Question about DSC Power Series Lcd5501z 5501z Fixed Msg Lcd Keypad
Lost master code for pwerseries alarm lcd5501z
  • nrap57
    nrap57 Jan 20, 2013
    I previously had a Master Code and for some reason my master code doesn't work. I aam trying how to find the master code or be able to put one in.
How do i fix codes u0141, u1110, u110e on '09 jeep wrangler?
so is car driving perfectly? (other shoe drops)??????
just dash errors, ONLY?
i have a 08 and FULL FSM.
(book and CD)
first off each failure , needs further testing, that is what a ASE tech went to school for 3 years to learn.
here is the list.
1000 codes, I have them in a folder, (extracted with great pain)
141 lost comms with TIPM
1110, lost vehicle speed message.
110e lost ambient temp , message.
the prime DTC error here is 141, lost comes.
once comms are lost there will be lots of related DTC errors.
now to fix that , you need to go to the dealer,
his scan tool an delve deeper here.
Luck happens?
one trick, is to disconnect battery , unplug the TIPM , 5min more more.
then put battery back but (neg battery lug) but this will brick the radio and NAV options, lost radio codes,
we a pro does is get (all this is in the FSM if you read it)
and gets the radio codes and nav codes first.
on a new car its in the glove box, if lost all this is a Royal PITA.
so did you lose your codes.? the card?
my 08 has the cheap radio, with no codes. but the other 4 opted radios do... so....
my jeep has 11 computers, all 11 talk back and forth
some talk all the time to the master. (BCM , PCM and TIPM?)
(CAN-BUS 101) And any master (can be 2 masters) if any fails to here others talking and was expected, it sets a COMM error.
Jul 17, 2014 | 2009 Jeep Wrangler Unlimited X
How do I reset the Master code in DAS NX-4--8 alarm system when the existing Master Code is not known ?
Be sure you understand the difference between a master code and the technician code. A master code lets you program other codes (and do some other harmless stuff). The technician code lets you do anything in the panel. If no master code is known you will need to default the panel. Do that by turning off power and disconnecting the battery. Reconnect the battery or plug pack and within 10 seconds enter 971300 on the code pad. That will wipe the eeprom back to factory defaults, and reinstate user 1 as a master code with a value of 1234. Don't even think of doing any of this without an INSTALLER manual. (Not the same thing as the USER manual). Better still, get an alarm tech familiar with DAS or CADDX products to program it for you. Worth every penny. After that you can add/delete users with your own master code using the much simpler User manual. Any code can be set to be a master code (that is you can have more than one master code)
Jun 25, 2014 | Home Security
How do i change my code on an ademco m6673 without knowing the master code?
How to find the master or installer codes for an Ademco ...
security.livewatch.com/.../how-to-find-the-master-or-installer-codes-for-...
Aug 7, 2009 - ... Ademco ?€?Vista series?€ alarm system and you don?€™t knowwhat the codes are. ... The master code is the main user?€™s regular code, but different than the ... Be advised that an installing alarm company will not and should not... The master code can change or add the other SU?€™s as needed ...
Need to reprogram an ADT/ADEMCO system - DoItYourself.com ...
www.doityourself.com/.../295048-need-reprogram-adt-ademco-system.h...
Feb 17, 2007 - Purhased a condominium 2 years ago with an ADT/ADEMCO system. ... Received no manuals of any kind but MAY have gotten a "Security Code" from seller. ... To change the master code the system needs to be in regular run mode, .... myalarm system was working but i went and acted like Reset Master Code for Ademco 4111XM, Via30+ or VISTA 10 ...
Jul 8, 2007
Ademco vista 20P with FC and Comm. Failure
Nov 8, 2005
More results from www.doityourself.com
[PDF]VISTA-20SE, VISTA-20HWSE User Guide - Honeywell ...
Oct 11, 2013 | Vacuums
I have an ADT security system, the DCS alarm panel lcd5501z panel bypass motion sensors will not reset. The door and window sensors work fine when the alarm is set. but the interior motion sensors stay...
I would power down the main cabinet for 1 min. And unplug the battery in the cabinet. Most of the time this cabinet ( panel ) is located in a closet and contains the main brains of the system. Sometimes there is also a reset on the motion but when used, it can put the motion in test mode. You can also check the batteries in the motion ( if its wireless) The first thing I would do is power down everything and disconnect the battery. This resets and works 90% of the time. You might need the key to get into the box.
Sep 06, 2013 | DSC Power Series Lcd5501z 5501z Fixed Msg...
How to reset master code on adt alarm system without original master code
try 1234,just for kicks and giggles. if that does not work, I need to know system type.
Dec 01, 2012 | Home Security
MY ALARM SYSTEM KEEP BEEPING UNCONTROLABLY..ADEMCO ALARM
Resetting Your Installer Code
1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process.
Resetting Your Master Code
2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
Read more: Ademco Alarm Resetting Instructions ' eHow.com http://www.ehow.com/way_5752912_ademco-alarm-resetting-instructions.html#ixzz3pC2j96jl
Feb 04, 2011 | Audio Players & Recorders
Need to change alarm code on ademco alarm ststem
We need more information. The answer is different for different models and Ademco has dozens of models. Tell us the model of your control panel, usually on the inside of the panel cabinet door) and we can help you.
Oct 04, 2010 | Ademco 1 Wave 2 Alarm Indoor Siren Vista...
Changing the alarm code on the gaurdtec 500 series alarm
For a guardtec 593
Programming User Codes
(Master code only)
system.
1) With the display showing ' Un ' enter a Master code
2) The display will show ' SE '
3) Press NO five times, the display will show ' Uc ' (flashing).
4) Press YES, the display will show ' U- '
5) Enter the User number you wish to program (1 to 7) followed by YES
6) The display will show ' Co ' Enter the required code (4, 5 or 6 digits) followed
by YES. (Entering 000000 will delete an existing code).
7) The display will show ' t- ' enter the code type from the following list
1 = Set Only 2 = Main User 3 = User 4 = Master followed
by YES. A full description of code types is given on page 3.
8) The display will show ' Uc ' (flashing)
If you wish to program other User codes return to step 4
Or
To return to the Unset condition press 0
this is for the led version.
Aug 27, 2010 | House Brand Intrud Alert House Home Alarm...
Master code setting couldn't do it (alarm system ADEMCO VISTA-10)
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Jun 14, 2009 | Eagle SeaChamp 1000c Recording Sonar...
DSC Power Series Lcd5501z 5501z Fixed Msg Lcd Keypad Logo
77 people viewed this question
Top DSC Home Security Experts
Steve
yobo007
yobo007
don1956
Level 1 Expert
Are you a DSC Home Security Expert? Answer questions, earn points and help others
