Question about Kitchen Ranges
How to wire thermostat to the blower - Kitchen Ranges
  • 3 Answers
Should be wired in series with each other...
Posted on Jan 18, 2013
My empire heater wont turn off and just keeps blowing cold air. pilot is lit and all thermostat wires seem to be connected. any ideas?
Sounds like the thermostat for the blower motor (not the gas thermostat) has shorted. Remove front cover on stove. Follow the wires from the blower motor back to the blower thermostat. Replace with new one. Blower model # DRB-1.
Dec 04, 2010 | Empire DV-35 Heater
The blower will quit blowing
If this is aair handler/ Gas or Electric.
1) Shut power off
2) Remover blower door and locate blower motor
wires and then reconnect them. Restore power If
that does not cure them problem then:
1) Shut power off and remove blower door again, find
the thermostat wires and remove the wire from the
G-Terminal. Restore power if that cures the
problem, then you need to make sure the
thermostat wires are not touching either at the
thermostat or between furnace and thermostat.
If that does not work then:
2) It could be the high temperature limit that is
inserted into the unit above the burners usually.
If it is failing the switch opens up and the blower
will operate on its own.
3) Turn power off and locate this switch, put a jumper
wire or connect the two leads that go to this
switch, restore power, blower should not be
operating. The High limit switch is bad
Jun 22, 2010 | Goodman GMS90703BXA Heater
I tring to change thermosat I can not remeber what color go where
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Heating & Cooling
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
I have a coleman Evcon model AH16-0 . I am
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 06, 2010 | Heating & Cooling
Trying to figure out thermostat wiring diagham on a split system
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 05, 2010 | Heating & Cooling
Blower stays on
check your thermostat,
is the blower switch on
check your t-stat wires and make sure your connections are the same as on the blower
sounds like you have red on the blower
connection on the control, keeps 24v on the blower when the the t-stat is on
Oct 13, 2009 | Heating & Cooling
Goodman a/c blower fan will not shut off
Unhook the thermostat wires on the furnace. If the blower shuts off then your problem is either the thermostat or the thermostat wires. If it contiues to run check you high limit switches next. If all else fails you most likely have a bad blower relay. On most modern furnaces the blower relay is part of the circuit board.
Good luck
Mar 29, 2009 | Goodman CLQ36AR49 Air Conditioner
Blower stays on with new themostat
Check to see if there is a short between the green wire and the red wire. Green is the fan control wire for AC. Sounds like some wires may be touching. How did the old t-stat get fried?
Jan 02, 2009 | Honeywell Programmable Thermostat Heater
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
