Question about IBM ThinkPad R51 Notebook
Thinkpad R51 will not boot
Today my Thinkpad R51 will not boot. Was fine yesterday. Start up process starts, Battery and Start lights come on, fan starts, Hard disk access light comes on briefly then stops. Then nothing further happens. Anyone any ideas to help?
  • IBM Master
  • 7,627 Answers
Try remove ALL media DVD.CD,USB,etc. Shut down, unplug, remove battery, plug in, reboot. Do you get anything on the monitor? Can you access the restore/recovery software? Open the Memory bay and reseat the Memory, open the HDD bay reseat the HDD, Reboot. If no change remove HDD, test, replace if necessary. Have you changed the CMOS battery?,
Posted on Jan 18, 2013
  • 107 Answers
SOURCE: Ibm lenovo R51
have you check the temperature of your laptop. try 2 check on it through your bios. certain features of bios restarts itself when temp is to high to avoid from burning internal components
Posted on Feb 16, 2009
Geekman
  • 32281 Answers
SOURCE: My ibm thinkpad r51 is not starting up just
It appears the hard drive is faulty.
Does the hard disk LED flash when the laptop boots up?
Go into the BIOS configuration and see it the hard drive is detected, (then Startup - Boot - and look at IDE HDD0 it should list the make and model of the hard drive).
If the hard disk is detected it still could be faulty. To test the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port.
If the computer sees this as an external hard drive and you can open the various folders and files then the hard drive is OK and the fault could be the disk controller on the laptop's motherboard.
If the hard disk is not detected the it is faulty and you need to replace the hard drive in the laptop and install Windows etc. to get it working again.
Posted on Jul 15, 2009
  • 51 Answers
SOURCE: when starting the computer it does not boot up
Yes you are right it sounds like a power problem. I know for sure that desktop computers still can calculate time even when not in use for several days. They have an internal power supply charged from the time it's plugged in. I'm not sure that the laptop would be the same but it very well could be. So I would suggest to fully use up the battery power and leave the machine disconnected from the wall for about one week. That way there should be no internal power at all left in the machine. Then see if there is any improvement. However, before you do this one week marathon, see if the machine boots from CD or floppy because if it does then it could be a malware or OS problem in which case you will need to do a repair install of the OS. But it's unlikely. If it still won't work even after you try the power depletion, then I'd suggest to contact IBM, tell them everything you tried and see if there is any possibility for a replacement part. If any of my suggestions help, please do rate me. Thanks and good luck. Hope it all goes well for you.
Posted on Feb 13, 2010
SOURCE: will not start up no flashing hard disk light
not quite sure what the fault is yet as still looking into it, but i have read and tried this and it worked for me..(remove the battery completley and just run from mains). quite poss there is an issue with the battery.
Posted on Feb 27, 2010
elix0411
  • 3530 Answers
SOURCE: I have an IBM ThinkPad
Welcome to Fixya
Tryo to perform a power drain first. Take out the battery then unplug to power adapter from the computer. Press and hol the power butron for 30 secs. Put everything back in then turn on the computer. If still no display, you may try using an external monitor just to make sure that this is not a LCD problem.
Thank you for using Fixya!
Posted on Dec 03, 2010
Blank screen after start up
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sep 09, 2012 | IBM ThinkPad R51 Notebook
I would like to format my IBM thinkpad R51. kindly let me know which function key I need to use for it to be formatted and I can get it restored back to factory settings.
HI,
Wait for the ThinkPad logo to appear on the screen a few seconds after the boot process begins. Press the "F1" key on your keyboard and you will get access to bios.
Nov 02, 2010 | IBM ThinkPad R51 Notebook
Today when I was using my IBM Thinkpad R51 the screen went black and the machine shut itself down. It restarted normally but after about 20 minutes did the same thing. I never got a warning or any kind...
your battery could be failing,thats the most obvious thing.Then you might have accidentaly set the sleep mode,if you have this facility in your software(most pc's do).you must just search through your soft to see if you have enabled this function--good luck!
Davey Snake!
Oct 24, 2010 | IBM ThinkPad R51 Notebook
Will not start up no flashing hard disk light
Sep 20, 2009 | IBM ThinkPad R51 Notebook
My ibm thinkpad r51 is not starting up just keeping giving me error message and it doesn't recognize the hard drive in boot. I have to take the battery to stop the system trying restart the window again...
Jul 15, 2009 | IBM ThinkPad R51 Notebook
IBM Thinkpad T30 wont boot up
You have faulty RAM modules. Reseat your RAM modules, to make sure they make proper connection. If this doesn't work take them to your friendly computer shop and ask them to test them for you.
Apr 29, 2009 | Lenovo ThinkPad R51
IBM R51 Laptop cannot be turned on anymore
does your hard drive have a "caddy" or "drive sled" installed? Mine did the same until I bought one.
Dec 19, 2008 | IBM ThinkPad R51 Notebook
T30 still won't boot after fan replacement
One of your memory slots might be bad as I'm assuming you tried both memory chips in the known working slot.
I found setting the boot up sequence in BIOS is better than using F12.
Set your BIOS to boot the CDROM first. I suspect the hard drive has failed or has a problem. Do you have a floppy boot disk? Lenovo has PCDoctor bootable diagnostics on their website. You may have inadvertently bent a pin inserting the hard drive. Your CMOS battery could be dead but since that was untouched I would be surprised.
Sep 08, 2008 | IBM ThinkPad T30 2366 Notebook
Unable to restore OS in IBM-R51
after the booting oftions boot to c: hard drive.. press F8..
Mar 24, 2008 | IBM ThinkPad R51 Notebook
Thinkpad R51 Blue screen
First:
does this also happen in safe mode boot. (press F8 just before windows boots). If not then go to your event viewer and check the messages at the specific time,hour messages. for example. computer booted at 23:30. in windows around 23:31:10 and then blue screen. Go to safe mode. and look in the logs what registered at 32:31:10(around this time).
If not possible to boot in safe mode. Try to remove one of the 2 memory dimm(if you have 2). so you boot with 1. maybe 1 of them doesn't work good anymore.
Nov 30, 2007 | IBM ThinkPad R51 Notebook
IBM ThinkPad R51 Notebook Logo
179 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
