Question about Garmin nuvi 750 GPS Receiver
Garmin Nuvi 750 killed both my car and my double truck batteries
I had a new battery in my car and did not suspect my Garmin of killing the battery, but it did. I then put it in my truck which has 2 batteries. After a day of driving I unplugged the Garmin. The next morning both batteries in the truck were completely drained. I recharged my car battery a week ago and it has been just fine. Is it possible, if the Garmin battery is poor, that it works against the charging system?
  • Brett Duxbury
    Brett Duxbury Jul 23, 2017
    Hi Willie Baunsguard, I am wondering if the lead is faulty that plugs into the garmin. As you stated the battery is drained with it unplugged was the lead plugged into the car cig lighter socket while being unplugged from the garmin end ?
3 Suggested Answers
SOURCE: Brand new Garmin nuvi 755t won't power up.
i have had the same problem obviously. all i did was get a TORX TX5 screw driver and open up 2 screws. carefully lift off the cover(its just snapped in). Warning: battery and speaker are attached to the cover so do not pull the cover off or it will break the wire. carefully unplug the battery and leave it out for a 20 mins or so. plug it back in and it should power up and then connect it to internet, download webupdater and update. thats it and the problem is fixed.
Posted on Jun 29, 2009
  • 14 Answers
SOURCE: garmin nuvi 750 battery does not hold a charge
A new battery can be purchased and installed inexpensively. I found a video.
You-Tube video "yxP4PdRB_98" placeholder (do not delete)
http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+750
Posted on Dec 26, 2009
Nuvi 750 Car charger connection is intermittent.Either the Car charger or the Nuvi 750 connection is intermittent. The device will display a warning that it is using the battery - 27 seconds to turn o
It is very rare that it would be a problem with the Nuvi 750 GPS itself. This is because there are stationary gold pads on the bottom of the 750. No moving parts to wear out. We have seen problems with a bad plug on the charger that plugs into the cradle and the receptacle on the cradle can go bad as well. I would suspect more toward the cradle as we have seen the receptacles break away from the printed circuit board that is inside of the cradle. Best way to troubleshoot is to find a friend who has a duplicate charger and cradle and swap each piece, one at a time and see which resolves the problem... either the cradle is bad or the charger plug is bad. If you want us to test your unit, cradle and charger, let us know. Good luck! :) More info on charger issues here:
http://www.sharc.net/gps_charger_repair.htm
Apr 21, 2013 | Garmin nuvi 750 GPS Receiver
Tip
How To Replace Your Garmin Nuvi 750 Battery
From NewPower99.com, this video provides a step by step demonstration of the procedure for replacing the battery in your Garmin Nuvi 750 GPS. The battery, along with the necessary installation tools shown in the video, can be found at: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+750
on Dec 31, 2009 | GPS
I started my 92 gsxr 750 today and let it idle for a while then I turned it off with the kill switch .but forgot to turn the ignition key off.went in side for about 30 min .then came back out to start it...
By leaving key on you killed battery.Charge up battery and if dosent take charge, need new battery.Motorcycle batteries dont take much to kill,exspecialy if it is more than 3 or 4 yearts old.
Mar 06, 2011 | 2000 Suzuki GSX-R 750
When pluggin to the car charger and turn it on. it's a low battery and it keeps turning off. it doesn't charge. garmin nuvi 750.
the battery is defective and needs to be replaced, if the battery is not any good then it won't work even when plugged to an outside power source, that is how this are set up, the battery is not user servicable, u must send it back to Garmin for replacement.
May 26, 2010 | Garmin nuvi 750 GPS Receiver
My garmin will only turn on while it's plugged into the car charger. I have had it plugged into my computer for some time and it won't power on while connected to the computer or while unplugged- I...
Time for a new battery. If you talk to garmin they will want to replace the entire unit. You can buy a battery for about $23 and do it yourself.
Here is on place that sells them but I would also search for others to compare prices and specs.
http://batteries.batterymart.com/garmin-nuvi-750-replacement--list
Oct 24, 2009 | Garmin nuvi 750 GPS Receiver
Garmin nuvi 750 battery does not hold a charge
Jan 26, 2009 | Garmin nuvi 750 GPS Receiver
Battery on Nuvi 750
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 19, 2009 | Garmin nuvi 250W GPS Receiver
No car radio / stereo for use with Garmin nuvi 750 GPS
Every Garmin Nuvi unit I've seen has a (loud) built-in speaker. The only demand our 250s and 265 make of the vehicle is a 12V power supply (and they'll even work without that for a while, until the battery goes flat).
A.
Dec 17, 2008 | Garmin nuvi 750 GPS Receiver
Will not turn on
Hold the off button (to the left) for 10 seconds... the system will restart and your garmin should work fine!
Sep 13, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin 750 - 90 days old
Had the same problem-try this- leave your nuvi off for about 4 hours. Push the power button to the right(lock position) and then to the left (power on position) and let go. I suspect temperature (getting overheated is the problem. This worked for me.
Aug 25, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin nuvi 750 GPS Receiver Logo
60 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
