Question about Samsung RS2630WW Side by Side Refrigerator
Fidge and freezer will not stay cold - Samsung RS2630WW Side by Side Refrigerator
    New Friend:
Anytime you put a question out there concerning technical issues, the more information the better. There are always signs that tell you what is going on if you know what to look for.
The first thing I do is listen to hear if the compressor comes on.
Next I check for fan operation inside.
Then I check for ice on the back wall of the freezer side of the fridge. (FYI: almost all but high-end fridges are cooled by the freezer side evaporator only).
if your fan has a good flow of air over it and there is ice on the back wall it will more then likely be the defrost timer or defrost heater (there is also a thermostat in line with the heater that can fault as well). I change both the heater and the timer because they have about the same life span.
If your condenser coil is dirty it will not cool correctly, and can kill the compressor pretty quick.
Anything with a mother board should be checked by a technician unless you have a full understanding of wire diagrams and electrical skills.
Posted on Jan 18, 2013
Fidge has frozen up . the back wall is solid ice
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 24, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Fidge is warm but freezer ok Kelvinator c 500 c r cyclic
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Refrigerators
Fidge is not getting cold wot temperature is it suppose to be set at
heatman101
Sep 01, 2011 | Prestige Appliances PRT295FFCS (9.3 cu....
Side by side refrigerator/freezer. Refrigerator warm but freezer is cold and Ice maker works well.
evaporator iced up so air cant circulate to fidge compartment... either defrost heater blown.... or air circulation fan caput... maybe seal around freezer door not very good so excess moisture getting inside...
Feb 06, 2011 | Maytag Refrigerators
Fidge in not cold.
check the bottom vent for ice build up. if there is no ice build up at either vents check the gasket on the fridge door masking sure there are no gaps when closed
Jul 24, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side be side freezer works fidge not
It is either a problem with your defrost cycle, or timer, or it is the damper, for some reason froze in position. Hope this helps
Sep 12, 2009 | Kenmore 57029 Side by Side Refrigerator
Samsung fridge freezer
there is a shaft from freezer to fridge that the cold air travels. make sure that is unblocked. also make sure the fan is working. then see if the freezer coils are iced up (this restricts air flow). if they are, unplug it, empty the fridge and freezer, defrost the coils, dry it out, plug it in and turn it on (not high). once it reaches the temp and the compressor stops, fill the fridge again.
Jul 30, 2009 | Samsung RB215LASH
Fidge freezer is not working properly
Get british gas homecare cover for heating and appliances, don't tell 'em the freezer isn't working, then a month later report it as a fault, they'll fix it. Unscrupulous i know but what can ya do? Otherwise get a hotpoint engineer, sign up for their maintenance plan.
Apr 04, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint future RFA60 Fidge Freezer
I have lost the instruction booklet for my Fridge Freezer RFA60. How do I defrost the freezer?
Nov 04, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Samsung RS2630WW Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
