Question about Honeywell 40 In. Oscillating Tower Fan with Built-in Ionizer Heater
Honeywell hz-360c high temperature reset button is stuck
The power went out while running my Honeywell hz-360c heater. I heard a click about 10 seconds after it shut off. Now that the power has been restored I can't get the heater to work. Pushing the "Power" button only makes the led's on the panel flicker and a light clicking sound comes from the heater.
  • Brian Sliede Jan 21, 2013
    Several hours later I noticed a high temperature limit switch just above the heater element. I pulled the plug on the heater and then poked a straightened paper clip into the temperature switch. I heard a click and then tried the heater and it worked. Thanks for proposed solutions.
SOURCE: Honeywell HZ517 Baseboard Heater
This troubleshooting approach may be sound, but you need a deep security star screwdriver to open the heater up. I have looked in specialty tool and electronics shops and no one has a screwdriver that gets in deep enough. You won't go anywhere without this screwdriver, so if anyone can suggest a source, that would be great.
Posted on Nov 30, 2005
SOURCE: Honeywell HZ-709 Oil Filled Radiator
Problem: firs let's identify the problem, there is a sensor on the inside panel, made originally for safety if you tipped the heater off, it kill the power causing it to turn off...after a year of so that sensor get a little rusty/dirty causing it not to work correctly...
let's find out how to fix that annoying turn off..
tool needed, a phillip screw driver.. electrical tape or soldering unit..
fixing it: take out the top and bottom screws, to open the panel. after you open the panel you'll see a metal bar screwed to the front controller...take all 6 screws out...the front panel comes off....then there is about 4 screws holding an inner box, open that up..
inside there, you;ll see lots of wires...look for 2 small blue wire running together to a black sensor that make noise everytime you move it....
disabling the sensor
2 ways you can do this..
-you can cut the wire off using a scissor, and connect the blue wires together, use the tape to tape them.
or
- you can solder them together on the back of sensor panel...
there you go problem solved...
Posted on Mar 25, 2008
SOURCE: Honeywell 6300B clicking noise
This is normal it is just the relay.
Posted on Jun 09, 2008
  • 4 Answers
SOURCE: HZ-725 honeywell cooltouch heater..Lights on but no heat
The screws are "Tamper-Proof Torx" head, it takes a special T15H tool bit to remove the screws. I just disassembled one of these non-working units and the problem with this unit is a open diode on the heater element board. Not sure the purpose of the diode, but no voltage is going through it. I doubt if parts are available as I see no link for parts on the www.kaz.com website. This unit has been quite hot inside as the plastic mounting peg for the heater element board is melted near the diode area.
Posted on Nov 18, 2009
  • 74 Answers
SOURCE: Honeywell HZ-709 oil filled radiator heater-all
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
Posted on Dec 07, 2009
Reset a Honeywell HZ-709 portable electric oil room heater?
I'm going to ask the first "obvious" question: are you sure the socket you're plugging into is delivering power? (Sorry to ask but it's an Occam's Razor kind of situation) Have you tried a different socket in the same room? Next, does the main power switch for the heater have different settings i.e. high, medium, low, high-high, high-low, low-low and have you tried those combinations? Next, pick up the heater (if it won't hurt your back) and give it a robust shake. Try the power again. Any luck? Keep us posted.
Mar 06, 2015 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell HZ-338 thermostat problem
See if there is a little brass-looking bulb on a wire (sensing bulb) inside that can be moved away from the heat. My other thought would be maybe there is supposed to be some insulation between the control unit and the heating element that was inadvertently discarded?
Nov 27, 2013 | Honeywell HZ-338 Ceramic Compact Heater
Need to replace off switch
How about a free replacement heater?
There has been a recall since 2002 on some Honeywell portable baseboard heaters. Check this link, or call Honeywell ASAP. The ON/OFF switch failed (with a burning plastic odor) on my HZ-514.
http://www.cpsc.gov/en/Recalls/2002/CPSC-Honeywell-Consumer-Products-Announce-Recall-of-Moveable-Baseboard-Heaters/
"Consumers should stop using these heaters immediately, unplug them, and contact HCP at (800) 290-8495 between 8 a.m. and 10 p.m. ET Monday through Sunday or log on to the company's website at www.honeywell.com to determine whether their heater is part of the recall."
