Question about Dell WL6000 Computer Speakers
Rear speaker does not connect
When I press the connect button for my rear speaker, it does not connect to the subwoofer as it should, and therefore no sound comes from it at all. The little blue light just blinks continuously. Please help, this is very frustrating as I'm losing a significant amount of the sound that I paid for with this not functioning.
  • 1 more comment
  • Steven Cash Jul 14, 2007
    None of that has worked... and I've misplaced the manual so I don't have any troubleshooting options either.
    Also, the front speaker which has a blue light as well is not emitting any sound, though it is on and I can control the master volume from it... any ideas on this either?
    I think there's definitely something wrong with the system in general. Though the two smaller speakers and subwoofer have very good quality on their own, it really bothers me considering how much better the experience would be with all of them working..
    Thanks for your help, but I've read that these speakers have been sent back many times for similar reasons so I'm a bit disheartened... continue with any advice you've got, though.
  • Steven Cash Jul 15, 2007
    Thank you very much for that manual. I got them all to work! Only because I didn't realize that I had an audio jack, though, and the manual told me, and by accident while checking my speakers settings I realized it was not set to surround sound.
    For some reason all the speakers only work when I use the audio jack, strange, took a bit of frustrating fiddling with the cords but it finally worked.
    The rear speaker cuts out quite a bit, and makes an annoying popping noise, I've read that this is what it does when a volume level is reached or something? I don't see what I could possibly do about it so whatever, the sound is amazing now.
    Thanks again, very very much.
  • Anonymous Feb 16, 2008
    the system not working fully
  • 432 Answers
I have the manual in front of me. Have you already tried all the troubleshooting steps? Seems like wireless isn't making a good connection. Have you tried moving the speakers around? I know its frustrating, and I want to help you with this.
Posted on Jul 14, 2007
  • Anonymous Jul 15, 2007
    Heres the link to the user support manual. http://support.dell.com/support/edocs/ac...
    I hope this helps
    Let me how it goes Arnold.
    Your welcome Arnold. I'm glad it worked for you. Let me know if I can help you in the future :-)
  • 624 Answers
ArnoldLayne, -Make sure the blue LED on the center speaker is on -Make sure the power switch on the back of the rear speaker is on. -Move the rear speaker to within a few feet with no obstructions (including glass) and try reconnecting again. If you can connect then you have a problem with the distance or an obstruction. If you can?t then it is probably time to call Dell.
SOURCE:
When I hook up the speakers in the back to the left and right side for the in and out, do I connect the front or rear speakers. do the speakers connect to the subwoofer first then to my receiver or the...
I was trying to find an owner's manual or picture of the rear panel of the sub, but had no luck. The subwoofer is a powered type - or "active" speaker. This means it has a built in amplifier. These active subs usually provide for one or both "low level" and "high level" inputs. Low level signals are usually carried by shielded coaxial cables and have RCA type plugs on the end. The low level is also called "line level". This is an un-amplified signal that might be heard on cheap earphones - but that's about it. It is similar to the output of a tape deck, DVD or phonograph. These signals require an amplifier to be heard. If you have a sub woofer output on your receiver or amplifier, you could run a patch cable between the low level input on the subwoofer and the subwoofer output of the amp or receiver. You receiver or amp may call this output "low frequency effects" or similar. The front and rear speakers would then connect directly to the receiver or amp's corresponding connections.
If you lack low level outputs on the amp or subwoofer, you'll need to run speaker wires from the amplifier or receiver's front left and right speaker output terminals to the subwoofer's high level input terminals. High level signals are speaker connections or amplified signals. These are typically connections that accept bare wire connections. The front speakers would then connect to the subwoofer's front left and right speaker output terminals. The rear speakers connect to the amplifier.
I hope this helps - and good luck!
Nov 24, 2010 | Cerwin Vega AVS-632 System
Where do my subwoofer speaker wires get hooked up to on the back of the reciver vsx-815 ??
Hi there, the Pioneer VSX-815 amplifier only feeds out a mono LINE LEVEL output with the subwoofer signal. Therefore you would need to connect the SUB PREOUT jack at the rear of the unit to the "line level input" on a self-powered subwoofer. Hope this helps.. Cheers, Yusuf
Nov 12, 2010 | Pioneer VSX-815-K Receiver
Hello i am rohit i have avh-6850 in my car i want how connect front and rear speaker and subwoofer there only two rc output one is front and other is non-fad & subwoofer tell how to connect front and...
If you only have 2 sets of pre-outs, you will either have to split the fronts into front and rear channels and use the other for a subwoofer signal, or else utilize an equalizer or other preamp that separates out a sub channel. I have an Alpine EQ that I send one stereo pair into, and it sends out front, rear, and sub outs. That allows for front/rear fade, and independent sub level adjustment.
