Question about Nuova Simonelli Oscar Coffee Maker, Espresso Machine
Machine won't heat
My Oscar has worked fine and all of a sudden will not heat. I assume it is some part such as a heating element?
    Habit-Forming:
    New Friend:
  • 82 Answers
Thermal overload maybe open, reset if resetable, change if fixed type
Posted on Jan 11, 2018
2 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Heater problem with espresso machine
Make sure there is water in the boiler, unlug machine remove the top panel and on the side of the boiler is a reset thermostat.
Posted on Jun 04, 2009
Whirlpool heavy duty 5cycle 3 temp dryer won't turn on suddenly stopped..no sound whatsoever..changed heating element and still not on
Check your thermal limiter . It should look like a white bar about a inch long . You can find it on the blower housing
Feb 17, 2013 | Whirlpool Dryers
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Nuova Simonelli Oscar No Steam After Descale
when you descale your machine, how did you drain the water? I think the scale particles clogged your steam pipe. And also if you had put a lot of descaling chemicals, this chemicals can eat up the heating element. If you can remove the heater and check it physically and also cleaning and removing the scale inside the tank will help.
Jul 15, 2012 | Nuova Simonelli Oscar Coffee Maker,...
Autofry Mti-5 - no error codes, was working fine and suddenly won't heat up at all.
we have a MTI-5 Autofry, and the display shows "Basket Can't Find Home". what can you recomend?
Jul 31, 2011 | Kitchen Appliances - Others
Our machine keeps shorting out. help!
You have probably have a burn our heating element and need to be replaced.
You can remove the two wires going to heating element leave them free and try to plug it in so you can confirm if it is the element.
Good luck, thanks for positive voting
Aug 09, 2010 | Nuova Simonelli Oscar Coffee Maker,...
No heat, will not dry
Is your dryer electric? Assuming so, you're probably right that the heating element has gone out if the drum is turning but there is no heat at all.
I don't know if you are a do-it-yourself type, but if you take the model/make/serial info to your appliance parts store, you can obtain the correct heating element and install it yourself.
I hope this helps... Good luck!
Oct 23, 2009 | Dryers
Open Questions:
Nuova Simonelli Oscar Coffee Maker, Espresso Machine Logo
83 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
rhodesworks
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
