Question about HP LaserJet Enterprise 600 M603n Workgroup Monochrome Laser Printer
How to reset an hp laserjet m603n - HP LaserJet Enterprise 600 M603n Workgroup Monochrome Laser Printer
    New Friend:
  • 4 Answers
Hi Angela,
What is a problem whit printer? Service error 49.xx.xx or?
Posted on Jan 18, 2013
HP PRINTER LASER JET 600 ERROR 59.00.90
www8.hp.com/us/en/support.html
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
Jun 17, 2014 | HEWLETT PACKARD - LASER JETS HP LaserJet...
49.4a.04
49xx,xx is a generic firmware error ( windows blue screen of death type of thing)
lots of things can cause this the most common by far is a corrupt file:
firstly disconnect the printer from the pc and turn off then wait 10 seconds before turning back on ( still not connected to the computer)
the printer should now be able to come to ready, ( IF not- main PCA failure - ) now clear the print queue form the computer by opening the printers folder selecting the printer and right click menu to ' see whats printing' - then clear everything in the list.
now reconnect the printer and have the printer driver send a test page, if this is printed your error has gone! :)
Mar 18, 2014 | HP LaserJet Enterprise 600 M603n Workgroup...
M603n initialisation error
Initialization error is usually related to the communication connection. Make sure that the connection is solid. Might want to unplug the cable from the back of the printer and then turn the printer on, comes to ready ? If so the cable or connection might be bad.
Jan 12, 2014 | HEWLETT PACKARD - LASER JETS HP LaserJet...
Hp laserjet m603n flashing orange warning light and says "ready" then changes to "please wait...checking printer" sitting like this for days now. When I reboot withought the ethernet cable it boots u
What do you mean by "When I reboot without the ethernet cable it boots u......?" It boot ok and the flashing orange light, stop? Try using a local USB connection to a nearby computer and see if it works.
Jan 18, 2013 | HP Laserjet 600 M603dn Laser Printer -...
Reset password HP LaserJet Pro 400
Where is the go button on the hp laserjet M425dn? I have been trying to reset to default setting, student put a password on the printer.
Dec 05, 2012 | HP Laserjet Pro 400 Mfp M425dn...
HP laserjet 4600dn printer. Replaced the HP C9724a transferkit, but the message "new transferkit" does not appear. How to simulate putting it to zero. Erik 22-06-2010
The printer counter needs to be reset by going into menu and finding resets. Then toggle down until you come across Transfer Kit & press ok.
Jun 22, 2010 | HP LaserJet 4600dn Color Printer
LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
walid_sayed@hotmail.com
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
May 07, 2010 | HP LaserJet M4345 MultiFunction Printer
Replacing Print Cartridge
Turns out there was an easy solution. I filed a support case and had an answer in half a day:
"Often this issue is caused by a sensor. â Therefore the first thing we should do is try to trigger the sensor.
1 Turn off the HP LaserJet 3050
2 Remove the toner cartridge from the HP LaserJet 3050
3 Remove all of the paper in the paper tray
4 Check the entire paper path for any obstructions
5 Reseat the toner cartridge and paper
6 Power on the HP LaserJet 3050
If the issue is still not resolved we will need to try some resets on the HP LaserJet 3050.
1. The first reset we can try is a soft reset, it is done by pressing the MENU key then holding *# together. â This will bring you into a Developers Menu. â Scroll through the options until you find reinit FFS and then press the ENTER key.
2. If this reset doesn't clear the issue we can try a harder reset. â We can do this by pressing MENU, scrolling over to SERVICE, pressing ENTER, scrolling over to RESTORE DEFAULTS and pressing ENTER to restore the defaults and ENTER to confirm.
WARNING: Restoring the defaults will clear your fax settings, phonebook numbers and headers so you may want to print a phonebook report and Config Report first. â We can do this by accessing the Reports menu.
3. If these two resets do not help there is a third reset we can try.This reset will completely put the HP LaserJet 3050 back to factory defaults.WARNING: Before doing this reset we will need to disconnect the power cord, the phone cable, and the USB cable from the back of the HP LaserJet 3050.We can do this reset by unplugging the power cord from the back of the HP LaserJet 3050 then holding down the MENU/ENTER key and * symbol at the same time,then powering the HP LaserJet 3050 back on with the keys compressed.We will release the keys as soon as PERMANENT STORAGE INIT appears on the display screen."
I tried all the steps in sequence; it took #3 to fix it. Fortunately I didn't have a big fax address book or custom settings, so a factory defaults reset didn't cause any extra problems. It retained the time and date, and now it works fine.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet Enterprise 600 M603n Workgroup Monochrome Laser Printer Logo
220 people viewed this question
Ben Johnson
