Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi ws-65513 My Mitsubishi ws-65513 will not turn on. The LED blinks off and on. I tried the unplug/plug route and the reset option. But that green light keeps blinking. you can email fix to odwallaman@yahoo.com
  • Rick Jensen Jul 14, 2007
    I would like to replace the capacitors, got a lot of info and direction, but the caps are on backorder until 9-12-07? is there other ones comparable to those? for the repair
  • Rick Jensen Aug 04, 2007
    what happened to the link for the DM fix? it doesn't work?
    President:
  • 3,130 Answers
Have you looked at the DM board fix yet that's available here. http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Check it out. If the inside of your TV set does not look like this, you will need to get the service manual to disassemble the set and get to the DM board, but use the rest of the guide to repair the board. If you are successful, you will save almost a 1000 bucks! Good Luck
Posted on Jul 14, 2007
  • 1 more comment
  • Larry  Dillon
    Larry Dillon Jul 15, 2007
    Look at Radio Shack
  • Larry  Dillon
    Larry Dillon Aug 04, 2007
    It was modified and changed around again, try here. http://www.fixya.com/howto/h159332-mitsu...
  • Stacy Carto Nov 16, 2012
    I see that this post was in 2007. And....5 years later the "green blink of death" still exists. It happened to our TV last night! Major bummer! This link to fix doesn't work. Is there a new one? Thanks!
SOURCE:
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Cannot turn tv on
mine required a bulb replacement it wasn't that old at the time
don't like being turned on and off a lot
Dec 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
You can get the V23 DM repair kit at the following link which has the replacement capacitors and the instalation instructions on Cd which has pictures of the repair. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Aug 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi TV WS-65713
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-65513 tv. The green light keeps blinking. thanks
samzlades@yahoo.com
May 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513
if you changed the energy mode from standard to low that is normal, anytime you turn the set on it will do the same,
plug set green light will blink one minute.
turn it on it will blink onother minute and then turn on(make sure that you dont keep pressing power key) once on you can change your settings again.
hdtvman.
Apr 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Cannot turn tv on
i have a fix for this DM board, if you want it please leave your e-mail addy and I will send it to you. This guide has pictures and tells you how to get to the board and what is the problem with it most of the time. good Luck
Feb 28, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
429 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
