It's a Rowlett 2WTB-171E 2-slot toaster. It's brand new, I started it up for the first time and it smelled a bit like melting plastic or paint. A bit of smoke came out, both from the holes (ventilation? idk) on the side and from the slots. not much, and nota heavy or blue smoke, but smelly. The second time we turned it on (without bread in it,) it smoked more. It's just a light, white, but smelly smoke. Is it just because it's new, or is something melting inside it?
SOURCE: only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
SOURCE: how can I clean the inside toaster rails
Hi rsands1,
The following link will help you maintain a clean and good toaster,
http://www.pnwb.com/Toaster%20Maintenance%20Parts%20.pdf
Thanks.
SOURCE: Dualit 4-slice toaster (84US) warms only slightly
please check and make sure the red button in front is pressed to the right so that all 4 slots will heat up.
if it is to the left, only the left 2 will heat up.
if you need additional help contact the service center at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
[email protected]
www.electra-craft.com
SOURCE: Only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
SOURCE: My 2 month old 2 slice toaster only toasts one
take it back to the store or send it back to the man. this is a factory defect
