Question about Maax Home
Pump starts spontaneously without pushing the switch button
The pump seemed to work fine. About 2 min after stopping the pump it started again on its own. I shut off the breaker and turned it on again and it seemed fine for another 5-10 min. then it started again.
  • Maax Master
  • 717 Answers
This sounds as if a relay has gone out on the circuit board. There really could be no other reason for the pump to come on without pushing the button.
You will need the model number of the control box so you can find a replacement.
Rod
US Parts Center
Posted on Feb 07, 2013
smokenic
  • 49 Answers
SOURCE: My Jacuzzi jetted tub has stopped working.
other than your switch , it could only be the moter or connection to it. always make sure you have enough water in the tub before turning it on or you'll ruin it.
Posted on Sep 19, 2009
SOURCE: I hooked up a Jacuzzi bathtub and pump won't stay on
I bought a new house and I have a jacuzzi bathtube . and all the sudden stopped working .. where or how I can locate the pumpe ? the only thing I see is the button to turn it on or off and now it does'nt go on ?!! I checked the circute praker and everything seems okay to me.... help please.
Posted on May 26, 2010
aquaman987
  • 927 Answers
SOURCE: I have a kohler bath jet tub. When I push the
Did you try an electric motor rebuilder? $500 seems too high to repair a motor. Motors have either a capacitor or dual windings to get them started and it sounds like yours has failed. Get the numbers off the MOTOR and call a motor rebuilder in your area for pricing.
Gary
Posted on Jan 25, 2011
  • 96 Answers
SOURCE: I have a Royal Whirlpool
You have a bad neumatic switch. Or a small hole in the air line. Try pushing the button fast and hard to see if it will stay on. if so , it is a hole in the tube. if not it is your neumatic switch
Posted on Mar 24, 2011
Testimonial: "perfect! Thanks for your help"
  • 23 Answers
SOURCE: My MAAX jacuzzi runs on its own. After it is shut
Power switch appears to have a short in it. See the dealer you purchased the tub from and have them install the part.
Posted on Apr 04, 2011
Can you advise me how to increase the temp in my hot tub? Jazzi SKT338H. It seems to be working properly but I don't have the manual anymore
Either turn heat control dial up, or there should be a 2-button, one UP & another DOWN. Push UP button.
If a single Heat button, the push the button once, it will start to blink, then push again - if temp goes up, you are going in the right direction to get to your desired temp. If going down, then stop & wait till blinking stops - then push the heat button again, it will blink again, press again and now it should go in opposite direction.
Apr 19, 2015 | Pool & Spa
Mercedes c180 problems
HI, could be the fuel pump. you don't mention the milage but if its high this is a possibility, good luck.
Mar 30, 2014 | 2005 Mercedes-Benz C-Class
I have a Bosh Logic dishwasher SGS65L12GB/04 The other day it got to 1 min left and would not stop pumping out water and continued even with the door open. After 5 mins playing around it started working...
Hi Jonathan,
Welcome to FixYa.
Your float may have got stuck or it's possible that you have water leaking into the bottom of the washer. In the bottom of the wash compartment, next to the drain you will find a plastic dome/mushroom (the float). You might need to rotate the bottom spray arm to see it.
Turn the washer on so that the pump starts to run, open the door and push down on the float. This should stop the pump running. When you let go of the float, if it rises back up on its own, then it's almost certain that you have water in the bottom of the washer. If this is the case please post back for further assistance. If the float stays down, then it may have simply got stuck.
Please try this simple test and post back with the results.
Regards,
BElectric
Nov 11, 2010 | Bosch Dishwashers
Pressure Washer Pump and Engine Stops Suddenly
The pump might be binding against the motor, causing the pump to overheat and temporarilly "seize up" and shut the engine off.
After cooling down for a brief period (5~10 mins) the engine can usually be re-started, but the overheating problem will keep coming back.
This happens when the pump either wasn't seated against the engine properly during it's initial instalation, or the pump housing wasn't machined properly and the PTO shaft is trying to drive the pump at a slight angle = excessive friction = overheating.
Try this:
1) Loosen the bolts that mount the pump to the engine just enough so that the pump can be wiggled slightly.
2) With the engine power switch in the "OFF" position, slowly pull the recoil starter rope so that the engine / pump completes about two revolutions. This helps to align the pump surface with the engine.
3) Lightly snug the pump mounting bolts in a criss-cross pattern, then slowly pull the recoil starter rope again to ensure that the pump isn't binding.
4) Finish tightening the pump mounting bolts in the criss-cross pattern (approx. 21 foot pounds torque).
The entire process should take you roughly about 10 mins from start to finish.
If this doesn't remedy your problem, then try running the engine for 20 mins with the pump COMPLETELY removed so as to isolate the components.
May 04, 2009 | Northstar Pressure Washer 3000 PSI
Mar 08, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
BOSCH washing Machine WFE 2021
perhaps it is waiting for user to add fabric softener? how it got in this mode?
May 28, 2007 | Bosch WFE 2021 Front Load All-in-One...
Home Logo
135 people viewed this question
Top Maax Home Experts
Mike
Tim Whalen
Tim Hunt
Tim Hunt
Are you a Maax Home Expert? Answer questions, earn points and help others
