Question about Realspace Dawson 60'' Computer Desk
The plastic hinges for the wooden back have broken
How do I fix or replace a broken Hinge on Dell 500 Laptop
The hinge rarely breaks, the fixings come loose and split the plastic case.
Disassemble the laptop to find out where your problem is,
DELL Vostro 500 PP29L SSD
If the plastic has broken off, I use epoxy resin to repair around the hinge or look on fleabay for a replacement hinge.
Dell Latitude D500 Laptop 14 1 034 Screen Hinges eBay
Feb 06, 2017 | Dell Computers & Internet
How do you fix a dm4 Hinge that is broke where it connects to the screen
You can buy hinges on ebay at:
http://www.ebay.com
Just type your computer make and model in the search followed by lcd hinges.
If the hinges are broken where the lcd screen connects to the base of the laptop then you will have to remove the screws from the bottom of the laptop and remove the strip that is at the top of the keyboard to get to them.
If the hinges on the side of the lcd frame is broken then you will have to remove the plastic strip that is around the lcd screen. Remove the plastic or rubber bumpers on the plastic strip then you will see screws to remove to remove the plastic strip. Then you will see hinges and screws on the side of the lcd screen that you can remove. Once you have them removed you can lean the lcd lid forward so that it drops in your hand. Don't let it drop on the keyboard, just into your hand and not too far because there is a cable on the back of the lcd that you don't want to damage. The cable can be taken loose from from the lcd at the back near the top if you like. Sometimes there might be a piece of tape securing it. If the lcd screen does not come out then there are screws on the 4 corners that is securing it and the hinges.
May 13, 2012 | Computers & Internet
Broken door knob. no access to hinges, screws. Rental property!
Take apart a similar doorknob in your house. Use the stem with knob on it and insert into the square hole in the lock--turn!
Feb 27, 2010 | Hardware & Accessories
The plastic hinges on my 3210 that hold the top on
Is it just stuck? Because if it is just use WD40 on the hinges. If it's broken, then sorry. Can't help you.
Jan 18, 2010 | HP Photosmart 3210 Printer
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Jun 25, 2009 | Dometic Refrigerators
Door opening internal plastic hinge broken
Just saw you post as I was searching for the same item. If you have not found the part yet, it can be ordered from repairclinic.com (part #916507). $5.50 plus shipping.
Apr 18, 2009 | Sharp R-1480 Microwave Oven
Broken plastic Hinge clips
you could try a lumber/electrical store, or from the manufacturer.
May 27, 2008 | Toastmaster 200 Waffle Maker
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Realspace Dawson 60'' Computer Desk Logo
Top Realspace Furniture Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Realspace Furniture Expert? Answer questions, earn points and help others
