Question about Intermatic Inc. ML121RT Malibu Low Voltage 121-Watt Power Pack with Timer
Where can I order some replacement ML Power Pack trippers for a ML600TW and ML 300RTW timer?
  • Intermatic Master
  • 5,245 Answers
1) Copy following link for ML series trippers, troubleshoot, 5-year warranty info, and tips to keep power pack running longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) Add comment if more help is needed. Jan 2013.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jan 19, 2013
  • Barry Smith Jan 19, 2013
    thanks, Gene, problem solved - ordered them today!
4 Suggested Answers
protek480
  • 1723 Answers
SOURCE: My intermatic timer won't trip back on
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 26, 2009
  • 52 Answers
SOURCE: need timer trippers for model 3405 24 hour
Replacement parts at electricalexpeditors.com
Posted on Dec 30, 2009
SOURCE: My Malibu ML600TW power pack is stuck in the ''on'' position
There are no repair parts for intermatic/malibu power packs.
You can buy cheap plug-in timer, and plug power pack into cheap timer.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Posted on Feb 28, 2011
How to install Intermatic ML600TW
Copy following link for ML600 installation manual, installation tips, problem-avoidance, troubleshooting, replacement trippers, warranty information:
With the ML600, there are usually two sets ABC terminals.
Connect wires to AB terminals unless using photo eye.
Connect 300 watts to each set of AB terminals.
Nov 22, 2012 | Malibu ML600TW - Low Voltage Power Pack -...
I purchase a Malibu ML600TW. My quest is. In this unit are there 2 separate 300 watt transformer. or when you contact the line in you are wiring to 600 watts.
With the 600 watt ML series, there are two sets of a-b-c terminals. C terminals are used with photo eye.
Connect 300 watts of bulbs to one set a-b terminals, connect 300 watts to other set of a-b terminals.
I'm not sure what is inside the power pack. However if you run less than or more than 600 watts or let your bulbs burn out for any length of time, the power pack can burn out. Save your receipt for limited 5-year warranty.
For your benefit, open following link for more information on ML power packs, plus troubleshoot, plus tips to keep power pack from burning out, and links to trippers:
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 24, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
Red pin missing from friend's Malibu outdoor timer. Need to replace. Numbers / info on timer: 120V 60hz, 600 W Max, 158ML, 1194B 300 W/Sec 06A
Open following link for power pack resources including link to Intermatic ML series trippers.
Same tripper fits all ML series timers.
For all Intermatic trippers and parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
May 17, 2011 | Malibu Intermatic Inc. ML300RTW 300-Watt...
My ml600tw timer stopped working. How do you replace the timer? I took screw out by timer but I cant pull timer out. Is it held in another way?
You posted under Intermatic/Malibu ML series power pack.
There are no replacement clock mechanisms or timer modules for ML series power packs.
If you found a replacement clock motor source, add a comment add a comment here so others can benefit. If you find a way to repair clock motor, also add a comment.
Many people have same problem and will benefit from your discovery.
To work around problem, buy cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
ML series has 5 year limited warranty.
Open following links for troubleshooting resources, warranty links, manual links and Intermatic parts:
Apr 19, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
Where can I purchase the plastic tripper switch
You posted under Intermatic or Malibu power packs:
For full information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips: Including order form and direct link for ML series black and red trippers
Nov 10, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Where can I purchase the trip inserts for this product
Nov 09, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Need red plastic timer clips for my ML600TW. Transformer works, but only have one red movable clip for setting a time. Timer may be broken, but would like to try installing the on/off clips first. Any idea...
Open following link for ML power pack trippers, plus troubleshoot, plus tips to keep power pack from burning out, and warranty:
Upvote the help.
Oct 04, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
My ml600tw will not turn itself on when the pin gets to the pre-set time
Open following link for ML power pack troubleshoot, plus tips to keep power pack from burning out, trippers and warranty:
Upvote the help.
Sep 02, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
My 300 watt Malibu Power pack sticks and won't turn on automatically, but will go off automatically ok but it sticks trying to turn on
If clock motor has gotten weak, then buy cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
Upvote the help.
Lost manual i need to hook up the wires to the transformer
Open following link for Power Pack trippers, troubleshoot checklist and warranty information and other tips to keep power pack working longer:
Upvote the help.
Aug 30, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Intermatic Inc. ML121RT Malibu Low Voltage 121-Watt Power Pack with Timer Logo
130 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
