socket in your laptop & there is "audio input" in your tv, u need to connect both to get sound. u need a connector which has stereo jack pin at one end & 2 RCA pins at other end. please find out these sockets on laptop & tv & then buy the connector.
Sep 05, 2011 | Bose T20 Theater System
Hello, I have a pair of JBL Platinum Series speakers linked to my PC, which are just a few months old. They were working well, but they have stopped working. Although the green light comes on when I turn...
Hi Lauren This is the process of elimination which i would follow in a similar situation: -check cable going from computer to speakers, make sure both ends are plugged in correctly; -ensure sounds are not muted on your computer;
-try to play a song using another program such as windows media player. If this works, it's most likely the iplayer program which has been muted. -If none of this has helped, try plugging the speakers into a different device, such as a stereo headphones jack, ipod headphones jack, even a TV headphones jack. If the speakers still do not work, they are probably no good.
Hope this helps, Benji
Oct 02, 2010 | HP JBL Platinum Computer Speakers
I have a 50" samsung plasma that was working fine now the volume just dissapeared & when i try to adjust the volume it shows the normal volume display with headphone icon in the display & when i...
You would need to replace the headphone socket then and if I am correct it should be mounted to a plug in board. I first need the model number of your Samsung to look up the part number. The model will be on a sticker on the side and will be something like HTP50***/XAA or something like that.
Sep 02, 2010 | Televison & Video
My tv has one sub output socket,but my active sub woofer has a red and white input sockets.what lead do i need to connect it up with?
Sounds like the output on the TV is a phono socket or a jack and the inputs on the sub woofer take banana plugs. You need (or should make up) a lead with a phono or jack plug one and and two banana plugs the other end. (phono plug/socket has two connections and banana plugs just one)
If you can provide the model numbers of the two bits of equipment I can check this for you.
Mar 08, 2010 | Audio Players & Recorders
No audio output to tv on my dell 1545
That, & most, earphone sockets, simply doesn't have enough "Current" or signal voltage to drive your TV set's audio in Amplifier. You need to get a Pre-Amp, to amplify the signal, up to a level that can be used by the TV. So you need to purchase, or build from a kit, a small stereo pre-amp and insert it between your laptop & TV audio In.
Feb 04, 2010 | Dell Inspiron 1545 Notebook
Onkyo TX-SR605 Receiver Logo
544 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
