Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Print too small when printing,
Print too small for documents, need to know how to change it back to original size. I havre a Lexmark X 5100 series printer.
  • brn2pc Jan 25, 2009
    Thanks for your prompt response, however the default paper is already on 81.2 by 11.
  • 34 Answers
Try changing the defualt paper to 81/2 X 11, it may be on a smaller size.
Let me know if this helps.
Posted on Jan 25, 2009
How to change print size
Assuming you're referring to the print size of the fonts - letters ..... or the size of the printed page ...
If you're printing from your computer, you'll need to change the size of the font (to a larger font size) on your document before you print, or adjust the print Properties ... to fit to page, or magnify the size of a small document ...
If you're printing a pdf file, you can specify the size of the document using the enlarge (%) before you send it to the printer
Jan 15, 2014 | Epson WorkForce WF-2530 All-in-One...
Black ink on edge of paper
You may try to clean the rollers using a slightly damped paper towel.
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 5100 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Jan 23, 2012 | Lexmark X5150 All-In-One InkJet Printer
Installed new printhead,took new ink I had just put in old printhead and put it back in new printhead. Will print nothing.just spits put blank 4x6 photo paper it says to load in to get calibration.Then it...
The document specs of your printer is given below:
Document & Media Handling Max Original Size Legal (8.5 in x 14 in) Original Type Sheets Min Copy Size 3.5 in x 5 in Max Copy Size Legal (8.5 in x 14 in) Standard Media Capacity 100 sheets Output Trays Capacity 50 sheets Document & Media Handling Details Input tray - 100 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ Output tray - 50 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ ADF - 3.94 in x 5.9 in I would rather suggest to take a print in normal A4 size plain paper and see what you get. Please revert back Suspected 1) paper scanner faulty not able to judge paper.
Sep 10, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
When I attempt to copy a document-8in. X 11in- and have the copy menu set to -"original size auto detect,the printer persistently prints a smaller document size,usually 4" X 5". I have...
Try to reset your Lexmark X4650 settings to factory defaults. On the printer operator panel, press Setup -> select Defaults -> select Set Default -> select Use Factory -> press OK. Then try to make a copy again.
I hope this information has been helpful. Thanks.
Jan 06, 2011 | Lexmark X4690 Wireless InkJet Printer
I would like to increase print size occasionally to enable better readability of the printed document.
In checking for information on your printer I noticed that there were new drivers released in November for Windows 7:
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_CA&locale=en&productCode=LEXMARK_X2500&page=product&frompage=null#1
Your User Guide is available here:
http://www.lexmark.com/publications/pdfs/2007/2500/v3709407_en.pdf
Normally if wish to change the print size of a document you would change the Font Size within your word processor. The same would apply if you viewing a document on the web. For example, in Windows Explorer go to View, Select Text Size. Make your selcetion. Before printing I would choose the Print Preview selection under File to make sure it is what you want.
Trust this is helpful. :)
Dec 10, 2010 | Lexmark X2500 All-In-One Printer
My printer keeps repeating old subjects, and the print is very small... new inkjets are in.. Nothing else to add... I can't get it to print from my computer... the copies are ok.
I'm not sure I understand what you mean by "repeating old subjects", but that sounds like a printer queue issue. Try the following, and test printing after each step.
  1. Reset the printer. (instructions here)
  2. Print a self-test report. (here)
  3. Clear the print queue (see here)
As far as the size of the print, you will need to adjust this setting in the application you are printing from...In other words, you have to change the size of the text in the original document.
If you're printing from an IE browser, check the File>page setup options and make sure your haven't checked shrink-to-fit. Otherwise, use the File>Print Preview command to monitor the size of text in the printed material. In the browser, zoom adjustment affects the printed output.
On the other hand in Word, etc, you'll need to Format the font size in the document to change the printed text to a larger size.
(The zoom level adjustment only affects your view of the document at hand).
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 12, 2009 | HP Deskjet F340 All-In-One Printer
How to increase the size of the print? Print is too small
Right click on web page, choose select-all. Right click again click print preview, goto top tool bar and click full view (mouse over icon), then choose Custom from the Change Print Size drop-down menu. Specify how large you would like the webpage to be printed by setting a percentage in the Custom Size text box. This will enlarge the printed size of the entire webpage, but it might result in some of the webpage being cut off on the printed document. Usually you have more than one page to print. This is one way, maybe someone else can give a better way. Good luck.
Jul 18, 2009 | Lexmark C533DN InkJet Printer
Cant make prints lighter or darker
There are two ways to do this. One is to change settings in whatever application your are using. Increase your font size or bold your font (if you're talking about a document.)
The other way is to change your printer properties. Go to your printing preferences (from your print dialog or from Start->Printers and Faxes->right click on Lexmark 5400 Series->select Printing Preferences) and increase your Print Quality.
Steve
Jan 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Print out is too small
To resolve this, try the following actions:
* Check the default fonts within Microsoft Windows.
* Select your entire document and set it to a larger font.
* Make sure all your fonts are loaded properly.
* Change the resolution to quick print at 600 dpi. To do so:
1. Click Start, Settings, Printers.
2. Right click the Lexmark printer icon and choose Properties.
3. Choose the Document/Quality tab and set the resolution to 600 dpi quick print/draft.
* Change the Spool Data Format to RAW. To do this:
3. Select the Details tab and click Spool Settings.
4. In the Spool Settings screen, set the Spool Data Format to RAW.
5. Click OK and then Apply.
Nov 19, 2007 | Lexmark X2350 All-In-One InkJet Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
61 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
