Question about Royal Sc120 Shredder
THE BLADES ARE FULL OF PAPER. SHOULD I TAKE IT APART AND ATTEMPT TO CLEAN IT?
    Problem Solver:
  • 7 Answers
In order to maintain a functional paper shredder, you should clean it out and oil it at least once a month(depending on usage) if not every time you fill it.
I would advise against trying to disassemble the actual blades to clean them out if that's what you mean by "take it apart."
What you can do is unplug the machine, lay the blades up and get a pair of tweezers and remove any large pieces of paper/shredding that might be caught in there.
After doing that you should oil the blades with any lubricant that your owner's manual recommends.
Most shredders suggest a non-aerosol/biodegradable oil such as vegetable oil.
Do not use WD-40 or other canned spray lubricants.
I've found that dripping the oil straight into the blades can be very messy so a good alternative is to lay out a piece or two of scrap paper and soak it in the oil. Then run the paper through the blades as normal.
They also sell varieties of this here: http://www.staples.com/Staples-Shredder-Lubricant-Sheets-12-pk-Shredder-Sheets/product_602400
It doesn't have to be a headache to maintain but proper care can make your shredder last a long time.
Posted on Jan 18, 2013
Where can I download an instruction manual for a Royal MC5 - 5 sheet maximum microshredder? How do you fix a tight paper jam?
Hit reverse if got one, or take it apart carefully cuz it's sharp, remove blades and try to clean it then, it's like replacing the cutting wheels they called I think, make sure your motor is not fried. Good luck
Jul 07, 2015 | Office Equipment & Supplies
How do you clean the jammed paper so it will work?
I'm thinking that you have already run the shredder in reverse, right? After you disconnect from power supply and remove screws, most shredders can be disassembled quite easily. Be careful with the cutting blades, not only are they sharp but they have a preferred order in assembly. I give my crosscut shredder a good cleaning about every two years, having run about 5,000 documents with personal data on them through it in that time.
Sep 19, 2014 | Office Equipment & Supplies
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Office Equipment & Supplies
Paper has wrapped around the cutting blades and is packed in tight. How do I clean this?
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
    • 3 Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Office Equipment & Supplies
I have an advent tv/dvd combo. I dont have a remote and its stuck on video. how can I put it on tv without the remote? thank you
Disconnect the TV\DVD combo from power source (A\C) for two to three days, Replug power cord & see if it returns to normal. 2nd attempt:: Unplug A\C power from wall and take a piece of bear wire or any metal (paper clip, screw driver ) and SHORT the two blades of A\C plug for at least one FULL day.DO NOT PLUG INTO a\c SOCKET FOR ANY REASON !!! After one full day, take the short accross the blades. Replug into A\C power socket. see if that fixes the problem. P.S. Your TV should have a button that switches from TV to DVD play right in the right front.
Jun 19, 2011 | Recoton Advent Advent DV1418A 14 in....
Blades normally glide tight thru hair....cleaned and oiled blades but still meeting resistance on perfectly combed not matted hair. Blades are approx 5 yrs old. Do they need sharpened maybe. Should I...
Ok if you take them appart don't touch the screws you will find it hard to re-align, if your blades haven't been sharpened for 5 years the i think its a very good place to start
Jan 22, 2011 | Andis AGC2 Hair Trimmer
Odd metal to metal sound
You can't really clean the blades...however , a x-cut shredder should be lubricated regularly....try putting some shredder oil on a sheet of paper and shredding it...do this a number of times to get the oil down into the cutting blades, see if that helps.
Apr 09, 2010 | Royal VF1000MX Shredder
Printing in black is not the same shade through out the paper
This is a very common problem with the Samsung CLP 300 and CLX 3160 printers. What happens is that the toner or developer blades become coated with toner. The developer blades meter the amount of toner that the printer uses to make the image on the paper. When the blade become blocked, the image become faint. To fix this problem, you and either replace the imaging unit for about $100 or you can clean the blades yourself. I have posted instructions how to clean them on my Tips section.
Jan 26, 2010 | Samsung CLP 300 Laser Printer
The shredder is making a thumping noise like something is out of whack. Tried lubricant and running back and forth. It still thumps.
Common problems.
Jammed paper.
When sherdding paper that has any type of adheasive or glue, such as junk mail advertisments, the glue gets stuck on the blades.
FIX:
1 - UNPLUG
2 - remove top cover
3 - using a small screwdriver or other pointed small object, carefully clean out
the blade paths of jammed paper. Typically there is a cylinder of blades on the underside that does the shredding.
4 - be careful not to damage or PRY the blades, just enough pressure to get the paper out.
5 - dont use oil or lubricants, they can GUM up the blades.
6 - assemble
Give it a try.
Oct 10, 2009 | Fellowes PS60C-2 Shredder
My paper shredder stopped working
First things First...UNPLUG THE UNIT. It sounds like it has been fed too many pages at one time. You may also want to dump any shredded paper so there is plenty of room for the shredder blades to pull in the paper. If the paper catcher is too full the blades can grab shreds from the bottom and stop the blades movement. Just be careful. Shredders can be dangerous.
Jun 01, 2009 | Office Equipment & Supplies
Royal Sc120 Shredder Logo
383 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
