Question about Gateway Computers & Internet
Gateway laptop mouse jumps
When I use the built in mouse, it jumps to another area and I can't control.
  • 26 Answers
Could be mouse pad, drivers or spyware. Try usb mouse and see if it works okay.
Posted on May 19, 2014
My cursor on my computer jumps all over the page
You mouse is defective. If using a separate mouse (not the built-in laptop mouse), try changing the batteries and cleaning around the mouse light or ball. Also, try a different mouse. Check to make sure you have not unintentionally changed the mouse control settings.
Apr 03, 2016 | Dell Computers & Internet
Gateway HDMI laptop T series charger output 19 vgets v.hotbut works . burser pointer starts jumping frm place to place on screen dificult to control ?
run it in battery to see if fixes cursor problem
also try a different mouse see if that makes the cursor move correctly
this way you see if its the mouse or power supply
might also a touch pad problem anything that controls the cursor
May 07, 2015 | Gateway Computers & Internet
My cursor jumps all of the page when I'm typing on my Gateway NV76R45u laptop. what am I doing?
I was having a similar issue with my laptop. What I found was while I was typing, my thumbs were close enough to the "Touch Pad" to move the curser. You can decrease the sensitivity or disable the touch pad (which I do when the external mouse is connected) Let me know if this helps.
Dec 05, 2014 | Gateway Computers & Internet
Keyboard/mouse
Hello Allison,
I think you do have a bad ground. when the mouse act eratic, it might be because of a mission ground, that can happen when you take some screws out and you do not put them back. something else you can try is to go to the control panel, click on mouse, and change the pointer speed, that will give you more control, an another quick fix can be done easily by using a USB external mouse. let me know if i can be of further help.
Tony
Feb 09, 2013 | Computers & Internet
Gateway Laptop with windows 8. Mouse pointer gone and won't come back
See if the mouse pad has been accidentally turned off. This can be done via the "Function" button on your Gateway laptop. To enable your mouse clicker again on your Gateway, head on over to the "Control Menu" in Windows and double-click on the "Control Panel" icon. Click on the "Mouse" option under the "Printers and Other Hardwareicon1.png" tab. In the next menu that pops up, click on the tab listed as "Device Settings." From this menu, you should be able to locate a listing for the mouse pad on your Gateway laptop. Click on this listing. From here, you should be able to enable the mouse again. Click "OK."
  • Head over to the official Gateway site online (see Resources). The above enabling of the mouse device under "Device Settings" may not have worked. Make your way to the "Software and Drivers" area of the site.
  • Check over your Gateway manual and find your specific serial number for your machine. Enter the number into the Gateway site when prompted and check to see if any driver updates exist for your mouse on your machine. If so, click to download the update, and then double-click the file on your computericon1.png to install it. Restart your Gateway laptop to have the changes take place. Your mouse should now work.
  • Jan 26, 2013 | Gateway Ne56r34u 15.6inch Laptop Black
    Hello I'm using a hp compact nc6320 and my sensor
    Do you use an external mouse or the built in touchpad/pointing stick? If you use an external mouse try another and see if the random movement disappears.
    If you are using the touchpad/pointing stick for day to day use, plug in a mouse if you have one spare, go to the control panel in whatever version of MS Windows the laptop is running and do the following:Start Button > control panel > mouse (goto the hardware tab on the window that opens) choose the 'synaptics' device > properties > driver > choose 'disable' then ok. This should disable the touchpad if the random jumping stops then it is probably a physical problem with the touchpad/pointing stick, you may want to contact HP and request a repair.
    Link below is to manuals for your laptop model:
    http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=135&prodTypeId=321957&prodSeriesId=1839146
    Good Luck
    Jan 10, 2013 | Computers & Internet
    Cq60 frozen mouse pad
    Since you don't seem to want to help us in helping you, by being more detailed about your mouse, or mouse pad, problem, I will give you some general advice:
    - This is a laptop, yes?
    - It has one of those little areas where you can use your finger, instead of a mouse?
    - Look in Device Manager, or even in the Mouse option in Control Panel, and see if you have a mouse configured for your laptop, in addition to the built-in finger pad for use as a mouse.
    - If you find there are two separate devices, one for the laptop-supplied mouse square, or rectangle, with the buttons on the bottom, for use instead of a mouse, and one for an external mouse, then make sure you have designated the built-in pad for use as a mouse. If, however, you want to use an external mouse, then you do the opposite, and ensure that the external mouse is selected as the device you wish to use for a mouse, and disable the built-in mouse/finger pad software, so that you do not have a conflict.
    One or the other must be primary, and the one not primary must be disabled, or your laptop must be told not to use that other one.
    Apparently - again, because you gave us absolutely no details - there is a hardware conflict and the laptop doesn't know which device to use, so it is not using either, and you're stuck without the benefit of any pointing device.
    All the work you need to do with device manager and control panel must be done with keystrokes, and for that you must use Windows' Help to learn which keys will do what. Usually the four arrow keys, near the numeric pad, along with Page Up and Page Down, and the Tab button, or Shift+Tab, to go backwards, are all you might need to reset things the way they need to be set.
    I hope you understand that absent any details at all, the only advice you will get from anyone here, is going to be educated guesswork.
    Best of luck to you.
    Cheers!
    -a.
    Jun 16, 2012 | Compaq Presario CQ60215DX PC Notebook
    Is there a way to disable jus the side scroll bar on my gateway laptop touchpad without disabling the mouse itself? on my touchpad if my hand jus gets in front of the touchpad it scrolls and makes my...
    yes. its in the control panel under mouse properties. Look for the advanced properties, theres alot of settings you can change there for the touch pad. There might be a link to the program in the start menu too.
    May 15, 2011 | Gateway Keyboard/Mouse
    Wireless Mouse on a laptop with built inTouchpad on the keyboard
    No need to disable the touchpad they should both work at the same time. Have you tried both the mice on another PC?. The first mouse should have the correct software already installed but you will most probably need to install software for the microsoft mouse. I hope you have tried resetting by hitting the button on the receiver then while its flashing the button on bottom of the mouse? If all this fails do have any other USB devices you can test on laptop?......good luck
    PS I hope its not the batteries
    Oct 31, 2009 | Microsoft Wireless Notebook Optical Mouse...
    Laptop dead mouse
    go to www.gateway.com and see if there are updates for that kind of mouse or drivers is what you need to look for
    hope this helps
    tazman
    Jul 20, 2008 | Computers & Internet
    Computers & Internet Logo
    47 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
