Question about Kenmore Washing Machines
KENMORE 110/24832200 WONT DRAIN - Kenmore Washing Machines
Wont drain
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 06, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
My washer wont drain the water....It spins but wont drain
This must be a brand new Kenmore 20.6 cu. ft top freezer refrigerator. I have serviced over 10,000 refrigerators and freezers. Never once did i see one that had a washer, let alone one that spins but wont drain. Maybe you should try the washer forum.
Mar 15, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
417.44152400 it wont drain
I have a 417.90862990, it was not draining. Seemed to stop during the wash or right before the rinse. Had the tech out and replaced the motor and belt, still had the same issue. He replaced the timer, now seems to be fixed. I say start with the timer.
Jan 24, 2010 | Kenmore Washing Machines
Kenmore dishwasher 206c1513p007 wont drain
take the cover off the bottom of the dishwasher inside and remover the built up food and turn the wire by hand and even use your hand as a plunger
Jun 29, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
My kenmore 80 top load series wont rinse top load wont rinse
drain pump is trying to drain. maybe have something in pump
Jun 22, 2009 | Washing Machines
Kenmore 90 series washer model 20922 wont drain
have you tryed blowing back the drain pipe to clear and sourse of fault,also is the water element heater working ok?it could be waiting at a thermostop position till its up to correct temp,hope this helps
May 27, 2009 | Kenmore 15944 Top Load Washer
My washing machine water wont drain,it is a kenmore 90 series.
  • first thing to check is the lid switch.
  • if the lid switch is bad it will fill up, then agitate then sit there full of water.
Jul 05, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
23 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
