Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Burner element broken - Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
  • Official Brand Answer
  • 4,342 Answers
Hi friarjp - I am happy to assist you. First, I will need your model number to better address the issue at hand. With this information I can verify which part you need exactly. Is it the right, left, back or front burner element or are you referring to the bake and/or broiler element.
Posted on Jan 22, 2013
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Oven shuts off by itself
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
The reason for my free advice is GOD is good!
Apr 21, 2014 | Whirlpool Ovens
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
Ge electric oven will not turn on
Hi Shane I need a little more info , like dose the broiler work ? dose the burners work , most times if the lower element isent working it has burn out , this is a cheep easy fix, look at the element with a flash light for damage it will have bump's on it or could be broken right off , this is the first thing to check , If it is the element I can locate you one to order and tell you how to change it but i will need the model and serial number and also is it the top or the bottom element , get back to me, and please always remember to rate this question: thanks Frank
Dec 13, 2011 | Ovens
When trying to turn on the front right burner it doesn't heat at all what do I need to replace?
Check the wiring to the element, be careful shock hazard. On my electric range the wires were broken where the element plugs in socket. Socket kits are about $9.00 us If you have a volt meter unplug the element and turn the control on if you have voltage then replace the element. Thanks Tom
Nov 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Cannot light burners electric ring not working either.regulator seems ok.
Check fuse first. Check for broken wire where the element plugs in. Unplug the stove from wall ,pull out the element and drip pan , remove the screw and pull the plug out and see if both wires are on. If they are remove the back panel about 6 - 8 screws, check for broken wires to and from the regulator.
Apr 24, 2011 | Ovens
4 elements stopped working at the same time on Frigidaire FEFB68CBC
sounds like a main bus feed wire that powers the burners has burned of broken off and you have lost one phase,check terminal (L-1) inside rear of unit and trace up to elements
Nov 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
The right front burner won't heat
The switch probably failed. Remove power. Take off the top rear cover and inspect the switch for signs of discoloration (burned or brown areas). If looks OK then maybe the element failed.
May 28, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Trouble Shooting
I hope by now it is working. You have probably knocked a wire off or actually have broken the burner itself. Can you check it for continuity.It may not appear to be broken but the coil on the inside may be depending on how hard the board hit the element.
Apr 16, 2008 | Kenmore 47783 Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
46 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
