Question about ENVISION PERIPHERALS INC Philips - 42 LCD flat panel display - widescreen - 1080p FullHD - metallic anthracite
The tv screen turns on but only has green lines on it
No sound input,menu, any button, does nothing. vertical green and blue lines fade in and out of the screen
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
RCA l32HD31YX12 white vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 02, 2017 | RCA L32HD31 32 in. LCD HDTV
VS 5001R sounds like its gonna turn on but doesnt
This chassis model line had issues with the vertical output IC shorting causing shut down.
It also had issues with intermittent solder connections in the Horizontal Circuit. I would not try to fix it your self unless you are very familiar with Projection circuitry and electronics background.
Hope this helps,
Skyassoc
Jul 02, 2009 | Televison & Video
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Powers on to blue screen and nothing else
press the input button until it cycles through all of the inputs.
Feb 11, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mits WS-55807 blue screen, steady green light no video
Good Day, luap356;
Look for fluid on the PCB's, if don't see any try this:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Jul 17, 2008 | Mitsubishi WS-55807 TV
Lines on tv screen
Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
Vertical line at the left of the picture
Replace L506 on A board, replacement part number 1-407-366-00
Nov 26, 2007 | Televison & Video
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
ENVISION PERIPHERALS INC Philips - 42 LCD flat panel display - widescreen - 1080p FullHD - metallic anthracite Logo
22 people viewed this question
Top ENVISION PERIPHERALS INC Televison & Video Experts
Are you an ENVISION PERIPHERALS INC Televison and Video Expert? Answer questions, earn points and help others
