Question about Combi Centre DX - Mango
Hiya. I have an old baxi boiler wm 38/RS . The pilot light is on but the boiler will not fire up . Can u help me
  • nick_hinchli
    nick_hinchli Jan 19, 2013
    you might need to clean the jet on the piolet assembly as it may not be powerful enough
    Problem Solver:
  • 19 Answers
Rubbish!
Cleaning the jet is a job ONLY for a gas fitter as it involves disturbing both the case seals and the gas pipework. DON'T RISK YOUR SAFETY, besides which if the pilot wasn't powerful enough it would continually go out.
Check (if you're competant to do so) that there's 240vac across the gas valve solenoid connections. If so then the gas valve will need replacing by a GAS SAFE REGISTERED fitter.
FYV
Posted on Feb 26, 2013
4 Suggested Answers
  • 35 Answers
SOURCE: What boiler?
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Posted on Sep 22, 2009
  • 2464 Answers
SOURCE: hi there i have old baxi boiler i was wondering
pilot has to be on all the time on this baxi ,piolt might be a bit large might need adjusting down
Posted on Jan 21, 2010
  • 36 Answers
SOURCE: I have a baxi boiler. It is hard to get the pilot
check your pilot assembly,if flame not hitting tip then change or strip and service.
Posted on Jan 24, 2010
Instructions on how to re light my pilot light onb a baxi bermuda back boiler picture if possible thanks
http://www.baxi.co.uk/products/bermuda-back-boiler-unit.htm?view=download , i hope that will help
Feb 16, 2011 | Heating & Cooling
Baxi solo WM 50/4 RS pilot light is lit, Boiler will heat water but not rads have you any ideas thanks sam
Double check that the programmer is calling for the boiler to fire, and also that the thermostat is turned up enough.... you will hear it click as you turn it up... if the radiators still dont get warm...
then In the airing cupboard there should be a pump on a three port valve that says A,B, and AB on the different pipe outlets... It seems that this is possibly stuck in one position.... Sometimes the servo motor on top of the three port valve (square metal box with wires going into it) goes weak and requires replacement, these are not expensive from a decent plumbing spares shop I.e Pts (plumbing trade supplies) and are a doddle to install, just isolate power to it, take square the top cover off the valve to reveal the innards and you will see it straight away... Like a round brass cylinder with a flat top... It should have two screws holding it in...
Hope this helps
Thanks
Steve
Nov 06, 2010 | Heating & Cooling
We have just moved into an old house with a Baxi open fire and have no idea how to use it. Do all Baxis have boilers? How do we find the model name/number? Is there any risk in using it if the backplate is...
baxi do boilers they are on the baxi potterton wed site, but they are gas would not use with the back platecracked this old fire place you may have trouble finding parts if any , try someone one that deals with woodburners of fire places , they could well be you bestline to go down or a chimney sweep
Oct 15, 2010 | Heating & Cooling
How to light pilot light for baxi bermuda sp3
Go to this link.Bottom of page 15 on the manual
http://www.aroundtownflats.com/manuals/Boilers/Baxi/BAXI%20BERMUDA%20SP3%20GCNo.37-077-63.pdf
Basically it says (turn on the power first) Turn the knob to the the star/flame marking. Push the knob in, hold it for approximately 10 seconds. Release and check the small flame is lit. Now turn it to your desired heat setting.
Jul 21, 2010 | Heating & Cooling
Got a baxi bermuda 552, back boiler not working
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
Feb 20, 2010 | Heating & Cooling
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Hi there i have old baxi boiler i was wondering
Oct 05, 2009 | Combi Centre DX - Mango
How to light pilot light on back boiler?
Hi. we have a baxi bermuda. I know that you need to hold in the silver button on the left while repeatedly pressing red/ignighter button until pilot is lit. Hold in the silver button for at least another 30 seconds.
Good luck, ours wont light anymore so was on here looking for advice.
Cheryl
May 07, 2009 | Kitchen Ranges
Baxi Boiler not firing, pilot light ok
first check the pilot is alight, it sounds like it is cause you can hear the boiler click. that click is the gas vale solenoid trying to open, if there is 240-230volts at gas valve when you here the click and pilot is alight the gas valve is broken. if you test for voltage look on the gas valve and see if its 240 or 24v obviously if it 24 v check for 24 volts, let me know
Nov 11, 2008 | Combi Centre DX - Mango
Combi Centre DX - Mango Logo
113 people viewed this question
Top Combi Baby Gear Experts
paulcarew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
