Question about Spectroniq PLTV3250 32 in. LCD TV
Lost remote where can I get a replacement in the Cincinnati area?
Need remote for volume and audio sound.
    Sergeant:
  • 183 Answers
Try ebay
Posted on Jan 18, 2013
P250WT upstar used as monitor. Lost volume output. How to reset ?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts
Nov 01, 2016 | Upstar Televison & Video
Olivia tv has no sound but see picture what does this mean?
  • Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2
    Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3
    Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • May 07, 2014 | Vizio L32 32 in. LCD HDTV
    No sound
  • 1 Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2 Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3 Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • Read more : http://www.ehow.com/how_7498064_troubleshoot-vizio-sound-problem.html
    Mar 08, 2014 | Vizio Televison & Video
    The Akai TV MA TE02 lost sound
    It sounds that the audio output section circuit has the fault. Check it audio out pre-amp sockets at its back, connected to any external Amp. See whether audio comes out by this way. If not, the main digital board is faulty. If yes, audio output section is faulty.
    Dec 31, 2012 | Televison & Video
    I lost my instructions for hooking my sound bar up to my new tv I ahd it hooked up to the last one and it worked now no sound and when I raise the volume it doesnt do a thing I programmed it to with m
    Some sound bars have a seperate power cord, did you plug it in. Also, the source for the sound, are you using the audio outputs and not the audio inputs. They are all the same color (red and white) so you may have plugged in the wrong ones. If the sound bar is getting power, say a green led and the source for it is the tvs audio ouput jacks you might have to see if there is a seperate remote for the sound bar and raise the volume. Lastly the tvs audio output might have a seperate setting, it could be fixed or variable. Fixed will only change volume with the sound bar remote. In variable you will be able to change the volume with the tv remote but first you have to raise the sound bar level. Hope this helps in some way.
    Feb 26, 2012 | Televison & Video
    Lost volume on my tv
    Using the remote click on the menu and find audio
    check each area under audio and change one at a time til you get the sound back. Keep notes on what u r doing so u don't make matters worse. J.
    Jul 10, 2010 | RCA F27242GY 27" TV
    We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
    Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
    Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
    I have lost the volume control icon from the desktop toolbar and want to restore it
    To display the volume icon in the taskbar notification area, you must select the "Place volume icon in the taskbar" check box in Control Panel Sounds and Audio Devices applet.
    May 21, 2009 | Dell Inspiron 1501 Notebook
    It has lost partially the mechanical connection between the volume control knob and the volume control pot.
    The knob could be "stripped". A drop of a slightly resilient glue should do the trick. Do not use rigid adhesives, as this will prevent future service to this area of your receiver....accordianman
    Oct 31, 2007 | Yamaha RX-V630 Receiver
    Sound
    hi, ya, someimes the POT i.e the volume controller variable resistor loses its contacts with the carbon strip. tru using some switch cleaning solution( NoN Acidic) to clean the POT,let me know
    Dec 07, 2006 | Yamaha GX-70 CD Shelf System
    Spectroniq PLTV3250 32 in. LCD TV Logo
    20 people viewed this question
    Top Spectroniq Televison & Video Experts
    Frank Zabroski
    Frank Zabroski
    Jayesh Panchal
    Jayesh Panchal
    Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
