I have just had a IWC6125 washing machine plumbed in and put what I thought was a normal programme on. That was a few hours. So far nothing has happened but the 3 hour delay is flashing? Can I cancel this and restart
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Yes you can
Posted on Jan 18, 2013
Why does belt keep coming off when spinning?
Sadly, this is almost certainly drum bearings worn out and the drum spins off centre, causing the belt to come adrift (I'm guessing your spin cycle has become significantly noisier recently). Worse news I'm afraid, the IWC6125 uses a sealed, non serviceable drum, so this is really an uneconomical repair that will cost around 60%-75% of the cost of the machine when new
Sep 06, 2015 | Indesit IWC6125 Front Load Washing Machine
Bosch classixx 1400 express
have you cleared the filter
Feb 03, 2014 | Washing Machines
Polaris won't stop spinning/display screen black
TRY TO USE DIFFERENT PROGRAMM, BECAUSE SOMETIMES THE PROGRAMM GET STUCK ON ONE.
Jan 20, 2014 | Miele Washing Machines
Hi, recently bought a bush a126q washing machine, worked perfectly fine after 2 washes. However, firstly the programme starter light doesn't stay on throughout the wash, is this a problem? Then the washing...
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board. It's like rebooting your computer. I did this to mine and it cleared up the problem.
Oct 16, 2013 | Washing Machines
Dishwasher leaves baked on soap scum on al dishes and everything ....even on the dishwasher ...tried all kinds of soap and rinse aid...nothing works...cleaned entire washer out cleaned all filters...
I imagine you've already checked that you're using the correct amount of detergent for the wash programme, and that you're washing the correct quantity of dishes for the wash programme, though if not, try that first!
Is the dishwasher heating the water to the correct temperature? If it's not rinsing at a hot enough temperature, the detergent may leave a residue. In that case, your dishes would probably also be less than entirely clean; they could be slightly greasy when removed from the machine.
Another possibility is that insufficient water is supplied to the dishwasher, so it might be worth checking the tap that lets water through the hose and into the machine. Does the tap turn on fully? Does it turn off properly?
The other thing that might be worth trying is an empty wash: put the machine through a wash programme WITH detergent but WITHOUT dishes, at the programme with the highest temperature. Is all the soap scum washed away? Or is there still a residue inside the machine? If the empty wash works, you probably need to give your machine a maintenance wash once a month or so. This is often the case if you usually wash your dishes a few at a time on a short programme.
I hope some of that helps. Good luck!
Oct 09, 2010 | Bosch Dishwashers
Got this washer yrs ago..never used. Just hooked it up & want to run a bleach cycle to clean out so I can wash clothes after. What do I do?
A simple way to put a cleaning cycle through the machine is to fill to the highest capacity with warm to hot water and add a cup or two of bleach. Any bleach is ok, but chlorine bleach if your plumbing type allows it is stronger. TIP.....Do NOT mix any wash powder or detergent with the bleach (Check Directions)
Let the machine do it's longest wash, with soak, if it's part of the programme, and after a normal rinse you should be good to go!
Good luck....Nomess
Sep 07, 2010 | Maytag Neptune MAH55FL Front Load Washer
Bosch WF2001 washes only 30 degrees programmes
We had this problem and it turned out in our case that the hot water inlet filter was blocked. The pump wasn't receiving any hot water into the machine so wouldn't start on anything except a cold (30degree) wash.
We turned off the the hot water tap on the plumbing at the back, disconnected the inlet pipe from the machine, then put the end of the pipe in a bucket and turned the water back on, and saw loads of sediment spurted out.
We ran it until we'd filled the bucket, then turned the tap off, emptied the bucket down the drain, then disconnected the hose from the plumbing and cleaned the hose separately (there's a gauze at the plumbing end of the hose so make sure that's clean).
Then get some pliers and where the hose attatches to the machine there's a filter that you can pull out. Clean this out. In our case this was completely blocked with limescale sediment etc.
Reconnect everything, check it's all tightly fastened etc. then turn the tap on the plumbing back on - turn it on to a hot wash, press start ...and in our case it all worked a dream again.
All this info is in the manual if you've got one, but I thought I'd write it out in case you've got this problem and don't have the manual.
Ahhhhh... cleeean washing again! Hope this works for you. Happy go laundry!
Mar 04, 2010 | Bosch Washing Machines
AEG Lavamat 74810 - Spin only programme?
need make and model .
but most machine's do have spin only programme. so turn your machine to this position look for the spin programme after sythetic this is normally slower .and turn on.Iif you can't find spin please let us have make and model .
Feb 11, 2010 | Washing Machines
Washing time & quality
Look for wash cycles in your users'manual. It is best the read the manual well before operation.
Apr 05, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
