Question about Keurig B60 Coffee Maker
Keurig b60 hook up to direct water line - Keurig B60 Coffee Maker
SOURCE: New Keurig B60 stopped working!
I had the same issue. I now believe that there was some "vapor lock" type issue. Mine would say the same thing, and i could hear the pump running, but the water level was not changing in the reservoir. I unplugged it, removed the reservoir, let it cool, then tipped it on its back for a few minutes, then on each side. Truthfully I was trying to see if there was some kink in the tubing. Couldn't find a problem, so set it back up and it runs great again.
Posted on Jan 02, 2010
  • 12 Answers
SOURCE: keurig b60 coffe maker will not do anything.
These brewers are defective & Keurig is replacing them with new units @ no cost. Just call the toll free # (866-901-2739) & they will ship out a replacement in 3 to 10 business days. I own (2) of the B77's & they have both been replaced. Even if not the above mentioned model, call them anyway & see what they will do for you......
Posted on Feb 15, 2010
  • 10865 Answers
SOURCE: The brewcover on my Keurig B60 broke. Both screw
Hi. go to keurig.com/parts and order what u need. J.
Posted on Jul 25, 2010
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
  • 3 Answers
SOURCE: my k cup reusable coffee
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
Posted on Dec 31, 2010
Why is my keurig 560 leaking water from the base
Most likely the water lines inside your unit are leaking. If you can take the bottom of B60 off and look inside the unit. Usually, the line that comes off the water pump is leaking at the T connector. If not leaking there look for other signs of leaking while the bottom is off. You can call Keurig 800 number to see if your unit is still under warrenty. Hope this helps.
May 28, 2014 | Keurig B60 Coffee Maker
Haven't used our b60 for a few months. It comes on for awhile then shuts off, it never says "ready"
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 17, 2011 | Keurig B60 Coffee Maker
My B60 keeps on flashing not ready and non of the buttons works the only way to stop flashing is to pull the cord out!!! What should i do?
heatman101
Sep 08, 2011 | Keurig Special Edition B60 Coffee Maker
Water light malfunction
heatman101
Jul 10, 2011 | Keurig B60 Coffee Maker
I have a Keurig B60 and it is making a loud noise that sounds like a fog horn when it is brewing. Can I make this stop or lessen?
heatman101
May 27, 2011 | Keurig B60 Coffee Maker
My Keurig B60 stopped pumping water, the pump runs for 45 seconds and the pot then turns off. Any idea's on how to fix this would be greatly appreciated.
you can try contacting Keurig directly and see if they will honor the warranty, if that doesnt work i know of this great website that sells all kinds of keurig products for very cheap.http://stores.ilikenew.com
Jan 30, 2011 | Keurig B60 Coffee Maker
The Keurig B200 primes several times a day and the process takes between 3 and 4 minutes to complete. Is this normal and if not, what do I do about it?
This absolutely not normal. Are you directly hooked up to the water? One possibility is if the machine is shut off when it is turned back on it asks if it has been emptied...if you answer yes by pressing the large cup then it will go through the priming process.
Oct 27, 2010 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
198 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
