Question about Kodak ESP Office 2170 All-in-One Printer
Kodak office 2170 won't print on envelopes
I can copy or print but won't print on envelope
5 Suggested Answers
ohms
  • 1879 Answers
SOURCE: why cant i print envelopes
Well that depends, additional info would be great.
Here's an example:
PRINTING ENVELOPES from Microsoft Word
The envelope should be fed into the printer using the short side, all the way to the right, flap to the back and to the left.
Please follow the steps below to print envelopes in Microsoft Word:
1. Open Microsoft Word.
2. Click on TOOLS, then ENVELOPES AND LABELS.
3. Ensure the ENVELOPES tab is selected. Click on the OPTIONS button.
4. Select your envelope size under ENVELOPE OPTIONS (ie: #10).
5. Select PRINT OPTIONS.
6. Under FEED METHOD, from the six options available select the FOURTH icon from the left. Select FACE UP.
7. Ensure CLOCKWISE ROTATION is selected.
8. Under ENVELOPE OPTIONS, ensure you choose the correct envelope size (ie: #10).
9. Click OK, then PRINT.
The envelopes should print correctly now.
Posted on Sep 11, 2008
SOURCE: Owners manual for kodak 5300 printer
my inks are both full but it will not print out black and the color is faded
Posted on Mar 18, 2009
ghassun
  • 499 Answers
SOURCE: how do I print envelopes
it's easy man u can change ur printing area by go to ur printer in control pannel then check its properties then change ur paper type to "Letter" instead of "A4"
Posted on Jun 12, 2009
  • 742 Answers
SOURCE: How do I print envelopes? It just jams when I
when you load the envelop, you should make sure that you adjusted the tray to lock the envelopes in place, or otherwise, they will move and cause a jam
Posted on Sep 22, 2009
Testimonial: "This was very helpful. Thank you so much!"
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
How do i address envelopes on my lenovo Windows 7 computer
The simplest method of addressing envelopes is to use a word processing application such as Microsoft Word.
If you do not have Word then I would recommend downloading and installing a copy of Kingsoft Office Suite Free 2012 which is compatible with the latest versions of Microsoft Office documents and is free for home users.
Once the application is installed, open Kingsoft Writer 2012 (which is very similar to Microsoft Word).
Click on File then on Page Setup and select the Paper page tab where you can then choose the Paper size to use for your envelopes.
In the Paper size drop down selection listing, choose an envelope size such as C6 Env.
If you are unsure which option to choose, then simply measure the size of the envelopes you are wanting to print on and set the Width and Height values (in centimetres) to match that size.
Next switch back to the Margins page and select the Orientation that you want to use for your envelopes, i.e. Landscape or Portrait.
On this same page you can also increase the Margins to position your address text more centrally on the envelope.
Click on OK to exit Page Setup.
Type your address on the main Kingsoft Writer page and you are ready to print the envelope on your printer.
Kingsoft Writer can also use Mail Merge to write a series of addresses on a stack of envelopes if you need to write a number of addresses.
Simply create a list of your addresses in the Kingsoft Spreadsheets application, putting each 'address field' in a separate 'box' in the new spreadsheet so that you have a column each of 'Names', 'Address line 1', Address line 2, Town, County, Post code etc.
Then in Writer, click on Tools, Mail Merge toolbar, then in the toolbar, click on the left icon to Select Data Source and select your addresses spreadsheet document.
Next, click on the icon for Insert Merge Field and select all the address fields to insert into your new Envelope document.
Finally, adjust the layout of the fields by moving fields on to new lines as needed. You can also change the font and character size of the new address fields to make the text larger or bolder etc.
Last of all, click on the icon for View Merged Data which will show you what your addresses will look like when printed on the envelopes - you can step through the list of addresses using the controls in the toolbar.
Dec 23, 2011 | Lenovo Computers & Internet
Can you print address on envleope
Yes you can print an address on an envelope. Do you have Microsoft Office? If so, click on new office document and click the tab that says Letters & faxes (for versions before 2007) and choose the label wizard. When the window opens, click the tab that says envelope instead of label and follow the prompts to type in the information you want to print on yoru envelope.
If you have Office 2007 - or newer, click on new office document and then choose blank document. Click on the tab at the top that says mailings and then choose envelope and type in the information you want to print on your envelope. Then click on file, and print. You will need to load your envelopes in the printers tray and put them in the correct direction according to the settings your machine requires. You might need to waste a few envleopes until you get it right.
Oct 22, 2011 | HP Photosmart C5280 InkJet Printer
If you have MS Office 2007, there's an option there to print envelopes in MS Word. Just Click on the Mailings tab, click on Envelopes, and type the delivery and return addresses. You can also change layout and other print options there. I'm not sure if this is available for earlier versions of MS Office but most likely it is available on later versions.
Aug 05, 2011 | Office Equipment & Supplies
I have an HPPhotosmart C5280. I want to print on an evelope 8.2 x 5.5 for a wedding invitation. The printer tells me paper mismatch every time I try it. I set it up every time on the computer, it prints...
The easiest way to print an envelope is to use Microsoft Word. If you have the software installed, go to start and then create new office document and click blank document. When the document opens, click on help and type in envelope. This will give you instructions on how to create an envelope and save a copy to your document. When you save a copy to your document, it gives you a picture of an envelope which helps to create it. Then click on file, and slide down the print and click ok. Creating the envelope through Word helps to change the printers paper settings. Word will send a signal to the printer to tell it what type of paper and size of envelope you are creating.
Hope this helps?
Jul 18, 2011 | HP Photosmart C5280 Printer
My hp J4680 won't feed envelopes, the envelopes goes part of the way in and then fails to print
Hi
The envelopes are standard in size hence do not use any odd sizes. And also do remember that you make the required alignment and also the feeding directions and positions. If you print in Landscape then the paper is too short for the printer to pick. Hence use Portrait so your printer can sense the presence of the envelope
Jul 16, 2011 | HP J4680 Office Jet All-In-One Printer
Trouble printing envelopes on kodak esp3 printer
Have you tried this procedure?
Loading Envelopes
You can load plain envelopes into the paper tray of your Kodak ESP 3 All-in-One printer.
Important Do not use envelopes with cutouts or cellophane windows.
1 Remove any other paper from the paper tray.
2 Insert one or more envelopes into the right side of the paper tray with the print side down and
the envelope flaps on the right, pointing left.
3 Squeeze the paper-width guide and move it to its right-most position up against the envelopes.
4 Leave the paper tray open while the envelopes are loaded.
If you have and it's not printing correctly, there is probably a problem with the document you're trying to print.
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Why cant i print envelopes
Here's an example:
Sep 11, 2008 | Kodak Office Equipment & Supplies
Kodak ESP Office 2170 All-in-One Printer Logo
89 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
