FixYa.com
Tags:
HP Pavilion a340n  PC Desktop
Date/time defauting to Dec 2000 (by 2 users)
posted by Matzke on Jul 14, 2007
Whenever I log on after the computer has been turned off, the date defaults to December 2000. It appears to be a millenium issue.
I have tried the setting to ON for "Automatically synchronize with an internet time server" and also tried with that unchecked..........neither solves the problem. The machine seems to run slower until I correct the time/date to current.
What should I try?
Comment by Matzke, posted on Aug 11, 2007
Changing the battery was my second option, did not have to go there. From hp.com, an easier solution that I thought I would try was to remove and reinstall Realtime clock. Did that and it was solved.
Thanks to all.
Comment by Matzke, posted on Aug 12, 2007
Follow up comment: The clock worked the first time that I started my computer from being off. But the next time that I powered it up, it went back to the December 2000 date.
I will try updating my BIOS or changing the battery on the mother board.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Larrinel, posted on Nov 22, 2007
Clock keeps changing from correct time to incorrect time
Best Solution
posted on Jul 14, 2007
FixYa! (100)
MrJLH
Rank:Wiz Wiz
Rating: 83%, 405 votes
Change the "battery" on the mother board. Sounds like it's weak and there's not enough voltage to maintain the BIOS memory.
Comment by MrJLH, posted on Jul 18, 2007
Here's more info for you.
http://h10025.www1.hp.com/ewfrf/wc/docum...
Also see if you have the latest BIOS version.
Good luck
Rating Locked! (?) Matzke has rated this solution as FixYa!
Solution #2
posted on Jul 26, 2007
FixYa! (100)
ShaC
Rank:Master Master
Rating: 92%, 67 votes
The bios battery could have been drained up. Replacing the battery is the only solution.
Remove the side cover of your computer, on the motherboard you can see a silver color round shaped object, thats the battery. Remove it, you may have to use a screw driver to pull it out. Note the code written on the battery and purchase a same one. Put the new battery on the motherboard. Make sure that the +ve discharge should come on the top.
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
posted on Apr 15, 2008
Not Rated (0)
acharyulu
Rank:Guru Guru
Rating: 86%, 37 votes
Hello
It may be of the defective CMOS battery inside the CPU.
Change the battery and set the time once and restart the system.
Let me know if your problem is solved and rate me as FIXYA!
Solution #4
posted on Mar 29, 2008
Not Rated (0)
acharyulu
Rank:Guru Guru
Hello
I think its the CMOS battery problem
1. Remove the top or side cover of the CPU
2. Look into the mother board.  You can see a CMOS battery which is upto size of 50np.
3.  Remove it carefully and replace the same
This Problem Also Relates To: HP Pavilion a400n (DQ173A#ABA) PC Desktop HP Pavilion A610n (PC106A#ABA) PC Desktop HP Pavilion a810n (PP164AA) PC Desktop HP Pavilion s7310n (EN996AA) PC Desktop HP Compaq d530 SFF PC Desktop HP Media Center m7250n (ED842AA) PC Desktop HP Media Center PC 873n (P9875A#ABA) PC Desktop
Can you Help with these PC Desktops problems?
PC Desktops
my printer spooler and spooler
my printer spooler and spooler... Answer This...
PC Desktops
can you put a memorex
can you put a memorex 2 hd 3.5... Answer This...
PC Desktops
cant access the webcam on
cant access the webcam on my... Answer This...
PC Desktops
how do i change the
how do i change the mail... Answer This...
PC Desktops
need ip adress and primary
need ip adress and primary dns... Answer This...
Repair Service
Find PC Desktop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
