Question about LG 42LG50 42 in. LCD HDTV
How do I take the base off of my LG42LH3000 television
I am having problems with taking the base off of my television, I have taken out two screws at the bottom, but still it does not come off. Why?
    Top Expert:
  • LG Master
  • 41,919 Answers
Usually, there are four screws that have to be removed
Posted on Jan 18, 2013
Have power only v03.55.00 showing on my lg42lh3000. Just went to a blank white screen and nothing works on the controls
Check and replace its main board. it is faulty. Contact any service technician. If you wish to get some details, http://electronicshelponline.blogspot.com/Pull up older posts.
Dec 21, 2013 | LG Televison & Video
Hi i have the lg42lh3000 lcd tv and half the screen is darker than the other
The CCFL (Cold Cathode Fluroscent Lamp) at the darker end is not lit. Either the CCFL is fused or the ballast is needing repairs.
sonsunny
Jun 18, 2011 | LG 42LG30 42 in. LCD HDTV
How do you remove the stand from a panasonic TH-50PV30 50 inch type with 3 levvels of storage shelving. Thanks.
Never owned the this TV, but from what I can tell the outside edges on either side should have a series of screw holes. Even if you can't see the actual screws, there are philips head and there are in the bottom of those 4 or 6 holes. Take those out to get the TV off the stand.
Those may also be covers for a less complex connect to the spot where the additional speakers normal mount. Either way, remove still starts there.
Apr 27, 2011 | Panasonic TH-50PV30 50 in. Plasma...
Hello, I am not sure if this is the exact sytle of fan but the receiver is not working and I am having trouble getting to it. I have taken off the blades and the screw just below the base. Now I'm not sure...
Sorry to read about your problem, I hope this helps you out.
the receiver is located up at the ceiling part the upper most cover remove all base screws
you wil need 2 people for this
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Hampton Bay B552ODWH Gazebo Plus Ceiling...
HOW DO YOU GET THE TV STAND OFF A UMC UX26A TV
Check the tv back cover at near around the base stand area.Lacate all screws near or at the base stand,spray some WD40 in each screws holes and wait like around ten mins.Take a Philip screw driver take out all the screws out in the srews holes.Take ur hand slicely push it foreward and pull it back.Now u should have no trouble taking out the base stand.
Dec 15, 2010 | Philips 42PFL5332D 42 in. LCD Television
How many screws has to be taken out for removing from pedestal stand of lg 47" Scarlet.
The 42” has 4 screws and the 50” has 5 screws.
So, your 47” may have 4 or 5 screws on the back to hold that base on.
The pattern is:
O………O
……O…..
O……….O
If there are only 4 screws then the middle (or 5th) screw will not be there.
Good Luck.
May 19, 2010 | Televison & Video
Im wanting mount my 37 in toshiba regza but i can figure out how to take off the bottom brace that supports the tv as it stands. i have taken off all the screws but the brace or base still wont come off.
Carefull turn the tv on it's back and remove the 2 black screws in the bottom of the stand in addition to the screws on the back that I assume you already removed.
Nov 10, 2009 | Toshiba REGZA 47HL167 TV
Need base for Insignia TV
It will either slide out from the front/back or to the side..Some actually bolt on from the bottom using screws/bolts.And then again some are not meant to be taken off.Make sure it is a wall mountable tv.Then try to take the stand off as directed.
May 29, 2009 | Insignia LCDTV26 26 in. Television
Removing base from tv
I researched this problem on the net and found the solution. Someone on one of the posts said the base can be removed by taking out four screws - all from the back of the TV. One screw is the one closest to the power plug, the next screw is beside it, the remaining two screws are the corresponding screws on the opposite side of the base panel (still on the back of the TV). Once these screws are removed the base comes off including the mounting bolt and the rectangular shaped plastic panel. There are no electronics or any components inside the base panel, only the bolt and plastic base which are held on by the four aforementioned screws. It was very easy to remove!
Apr 12, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Base removal of mounted plasma
Pls do not take any other screws, other than silver screws.if you take the 6 pcs of silver screws and pull the stand it will come out easily.
Sep 01, 2007 | Haier HL32BG 32 in. LCD Television
LG 42LG50 42 in. LCD HDTV Logo
18 people viewed this question
Computer Repairing
Computer Repairing
