Question about Fuji Cameras
Charge with out charger
I have not the external charger
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
What model Fuji camera?
Posted on Jan 18, 2013
I have an Invacare Pronto M-91 Sure Step Electric Wheelchair that when plugged into wall socket is no longer charging chair batteries. The onboard Signet charger's led light isn't illuminating at all when...
The charger is defective. I would not try to charge it externally because if you charge it with a higher rate of current (amperage) than the original charger, it could explode or leak.
Jun 05, 2014 | Health & Beauty
Battery charger
EXTERNAL OR INTERNAL EXTERNAL GET A TRICKLE CHARGER CHARGE MORE THAN 2 AMPS INTERNAL CHECK ALL ALTAERNATOR COMPONETS WIRES ETC. REPLACE AS NEEDED
Jun 23, 2013 | 2002 Honda XR 200
Camileo p10 wont turn on or charge
I had a similar problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger just a USB cable. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Dec 18, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Any idea where I get a replacement charger for a Metz60CT4
EBay, if that's what you want. The metz "chargers" are just 7 volt ac transformers - they supply 7 volts to the battery pack which has the actual charging circuit in it. I haven't pulled one apart yet, but I'm guessing they're very rudimentary chargers. Depending on what you're using for a battery you might want to use a modern external smart charger. I use $20 AGM batteries from batteries plus (instead of the $80 metz batteries) and use an external charger from WallMart on them. It's quick, lets me see the current charge state, won't overcharge the battery, and works on my car and boat batteries too.
Jan 24, 2012 | Metz Mecablitz 60CT4 TTL Flash
I have charged my camera but it will not stay on when turned on
you dont have explain exactly the problem.. if the problem turn on and off istantly this is shure a lens problem and you mst change the lens. if the camera turn on one two 3 minute and than turn off its probably that the camera dont charge the batterie. if the camera dont charge you can bypass the problem. you can buy on ebay a external charger for your batterie. if you search on ebay international seller you can find charger and batterie to a very good price. its possible to find two batterie and one charger to 10 sterl. so you have new batteries and a external charger. external charger is better as charge the battery in the camera. why i is nott so difficult that the batterie explode and ruine the camera. with a external charger this is not possible why you can ruine the charger that have a low cost but not the camera. i hope that i have help you. its possible that the camera dont charge its possible that the batterie dont mantain the charge.. its possible if the camera go on and go out directly that this is a lens error.. sorry foer my english
Aug 10, 2010 | Kodak EASYSHARE M1063 Digital Camera
I cant charg my psp i cant find my charger
When you say you can't cahrge it, do you mean on your PC, PS3 or with the charger? I don't think the PS3 charges the PSP, I have no idea about the PC, but if the PSP doesn't charge using it's charger, it is either the battery, the charger, or the psp charger outlet. If it is the battery, buy a new one. If it is the charger outlet, it is a good idea to have 2 working batteries and to buy an external charger at game crazy, game stop, or from sony. This way, you can switch out batteries while playing, like me :). If it is the charger, buy a new one.
I would suggest first trying to buy a new battery. If it works, you are good to go and your old battery was broken, otherwise your charger/ charger outlet is broken. Buy an external charger. Then, you will be able to charge the batteries while one is in the PSP.
A new battery and an external charger cost about $70, but it is worth it. I hope i helped.
Sep 05, 2009 | Sony PlayStation Portable (PSP) Console
Nokia 1100 not charging from external charger
Ther charging circuit seems to be defective or your charger is gone. Try and test the charger elsewhere.
Jul 28, 2009 | Cell Phones
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
Cameras Logo
12 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
