Question about Maytag Neptune MAH5500B Front Load Washer
Burning rubber smell
I think my Maytag Neptune washer has a belt that is ready to go out. During the final spin cycle, there was a strong odor of burning rubber but no smoke. I had a heavy load of Levis so not sure if that is the problem or if it is getting ready to break down.
  • ksmith1949 Jan 26, 2009
    Thanks, that is what I kind of thought. We did some more loads with less weight and no burning smell. It did smell like rubber the first time so thought a belt was slipping. Makes sense. Thanks!
    Scholar:
  • 42 Answers
Even though manufacturers' love to advertise it, I personally would not load "too many items", as it may cause excessive normal ware and tear on your machine parts, motor, belt, etc.
Yes; the smell can be the belt and possibly your motor as well. The motor may be spinning, but the weight may be too much when the belt is engaging to rotate the drum. I would be careful not to burn the motor (About $120 - part only)
You should be able to access and inspect the drive-belt in the rear of the machine by removing an access panel (back of washer).
To replace the belt if fairly simple. Remove and re-install by wedging a long screw driver in between the belt and metal pulley (circular), while simultaneously rotating the pulley.
You may be required to make a belt repair if you start to have problems with your "washer not spinning" or "making a noise/not spinning"
Posted on Jan 26, 2009
Screeching sound; smell of burned rubber
What is the model number of the unit?
Oct 31, 2012 | Washing Machines
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
On final spin cycle there is a smell of burning rubber and smoke coming from the back of the machine.
Hello, If you remove the rear panel you can check the condition of the belt. The belt may be breaking apart and wrapping around the motor or pulley. I would start there. If you find a damaged belt the part number is 34001411.. Hope this helps and please dont forget to rate me if this helps :)
Jun 08, 2011 | Maytag Neptune MAH6700A Front Load Washer
Maytag Neptune MAH5500BWW burn smell (doesn't appear to be hose)
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
Oct 06, 2017 | Maytag Washing Machines
Washer has been making an unusual amount of noise / burning smell
remove the door and screws on opposite side and the front comes off. Then the top will flip up.
Eric
Nov 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune has just started new odor
The rubber belt from the engine to the drum is loose: replace it, it's worn out.
Nov 16, 2009 | Televison & Video
Strong electrical smell with smoke coming out
Check the lower motor control board. See www.neptunehelp.com for disassembly pictures. It is possible you will need to replace the motor control board and motor if you have the original one as Maytag has redesigned these two components due to reliability issues. The new motor conversion kit is part # 12002039.
If there are any burnt components on this board then it will have to be replaced. There is also a 10 amp fusesoldered to the board. if this fuse blows the tub will not move anymore and the motor control board / motor will have to be replaced.
Have you noticed your Neptune's spin cycle getting loud? If so, the seal kit and bearings need to be replaced. See www.neptunebearing.com for more info on the special bearing tool kit you can rent that includes use of a DVD that shows you how to disassemble Neptune, replace bearings and install the seal kit.
Feb 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Maytag Neptune MAH5500B Front Load Washer Logo
813 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
