Question about Motorola Mobility HS820 Consumer Headset
Paring Motorola HS820 with Pearl Blackberry
I am triyng to set up the Motorola HS820 with the Pearl Blackberry... at the end the BB is aking for a password. Dont know what password to write. Thanks
  • wiwhelchel Feb 13, 2009
    I.m trying to get my Motorola to work with my Razor and Nothing. Please help.
    Scholar:
  • 130 Answers
Conidering it's an HS820, and I have the HT820, I'm going to assume the passwords are the same: 0000.
Posted on Aug 17, 2007
    Scholar:
  • 130 Answers
The password is 0000. This is in the user manul for the HT820.
    Problem Solver:
  • 13 Answers
Is it a 4-8 password???????????????
Posted on Jul 14, 2007
  • Brandon Rudolph
    Brandon Rudolph Jul 14, 2007
    I THINK ITS 12345678 OR 00000000
  • Brandon Rudolph
    Brandon Rudolph Jul 15, 2007
    DID IT WORK???????
Type 0000
Posted on Aug 23, 2008
There not compatible blackberry failed to make them compatible
Posted on Mar 05, 2008
2 Suggested Answers
SOURCE:
  • 316 Answers
SOURCE: Paring Motorola HS820 with Pearl Blackberry
either 0000 or 1234
Posted on Nov 07, 2007
I want to get bsnl gprs in my bb pearl 8100 mobile What is the message i should sent.......it must be phonemake<space>modelno.... so it is blacberrypearl 8100 or blackberry 8100 or...
It is pearl 8100.They need the phone model and not the company.By the way BIS only works for blackberry and not bsnl gprs.to activate the Blackberry Plans just call 1505 or 1800 180 1505 from BSNL
Mar 23, 2011 | RIM BlackBerry Pearl 8100
Trying to pair my uniden bt108 bluetooth with my black berry. dont know password
Ok, well the password is something that you set from your blackberry device while you are in the process of paring.
So when you begin to pair the device your BB will ask you for a password, that's how you set the password. Then whatever password you chose when your BB asks for one will be the same password you use on the BT108 device.
Sep 22, 2010 | RIM BlackBerry Curve 8520 Smartphone
Motorola HS820 - cannot hear anything nor can others hear me
It turns out it was the Blackberry's problem, which could only be solved by a 're-boot' - take off the back of the Blackberry, pull out the battery for 10 seconds or so, and replace it. The BB will 'reset' and all was fine then.
Feb 16, 2010 | Motorola Mobility HS820 Consumer Headset
My BB Pearl goes straight to missed call without ringing?
you might have the call dirversion set to on. check that in your call settings
Sep 02, 2009 | RIM BlackBerry Pearl 8100
Won't pair with Motorola HS850 headset
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Pairing Motorola HS820 with Blackberry 8310
there is really no fail safe method to pairing a bluetooth device.
The main thing is recognition. i,d suggest trying to press the different buttons on the transmitting bluetooth device, whilst attempting to pair. i.e volume up/down or on/off et,c. to enable the device-blackberry to find and sync. i,d think the device that needs to be configured or setup correctly is the blackberry rather than the bluetooth device.
try changing the phone settings. to accept all incoming signals on bluetooth, or disable encryption.
hope this helps.
Mike @ Compurepair.
Oct 06, 2008 | Motorola Mobility HS820 Consumer Headset
HS820 won't activate 'voice dial' on Blackberry Pearl
Did you find a resolution.  This is the same problem I am having with the Curve.
May 22, 2008 | Motorola Mobility HS820 Consumer Headset
Motorola Mobility HS820 Consumer Headset Logo
692 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
