Question about NAD C340 Integrated Amplifier
NAD C340 has lost ability to switch between inputs
I have a NAD C340 that can't switch between inputs. All inputs are active at all times. I took to high end shop to have it repaired. ALthough they aren't a NAD repair outfit they do work on high end gear. They switched out the Micro chip AND the switching chip to no avail. They were all stumped. Am i stuck with just a power amp now?
  • david soriano Jul 16, 2007
    No...the light lights up on whatever input i select but that is neitehr here not there.
    If i have 4 sources playing at the same time i get 4 signals being sent to my speakers and 4 sets of audio being heard.
    As i understand it relays aren't used in this piece...just the switching chip, which was replaced.
    thanks
I have the same problem which started about a month ago and seems to be getting worse. I also noticed today, that 1 channel is significantly louder than the other - fault in the pre-amp stage, as feeding the power stage directly gives balanced, albeit extremely loud sound! Looking on eBay, I found someone else selling an amp with both problems. It would nice to think that NAD would acknowledge a design flaw, and fix for free, but my amp is 5 year old.
Posted on Sep 25, 2007
  • 42 Answers
Hey,
sounds to me like they have used a chip to switch between the inputs and not relay's?
If that's the problem, only solution is to find someone to replace the chip. Often denon and cambridge use this kind of 'easy' and cheap work around remote controlled input selection.
In several of the nad's i have repaired, they used relays, so i will bee surprised if nad use chips also?.
best regards michael miguelovitch
Posted on Nov 27, 2007
    Novelist:
    Champion:
  • 275 Answers
By mentioning "All inputs are active at all times." are you saying that all INPUTS lights are lit up at the same time? Or is it that you select a particular input option - say TAPE, and while the TAPE indicator Light gets lit, there is no sound coming from the speakers? In most Amplifiers, Input selections are routed through a couple of Relays. So, over time, the contacts of the Relay get dirty and signal does pass across. I suggest that you ask the Tech Store guys to have a look at the Switching Relays, and if suspect, replace.
Posted on Jul 16, 2007
C340. Why do inputs switch to either tuner or tape2 monitor on their own, albeit intermittently?
Probable answer? Dirt..Sometimes you can get poor contacts working again by gently working the switches 50-60 times
with the device off. If this procedure fails Use a good contact
cleaner...
HTH!
Jan 31, 2016 | NAD Audio Players & Recorders
HDMI problems with NAD T758
Yes because HDMI 1 is the only hdmi port on your TV that has ARC. I Believe if you turn down the resolution (the quality of the picture) in the settings on your DVD player it will work on the other hdmi ports. This of course is probably the last thing you want to do. That's technology for you.
Mar 01, 2014 | NAD Audio Players & Recorders
Cracking noise nad c340
Sometimes you can find the faulty part by touching the parts inside the amp. Only touch the plastic parts not any metal parts! As it is on one channel you have a good channel to compare the bad. Often small transitors can become noisy so start with them!
Nov 18, 2012 | NAD C340 Integrated Amplifier
My NAD C320 outputs a very low sound volume
Hi there I have a C340 that has similar problem, you must have bought this from ebay, lol.
Nad made a mistake on the C range, the pre - power link can be shorted out. if the pre is shorted out it takes out the pre amplifier stage, I have managed to get the right channel working, I will keep you informed what is the cause of the left channel. I have replaced the pre-amp IC and a couple of Jfets and transistors. Once I have repaired the Amp I could repaire yours if you like???
Apr 14, 2012 | NAD C320 2-Channel Amplifier
Unsure of connections from nad c340 to power amp, cant get both speakers working
It sounds like you're guessing.
Have you looked at the manual?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-C340-Amps-manual/id/8043dj588/t/2/
Page 7.
Tell us about the source(s) that won
Mar 25, 2011 | NAD C340 Integrated Amplifier
What is the maximum speaker wattage for a NAD c340 integrated amplifier?
The specs say 2x50W into 8 ohms. I could not located the 4 ohm specs, but it is logical to assume that you can run 2x100W into 4 ohms.
The back panel seems to imply that 4 ohms is a limit for speakers.
So any speaker over 100W capability should be fine, either 4 ohms or 8 ohms.
Oct 30, 2009 | NAD C340 Integrated Amplifier
Need a transistor spare part for NAD C340
Odd a transistor would have such a #. No 2Fanything series. It is most likely a 2SA949.... a PNP audio driver transistor.
It can be replaced by a NTE-383 (ECG383) transistor, though it's best to order the original # from a Japanese semiconductor supplier like MCM in Ohio.
It's best brought to a good hi-fi or guitar amp repir shop for a proper go-thru & repair.
Mark S. CET Sr. Dover, NH
Nov 06, 2008 | NAD C340 Integrated Amplifier
Connecting sub with nad c320bee
pre out from nad---------to 2 rca input in sub.
Jul 22, 2008 | NAD C320 2-Channel Amplifier
NAD C340
Hi There,
In a sound system there is an input selector switch which just connects the input socket you want to use to the "common" amplifier electronics inside...You say that the CD is fine so in this case it must be a faulty selector switch or broken copper tracks or wires inside the chassis electronics which connect those inputs.. through the selector switch to the amplifier circuitry.
The fault lies between the selector switch and the input sockets that dont work.....Not the CD one of course... thats fine..
Cheers From YUBEUT
Oct 13, 2007 | NAD C350 2-Channel Amplifier
393 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
