Question about Grandstream GXP2120
My gxp2120 keep on boot loop forever how I interrupt that
I have a gxp2120 phone, wen start the phone don't leave de boot process, how i can interrupt that for changing configuration. Thanks for your answer
Compaq dx2000 mt freezes on startup
Boot into Safe Mode by pressing F8 during boot and...
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 12, 2012 | HP Compaq dx2000 Microtower PC Desktop
Script era on xbox game
Basically the server thinks you are cheating. If you stop laying down claymores and try not using them every round. Or using a bunch of ballistic knives and not picking them up! I'm guessing you're doing the claymore stock up trick. Don't do it!!! I use to do that too, just in case I ran out of ammo, I've got an enormous amount of claymores to use later on. But every time I'd hit round 25-27, me and my teammates would get kicked. The servers think that you're glitching or cheating and boots everyone from the game. Don't do it, and you should be fine. I'm guessing there was a patch to stop players from exploiting the loop hole.
Jun 01, 2012 | Microsoft Xbox Console
Keeps comming up service or script era
Basically the server thinks you are cheating. Stop laying down claymores and try not using them every round. Or using a bunch of ballistic knives and not picking them up! I'm guessing you're doing the claymore stock up trick. Don't do it!!! I use to do that too, just in case I ran out of ammo, I've got an enormous amount of claymores to use later on. But every time I'd hit round 25-27, me and my teammates would get kicked. The servers think that you're glitching or cheating and boots everyone from the game. Don't do it, and you should be fine. I'm guessing there was a patch to stop players from exploiting the loop hole.
Good Luck!
Jun 01, 2012 | Microsoft Xbox 360 Console
How too start my computer wen the power is interrupted
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 01, 2012 | Compaq Computers & Internet
Acer Aspire 5535 Black screen not working at all. I turn it on and it sounds like its running normally but the screen stays black and eventually the fan gets more quiet than usual. Once starting it up, it...
3-1-1Slave DMA register failureThe DMA controller has failed. Replace the controller if possible3-1-2Master DMA register failureThe DMA controller had failed. Replace the controller if possible3-1-3Master interrupt mask register failureThe interrupt controller IC has failed3-1-4Slave interrupt mask register failureThe interrupt controller IC has failed3-2-2Interrupt vector errorThe BIOS was unable to load the interrupt vectors into memory. Replace the motherboard3-2-3Reserved 3-2-4Keyboard controller failureThe keyboard controller has failed. Replace the IC if possible3-3-1CMOS RAM power badReplace the CMOS battery or CMOS RAM if possible3-3-2CMOS configuration errorThe CMOS configuration has failed. Restore the configuration or replace the battery if possible3-3-3Reserved 3-3-4Video memory failureThere is a problem with the video memory. Replace the video adapter if possible3-4-1Video initialization failureThere is a problem with the video adapter. Reseat the adapter or replace the adapter if possible
^^ those are the beep codes, they are found here: http://www.bioscentral.com/beepcodes/phoenixbeep.htm# i assume they are using phoenix bios. you may want to boot it again and pay close attention to the time inbetween beeps so you can accurately diagnose the problem. there is a way to force a bios flash, you'll have to download the bios on a second computer. go here: http://goebelmeier.de/bootstick/ download the program and follow the instructions. boot to your flash drive by tapping f12 at boot, select usb drive and dos will load. once it loads follow the instructions in the previous web address. good luck!
Oct 06, 2011 | Acer Aspire 5535-5050 Notebook
My phone has a black screen, it doesnt show the nokia logo when turned on. what shall I do? please help
Hi bro....don't take tension, i just faced the same problem n get rid of it. You need to do as: It is just processing fault during booting on start up. Just press switch on button for some time and then leave it as for about 20 minute without pressing any other key, it will surely switched on.
Jul 22, 2011 | Nokia E63 Cell Phone
Can anybody help how to flash bios into a acer aspire 3680 using the usb?
Even with the automated (windows-based) BIOS updating software, this is not a small matter. I would make certain that you need the update for a specific problem before proceeding. Also realize that a failed or interrupted BIOS update may ruin the BIOS chip resulting in a much more costly and difficult repair. Don't jump into any BIOS update without doing your homework, making sure it's necessary, and make sure you get the correct BIOS for your PC. And make sure you don't interrupt the power once it starts! That will brick your computer for sure!
Jun 29, 2011 | Acer Aspire 3680 PC Notebook
Trying to recover from acer restore cds but keeps coming up with the above eror number and telling me to restart computer
Hello
Can you read the that recovery disk in another computer/laptop? If yes,put the CD into the tray When you boot your system hit f12, then select your USB cdrom, and it should boot then.
If no,you have to check the BIOS settings to ensure that "CD-ROM Drive" is set as the first boot device, otherwise the PC will ignore the disc.
press F2 at the acer splash-screen during the boot process, or when you see "Press F2 to enter setup" at the bottom of the screen.
On the main BIOS screen there is a menu along the top.
Use arrow key to highlight 'BOOT' in the menu bar.
Now you see "Boot Priority Order"
Yours probably has "IDE 0" as first boot device,
and "CD/DVD as second boot device.
The first boot device (IDE 0) is already highlighted.
Press 'F6' to swap them round, so that first boot device is
"CD/DVD"
Now press 'F10'
Highlight "YES" at the prompt (may already be highlighted) and press <Enter>
PC will reboot, this time from the CD/DVD drive first.
You can leave the BIOS set like that permanently so you don't have to go through all that process again next time, just don't leave a bootable disc in the drive unless you really want to boot from it.
Apr 12, 2011 | Computers & Internet
Samsung P520 ARMANI Cellular Phone armani phone won t start
i got the phone of ebay its a copy from china ive only had a week and wen i go 2 charg it sum times it will and other times it wont but even wen i try and turn it on it comes on for 3 seconds then goes strait off
Oct 07, 2008 | Samsung P520 ARMANI Cellular Phone
Grandstream GXP2120 Logo
418 people viewed this question
Top Grandstream Computers & Internet Experts
David Payne
David Payne
Are you a Grandstream Computer and Internet Expert? Answer questions, earn points and help others
