CAN'T GET SOUND FROM ION IDMO2 INPUT PADS
TRIGGER INPUTS DO'T MAKE ANY SOUND.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 236 Answers
And so you decided to ask the turntable experts?
Posted on Jan 29, 2013
I have a td11 it has an extra output to add a third cymbal.Can that cymbal output be split to get an extra cymbal
Info I have found suggests that the Crash trigger inputs are "piezo/switch" as required for cymbal pads using
Nov 22, 2016 | Music
The bass (kick) drum pad is not working. When i plug the kick cable into the kick pad, it does not project a sound when I strike it. I know the cable works because i tested it in the other drum pads, and...
If youve already tested the signal path and it works then your likely just dealing with a bad piezo inside the kick drum. The piezo is actually what detects the trigger. You could probolly replace it yourself it not hard typically just 2 solder joints but you'd have to buy the piezo. Call the manufacturer they should provide you with whomever distributs their parts locally to you.
Sep 08, 2011 | Simmons SD7PK Electronic Drum Set
I have an IED 11 kit. Today when I plugged it in to play, both pedals have spontaneously stopped working to trigger the kick drum. I tried numerous experiments to figure out the cause of the problem. ...
Good job of troubleshooting... I assumed you have tried other triggers into the kick drum input and found it is dead. This leaves the problem in the "brain". Look in your manual for anything to do with sensitivity of the kick drum input. It is likely all the inouts are sampled and digitized by the same A-D convertor via a multiplexor switch. I was unable to find the schematic of your unit so I downloaded one for a Roland TD8. Often the different companies rob designs from eachother so one can glean methods from a different brand. As expected the inouts are conditioned and then go to a MUXX chip that samples the input. The signals are conditioned before going to the MUX by a limiter and before that there is an RF bypass cap on the input. IF you might have had a static discharge, that capcitor(s) may have shorted rendering those inouts dead. This is what I want you to try:with a suitable cable I would like you to pulse the kick input by momentarily connecting a 9 volt batery to it... try both polarities. If NEITHER polarity fires the kick, then I want you to take an ohmmeter and measure the resistance of the input. The Roland schematic has coupling capcitors and if your brand has similar circuits you should see infinite resistance... if you find it very low, say 100 ohms, probablly the RF bypass cap at the input is shorted. These will be surface mounted caps and you need to be a bit adept at electronic repair to replace them. Essentially I believe you will find a failure in teh interface ckt where those inputs come in.
Apr 18, 2011 | ION Audio IED11 Sound Session Complete...
Hey, I have had used the Roland PD8's for a while but recently 2 of mine have just stopped working. Maybe I hit them too hard but I'm not sure because the rest of my pads work. One will work if I hit it...
Check the connections on the undersides of the pads--they sometimes get loose as the vibrations rattle them around. Tighten the nuts that hold the pads inputs in place and reinsert the cables until they sort of "click." If that doesn't work, it might be the cables themselves, so try switching them with one you know is currently working. It'll change which sound is triggered where, but you'll know it's just the cables that need to be replaced, not the pads.
Feb 18, 2011 | Roland Pd 8 Dual Trigger Pad
I can't get much sound from my tuner/receiver. I have tried all possible connections.
"Much" sound? What's that mean? Very low, almost silent, tinny?
"There is a switch on the bottom panel, next to the RCA cables, that selects between PHONO/LINE. Use PHONO level for
plugging into a turntable (PHONO) input on a home stereo. Use the LINE level for plugging into CD/AUX/TAPE inputs. WARNING: You
may damage your receiver if you plug in a LINE level into a PHONO input."
Apr 03, 2010 | ION Audio TTUSB10 Turntable
24-bit stereo drum machine with trigger inputs
solution: get a real drummer!
Jan 11, 2010 | Music
I have the ion idmo2 and I can't get the drum set part to work.I don't have instructions I lost in a move, All the rest is working. jamancuso@aol.com
I have the same exact set and module. It is the same module as the Alesis SR-16. I have the manual here but can't find it online, however, here is a link for the SR-16, I hope this helps.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CEIQFjAC&url=http%3A%2F%2Fc3.zzounds.com%2Fmedia%2FSR16_Manual-9d796d56d2c465f19b598d39a29c8d8c.pdf&ei=HkBIUYn2OdKk4AOVnoG4Dw&usg=AFQjCNHjCN7pfLOX9pINxBc_G3s0QrUsRQ
May 18, 2009 | ION Audio iED01 Electronic Drum Set
I have the ion idmo2 and I can't get the drum set part to work.I don't have instructions I lost in a move, All the rest is working. My e-mail jamancuso@aol.com Thanks Joseph
Why not download the .pdf's for it from the manufacturer's page? It's easy!
just go to: http://www.ionaudio.com/contentmgr/showdetails.php/id/1137/tt/4
Then you can save them to your computer and/or print them out.
E N J O Y!
Roland MV 8800 No inputs, phono
Hi, post on mvnation.com, they will be able to help.
Jan 26, 2009 | Roland Mv8800 Production Studio
ION TTUSB05XL - Poor sound quality
the turntable has a built-in phono preamp so you don't want to run it through phono inputs in your receiver but just regular auxiliary inputs instead
Oct 03, 2008 | ION Audio iTTUSB Turntable
 Grubhead
Grubhead
