Question about Rancilio Silvia Espresso Machine
Rancilio Silvia keep resetting
I have been using the Rancilio Silvia for almost 5 years now, it has been working fine until now. When I turn on the machine, the boiler heats up and when I start brewing, the safety button of the thermostat goes off, and I have to reset it each time. What part went wrong? is there any fix to that? thanks
  • puilamchan
    puilamchan Jan 21, 2013
    I have finally found the problem, even tho I was in the brewing mode, the temperature of the boiler keep raising and never know when to stop, so it keeps on boiling and boiling until it gets overheated. What should be replaced en?
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Posted on Jan 21, 2010
EsWorld
  • 1618 Answers
SOURCE: UPDATE on
If there is not a red pin on the top of the thermostats, then the easiest way to tell which one is bad is with an ohms meter or just replace both.
Posted on Feb 03, 2010
I've tried grinds from a very fine to a coarser grind in my Rancilio Silvia, but the water is going through the portafilter/coffee too quickly. When I clean out the portafilter, there is too much dry...
Check the shower screen to make sure it is not damaged. Then try this get coffee ground from the store at #2, 3, 4 and 5 at least 1/4 pound each then use that to figure out what setting works best for your machine, also note the tamping pressure. Fill portafilter to rim then tamp to fill ring in basket.
Aug 24, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia not heating
Unplug machine and remove the top panel, check the thermostats on of them tripped reset and you should be back in business.
May 29, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
Jan 26, 2010 | Rancilio Silvia Espresso Machine
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Silvia keeps brewing after shutting off
maybe cooffe termostat is bad and overheating
Aug 23, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Keeps tripping the Breaker
Usually when that happens there is a problem with the element in the boiler.
Jul 06, 2009 | Rancilio Silvia Espresso Machine
Noisy during heating cycle
element is litlle bit bad.you need change element .
Nov 02, 2008 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
