Question about DeLonghi Heating & Cooling
My Delonghi Safe Heat Model TRH0715 Type KH770715P will not heat
Model #TRH0715 Type KH770715P 1500 Watt When plugging and waiting awhile, it will not heat.
SOURCE: Delonghi TRD0715T Safe Heat Oil-Filled Radiator
Ditto same problem. Took it out of the box, plugged it in the electric outlet and did not turn on.
I tried atleast 5 different electric outlets to make sure nothing is wrong with the outlet. Tried changing the timer settings. No use.
Returned it to Lowe's.
Posted on Jan 23, 2008
SOURCE: Delonghi "the incredible heat machine" started smoking
Hi Coyote,
I don't know about your specific heater, but, as someone who has a vast electronics background, things that heat tend to give off some fumes. Many electronic componets are LIGHTLY coated with an oil product to provide humidity protection, while the product may sit in a warehouse for years. Typically, such protection, upon being heated, will disperse in the first (maybe) hour of use. but, it could be more, I guess.
BUT, fumes should never be taken lightly. FUMES SHOULD NEVER BE TAKEN LIGHTLY!!!. FUMES MAY KILL YOU!!
How I handle it is...if the fume is noxious, so as to irritate your nose, or eyes, etc. IT IS BAD!!!
Nevertheless, if I were in your boots, I would take the unit outdoors, and let it run on 'HIGH' for about a 1/2 hour, or so. After it cools down, take it indoors and try it again. If it is still fuming, write the manufacturer a "fuming" letter.
Good Luck,
Papou1
Posted on Feb 10, 2008
buzzwood
  • 65 Answers
SOURCE: Whatever rotates inside is making a lot of noise.
Call Dimplex @ 1-800-668-6663 Ext# 358 These folks will be able to help you.
Posted on Jan 21, 2009
shastalaker7
  • 1515 Answers
SOURCE: Where on the internet can I find the operating
Hi, I will see what I can find for you. As far as writing you back, we here at fixya have polices that are strictly inforced, so any help I can be I will contact you here on this site. I hope that you understand. I will get back to you asap.
Sincerely, Shastalaker7
Posted on Jan 19, 2010
TheMobilian
  • 8220 Answers
SOURCE: i have a patton puh682
Under the main black knob is a bi-metal switch which shuts down the heat at various temps depending on your setting. Their is no timer.
Posted on Sep 21, 2010
Need an owners manual
Many DeLonghi product manuals are available here: http://delonghiusa.com/support/product_manuals . The manual for the TRH0715 is here: http://delonghiusa.com/support/sites/default/files/product_manuals/m-TRH0715.pdf .
I hope this helps.
Nov 02, 2011 | DeLonghi TRH0715 Oil Filled Radiator...
The electric cord on our Duracraft heater model CZ-600 was very hot to the touch (closest to the plug) -- it burned so hot we could not touch it for more than a second. The heat was at maximum and we...
Look carefully at the plug's connectors to see if thewre is any scorching or otherwise burnt metal...electrical connectors tend to get hot due to the plug being loose(this causes more resistance and thus more heating). As a safe bet...the parts aren't expensive...I would replace both the power cord on the heater AND the outlet recepticle
Jan 17, 2011 | Heating & Cooling
The fan is operating on my Model 1500 V portable heater but no heat is coming out. Is there a way to replace the heating element? We are in the Scottsdale, AZ area if you have a service company that...
Most of these heaters are not worth the price of repairing.You will spend more on labor then a new heater will cost. One thing you can try is to shut switch off on the heater and turn the thermostat to high then unplug unit for 10 mins. Plug back in and turn on. Some of these heaters will reset by doing this.It may not help but it costs nothing to try. Hope this helps you. Thanks
Jan 03, 2011 | Del-Rain 1500-V 1500 Watt Ceramic Heater
I have a patton puh682 1500 watt heater and after a while it just seems to turn off is there some kind of timer or heat control?
Sep 21, 2010 | Patton Electric Patton PUH680-U Electric...
Rapid Heat Bath Heater - indicator light on but not heating water
Bathtub heaters will not produce the heat out a the jets like you would feel coming out of a return jet in a swimming pool.
Bathtub heaters will ONLY maintain whatever temperature water you put in there. they only heat 1-2 degrees an hour. that is for a 1500 watt heater. Many heaters today are only 650 watt or perhaps 700 watt.
Feb 21, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Delonghi TRD0715T Safe Heat Oil-Filled Radiator will not work, won't turn on its new just taken out of the box
Nov 17, 2007 | DeLonghi TRD0715T Oil Filled Radiator...
Leaking Oil from the front
DONT BUY A NEW ONE THEY ARE EXPENSIVE ... THEY PUT OUT VERY LITTLE ACTUAL BTU'S OF HEAT ...IT WOULD BE DANGEROUS TO TRY AND BRAZE ANY LEAK POINTS AND THE OIL IS NOT CAR OIL AND NEEDS TO BE FILLED TO FACTORY SPECIFIED LEVELS. (THESE ARE NOT MEANT TO BE RE-FILLED OR DOES THE OIL USUALLY DIASAPATE). OIL HEATERS OF THIS TYPE USE PLENTY OF ELECTRICITY. I SUGGEST A "HIGH QUALITY, THICK CASED, WITH TILT SAFTY, ELECTRIC SPACE HETER WITH A FAN. THEY HEAT PROBLEM AREAS SAFE AND EFFECTIVELY.
Apr 26, 2007 | DeLonghi 9707 Oil Filled Radiator Heater
Heating & Cooling Logo
121 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