Nov 08, 2010 | Car Audio & Video
How do i connect my 5.1 speakers to my desktop computer
Know Your Speaker SystemGenerally in systems all the cables from the speakers are connected to the subwoofer which comes with a set of wires to connect, that includes : a power cord to connect the system to the AC outlet, a power connector to feed the subwoofer and the subwoofer wires. Your system should come with at least three set of cables for connecting your speaker system to your PC. These cables are usually colored to help with the installation.imageview-thumb.jpg
Start ConnectingYou should connect the cables matching the colors on the jacks located on the subwoofer. After connecting all these cable, its time to connect the rest of the cables like power, subwoofer and speakers. This is very easy if you pay attention to the subwoofer connection then you’d be able to follow the polarity that is written on the connectors. In the end, all your cables would be connected perfectly.
The above pic shows you all the ports to connect the wires to with all the color coded mannerism.
Knowing Your ComputerAll computers have atleast three connectors
  • Line-In.
  • Line-out.
  • Mic.
Computers with six channel audio systems have two more connectors, i.e
  • rear out.
  • center/subwoofer out.
You’ll need to make sure if you have these extra connecters by checking the back side of your computer.
If your computer doesn’t have these two extra outputs: rear out and center/subwoofer out, it’s a disadvantage, you’d be able to connect your 5.1 anyway but you would require to use the line in and mic-in plugs as an alternative. Of course there is a really big disadvantage in using this configuration: you cannot use your microphone or line in inputs and your 5.1 speaker system at the same time. This is the reason that you should buy a motherboard with 5.1 system built in.
Configuration Of Computers With 5.1 Supporting Motherboards
  • Front cable: To Line out.
  • Rear cable: To the Rear-Out
  • Center/Subwoofer cable : To Center/Subwoofer Out.
Configuration Of Computers Without 5.1 Supporting Motherboards
  • Front cable: To Line-out.
  • Rear cable: To Line in.
  • Center/Subwoofer cable: To Mic-in.
Software ConfigurationAfter every single connection has been made, its time to setup audio configuration in operating system. Since we had Realtec drivers on our PC, Double clicking it opened up Speaker Configuration tab. In various options you should select 6 channel mode for 5.1 speaker output and check Only surround-kit if your PC has the separated rear and center/subwoofer outputs and leave it if you don’t.
Now everything is done, you are completely ready to enjoy surround sound experience and don’t forget to leave comments if you find this post useful.
Apr 14, 2010 | Computers & Internet
I cant get the rear speakers to play on my pioneer deh-p3000ib.
Sounds like you have
1) the rear speaker cable is plugged into the wrong colored hole
2) the audio software thinks you have a subwoofer, but you don't? Check on the audio software for ways to configure the speakers, the latest chips auto-detect when you plug in a cable, and ask you what that was you plugged in.
Jan 07, 2009 | Kenwood KDC-MP4028 CD Player
Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Oct 13, 2008 | Pioneer Audio Players & Recorders
4 speakers with games
For the rear surround speakers to work, the sound must be encoded in surround sound, and most games, if any, are not. The amp doesn't 'see' and information encoded in the sound signal for the rear speakers, therefore you get no sound.
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Feb 01, 2008 | Cambridge Soundworks Seventeen Speaker
Cant connect rear speakers
Hey there Subaquakid, the nature of surround systems is to identify separate extra channels of information and send them to the right address, being the selected speaker. In order for the rear speakers to work they need to be sent a signal. The media which you are using may not have the rear channel encoded. therefore the rear speakers have nothing to announce. Please ensure your source cd has the suround feature encoded. Hope this helps. Good Luck!
Jan 28, 2008 | Dell WL6000 Computer Speakers
Rear speaker connection issue
OK, the fix for the missing rear speaker sound on the DELL WL6000 5.1 Surround Speaker System is relatively simple, just 7 simple steps (Verified by Dell at http://support2.jp.dell.com/docs/acc/P121646/multlang/srg/DAO/srg_dao.pdf..
First, power down everything. Second, disconnect the rear speaker and subwoofer from the power source and wait about 5 minutes. Third, be sure the power switch is off on subwoofer and the center speaker. Fourth, plug in the power for the subwoofer but DO NOT turn on the power yet. Fifth, plug in the rear speaker power cord. Sixth, turn on the swtich on the subwoofer (this is the start of the resync mode). Seventh, turn on the center speaker power and the system will change the rear speaker system LED from flashing blue to solid blue in 5-8 seconds. The surround system is functioning again. You may test this under sound in the Control Panel but I would prefer to use a modern music CD that has Dolby Digital Support for 5.1 sound or better. YOU WILL HEAR INSTANTLY THE SOUND DIFFERENCE WHEN THE REAR SPEAKERS ARE CONNECTED.
Nov 10, 2007 | Dell WL6000 Computer Speakers
Dell WL6000 Computer Speakers Logo
310 people viewed this question
Top Dell Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Steve Mason
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
