Question about Refrigerators
Water wont work on jenn-air frenchdoor refrigerator?
Changed filter checked watter pressure when i push watter i can here pump try to move water. but no water comes out
Replaced watter valve
Posted on Feb 01, 2009
Jen Air Refrigerator (JCD2290HEW) developed problem with having low water flow at water dispenser and water hammer after changing water filter and depressing water dispenser to remove air. Have changed the...
I understand the correct manufacturers number for the PuriClean II water filter for your refrigerator should be UKF8001 or UKF8001AXX, that you have the correct filter, and you have plenty of water out of the dispenser when the filter is not installed. If all that information is accurate you have 30 pounds or more water pressure (although the minimum is 20 pounds the higher the pressure the better for flow will be), then I would try holding the filter under the faucet to be certain the water flows through the filter without a lot of resistance. If that checks out, I would look for a gasket or some other part from the old filter that is stuck in the filter housing.
Nov 03, 2013 | Jenn-Air Refrigerators
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
Tip
New Jenn-air refrigerator, Model #JFC2087HRS, water filters do not work...
The new Jenn-air refrigerator, model #JFC2087HRS, water filters (UKF8001) do not work correctly. Water flow is slow. I have called the manufacturer but cannot get any help from them. They insist they work fine. I have tried several of the new ones. The problem seems to be that the small ramps on the new water filters are not tall enough to push the small plungers sufficiently into the water dispenser. I have added a small piece of plastic (glued) to the ramps on the water filter in order for them to work better, but not as good as old ones worked (UKF8001AXX). The next best thing is to buy the old filters if you can find them.
on Feb 24, 2014 | Jenn-Air JFC2087HRS Side by Side...
We have a jenn-air jfc2087hrs (french door model) and the water pressure from the internal water dispenser is very low. the line has plenty of pressure.
If your ice maker is making full size cubes then it should one of 2 problems.
The water valve on the bottom back of the machine is a dual valve. One side feeds the ice maker, the other side feeds the water supply.
1. The dual water valve. is going bad. The water side is malfunctioning.
The dual valve must be replaced.
2. Your model should have filters for the water dispenser, and need replaced.
Try changing the filters first.
Oct 04, 2009 | Jenn-Air JFC2087HRS Side by Side...
The ice maker in my Jenn Air refrigerator stopped working.
Check that there wasn't a clog in the line after replacing the filter. Make sure you get water going to the solenoid, if so, it may either be a clog in the solenoid or a fluke that it's no longer working.
Sep 10, 2009 | Jenn-Air JCD2389G Side by Side...
I have a Jenn Air JSD2789GES side by side refrigerator and The water won't work to the ice maker or the water in the door?
Check if the water is on.
check if the water filter connected correctly or the bypass.If the filter is new and the appliance is new you should press the water handle or button till the water comes as the selenoid are open during you push.
Jun 30, 2009 | Jenn-Air JSD2789GES Side by Side...
Jenn Air Ice Maker Ejector Fingers Freeze Up
Hello, Yes you may be on the right track. Some manufactures like Jenn-Air, Viking, Sub-Zero, etc. require a higher inlet water pressure across the inlet solenoid valve to close the diaphragm after the ice machine stops calling for water. There are multiple solutions. But first, check the water pressure to your home to make sure you have 65-70 psi of pressure entering the home. Here is a link to our web site for a reasonably priced solution to increase the discharge working pressure from your RO System storage tank to the Jenn Air: http://www.puresafe.com/RO/html/eps-3tpp.html This is a modification that can be done to your system. It is a Patented Piston Actuated Permeate Pump that relieves the Permeate or Pure Water "BACK"-Pressure when the pure water enters the storage tank so the tank can store more water and build more working pressure. You could also increase the size of the storage tank, increase the size and daily production of the Membrane Filter to recover the tank water quicker, or add additional storage tanks for more volume of storage. Another method would be to use an "Atmospheric Storage Tank" with the RO System, and a Pressure Delivery Booster Pump to **** the water out of the storage tank and Pump it to the required location under higher pressure and flow when compared to the Conventional Pressurized Bladder Tank that you own now. The drill down path to our site for this information would be: www.puresafe.com, Purification, Reverse Osmosis, Residential, Pump Assisted Reverse Osmosis, EPS-3TPP, or other systems on that page. Hope this helped. Victor Kernes
Jun 25, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn Air JRSD209T
This is just anecdotal here, but one repair guy who came out and thawed a frozen line into the icemaker told us the fridge required near-full line pressure 90- or 70- or whatever that is, in order for the ice maker to work. This was a licensed repair guy. We were feeding it with an RO, which only pumped it in at 17 or 20 psi (or whatever the unit is) which he informed us was inadequate. However, after he thawed things out and we changed out the inline carbon filter in the fridge, everything was hunky dory for a couple of years. About a year back, the icemaking stopped, and changing out the carbon filters in the fridge AND in the RO system did the trick.
Now we have a different problem. Things aren't getting or staying cold, especially the fridge. I opened the housing in the back of the fridge, defrosted the extensive ice accumulated around the refridgerant coils, and everything ran great for a couple of days. Now we're back in the global warming pattern: steadily rising temperatures and thawing. I'm not feeling too happy about Jenn-Air these days.
Jun 17, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