I hope this is a solution for you, and you are safely warm again in the near future. need-replace-off-switch-gwybjxudtwjfkyidrgix5fxs-5-0.jpg
Mar 12, 2013 | Honeywell HZ514 Baseboard Heater
Need a thermostat for model no hz-514
I hope this is a solution for you, and you are safely warm again in the near future. need-thermostat-model-no-hz-514-gwybjxudtwjfkyidrgix5fxs-4-0.jpg CPSC Honeywell Consumer Products Announce Recall of Moveable Baseboard...
Feb 03, 2013 | Honeywell HZ514 Baseboard Heater
How do we operate and turn on it i have no manual
The left button under the temperature display lets you toggle between the heat output (high, medium and low) settings. Press the left or right side of the buttons. The center button sets the timer; press the left side of the button repeatedly to increase the run time. Press the right side to lower the length of time before the heater shuts off. The right hand button sets the desired final temp. Again it's an up/down toggle on the left and right sides of the button. Once you get to the desired temperature (in 1 degree increments), the display will return to showing the current temperature three seconds after you release the button.
Home Depot has the Use and Care manual on their product site: http://www.homedepot.com/buy/honeywell-1-500-watt-oil-filled-convection-portable-heater-hz-709.html#.UMp5GTmk5G8 . The direct link is http://www.homedepot.com/catalog/pdfimages/79/79058e0a-291f-48e8-8667-ff500b3d7bb7.pdf?cm_mmc=seo'altruik'202804472 . You will need Adobe Reader or a similar program to view the document.
I hope this helps.
Dec 14, 2012 | Honeywell HZ-709 Oil Filled Radiator...
THE HEATER RUNS FOR 2-3 MINUTES AND AUTOMATICALLY
Thermal safety is tripping, clean it out , no repairs viable for theses units,
May 23, 2010 | Honeywell HZ365 Ceramic Compact Heater
Honeywell HZ-705.....HELP!!!!
Should have oil in it. I don't think you can refill it. If it has leaked out, it's probably no good. Anyway, here are the instructions.
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Aug 17, 2008 | Heating & Cooling
Honeywell Surround HZ2200 / HZ2204 /
A link to an Adobe (Acrobat) Reader format (.pdf) owner's manual for Honeywell® (Mini Tower) SURROUND HEAT™ HEATER FAN Models HZ-2200 (charcoal) and HZ-2204 (white) is here.
Some text from the manual:
SET UP
• The Surround Heat™ Heater is designed to
disperse heat in either a 360° range or in one direction only.
• To select the desired heating mode, slide the Direction Control switch, located
on the top of the heater, to the position of your choice:
– to the right (full circle) for 360° Heating
– to the left (half circle) for forward only heating (One Direction
Heating)
OPERATING INSTRUCTIONS
Select the appropriate heat dispersion mode. (See
Set-Up instructions.)
• With the Power knob in the OFF position, plug the
heater into a polarized 120V outlet.
• Turn the Thermostat control fully clockwise to the
HIGH setting.
• Turn the heater on using the Child Resistant switch
(Power knob). To operate the switch, push down
the two sides of the Power knob while turning it
clockwise to the desired position. The power
light will illuminate. The Child Resistant switch helps
ensure that the heater can not be turned on accidentally.
• When the room reaches a comfortable temperature, slowly turn the Thermostat
control counter-clockwise until the heater goes off. This is the point at which the
Thermostat setting equals the room temperature. At this setting, the Thermostat
will automatically turn the heater on and off to maintain this selected temperature.
• Push down and turn the Power knob to OFF and unplug the heater when you
are finished using it.
Nov 04, 2007 | Honeywell Surround HZ2200 / HZ2204 /...
Honeywell oil radiator
Set temperature:
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Similar model compact heater will not "power up" after storage
they is no reset internal the electronic circuit is deferctive some electronics parts need no be changed. i have fixed one and modify it to be more reliable.
Oct 01, 2006 | Honeywell SureSet HZ-339BW Ceramic Compact...
Honeywell 40 In. Oscillating Tower Fan with Built-in Ionizer Heater Logo
56 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
