Question about Philips Senseo HD-7810 Coffee Maker
Senseo coffeemaker 7810/15 is leaking water all over counter. Not sealing well?
  • Anonymous Jan 28, 2009
    Same problem, new senseo leaks as soon as the water container is placed on unit.
    Problem Solver:
  • 17 Answers
Call senseo at 866-4-736-736 and describe the problem. it is the seaing mechanisim at the top brewwing portion that is loose, either you are not closing it right or the pressure is getting too high forthe seal.
if you have purchased or received it as a gift less than two years ago they will send a new one.
Posted on Feb 03, 2009
  • LuvCreama Feb 03, 2009
    Call senseo at 866-4-736-736 866-4-Senseo and describe the problem. it is the seaing mechanisim at the top brewwing portion that is loose, either you are not closing it right or the pressure is getting too high forthe seal.
    if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
2 Suggested Answers
  • 17 Answers
SOURCE: My Senseo coffeemaker 7810/15 leaks
Our Senseo Coffeemaker switches off half way through running a coffee.
You have to clean the unit. It must have calcium deposits, preventing it to heat the water properly. The unit overheats and the thermostat shuts it down.
Mar 03, 2011 | Philips Senseo HD-7810 Coffee Maker
My senseo coffeemaker has stopped pumping hot water through the coffee pods. What do I do to fix it?
When was the last time you clean it with vinegar? Run vinegar through it and you will see hard water scales that were built on the heater. Coffee makers should be clean out every month then with 2 rinse cycles after that.
Jan 24, 2010 | Philips Senseo HD-7810 Coffee Maker
My Senseo coffeemaker 7810/15 leaks water out of the spigot all over the counter.
Jan 25, 2009 | Philips Senseo HD-7810 Coffee Maker
Leaking coffeemaker
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Jul 21, 2008 | Cuisinart DGB-600 Coffee Maker
DGB-600 grind & brew thermal coffeemaker
Water leaking from the base of the unit.
Jul 17, 2008 | Cuisinart DGB-600 Coffee Maker
My senseo is leaking water more than brewing coffee
The leaking out onto the counter is coming from the reservoir. I had the same problem and was about to throw my Senseo out. Here's how to fix it.
When you put the reservoir back onto the Senseo the bottom fits into a hole that is surrounded by a rubber seal. The seal appears to be attached to the bottom side of the plastic shelf that the reservoir sits on. The problem is that the seal has pulled partly away from the plastic surface to which it is attached allowing water to leak onto the counter. Put a little glob of clear silicone sealer (like you use around glass) onto the end of your little finger and work that along the upper edge of the seal where it meets the plastic shelf. You want to be sure you go all the way around and that you squeeze the sealant into the crack between the seal and the plastic. When you're finished, wipe off any excess and make sure that the inside edge of the seal (that fits around the nozzle from the reservoir) is free of any excess silicone. Let it dry for a day and you're ready to go. I did mine and it works great now. No more leaks.
Jan 20, 2008 | Philips Senseo HD-7810 Coffee Maker
Water leaking
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great! But I must say that i have seen better engineering in child's toys!
Aug 31, 2007 | Cuisinart DGB-600 Coffee Maker
Philips Senseo HD-7810 Coffee Maker Logo
503 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
kenneth njonjo
Tom Chichester
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
