Question about iHome iD9 Portable App-friendly Rechargeable Speaker System for iPad/iPhone/iPod
How do i open up my ihome id9 to replace the battery
How to open up the unit
You have to remove 5 screws located under de black rubber cushion on the bottom of the ihome id9, you may need to glue back the rubber. Peel it off carefully to avoid tearing it apart .
Posted on Apr 08, 2013
Bush B1 10.1" tablet, the screen not working?
there is a reboot process for this unit. go to YOU TUBE, and type in the unit. there is a vid that will explain how to do the reboot. make sure the battery is recharged!.lol.
Aug 24, 2017 | Tablets & eReaders
My tablet says insufficient storage but I have nothing downloaded what do I do
didnt specify type of unit --generic --open settings and look for what is stored in unit ---also if unit has email ,phone ,photo,notes capability they take up storage as well as internet open pages
Jul 17, 2016 | Tablets & eReaders
Wont turn on even holding power button for 20 seconds
You could have a bad battery, a bad charger, or more probably, a bad charging connector. Try leaving the unit on 'charge' overnight, then remove the charger and try to start the unit. Check the charger with a voltmeter and see if it is putting out the required voltage. You could try taking the unit, if it is not under warranty, to a battery place like Batteries Plus and they may be able to open it and check the battery. If it is under warranty, contact Amazon Customer Service.
Jun 17, 2015 | Amazon Kindle Fire HD
How to open up the JBL onbeat rumble?
The power connection on my JBL Onbeat Rumble stopped working also. I could usually jiggle it to get it going but this wasn't a reliable solution. I note there were a few people online that have complained about this but no solutions or disassembly guides. With nothing to lose I set about pulling the unit apart to fix it... here's hoping it will help others:
1. Under the orange base rubber there are five screws. You need to carefully peel off the rubber to get to the screws. Also under the sticker on the input/output section there are two screws to undo.
2. See photo for positioning of rear clips. You might be able to use an appropriate tool to undo them. I used brute force to open the case and the rear clips didn't break.
3. There are two more clips and two screws at the front of the unit.
I don't know how to get to the screws - possibly you need to unclip the front of the unit and grille. I just used additional brute force which undid the clips and snapped the screw mounts. The unit was then completely opened up into two halves.
4. You can now get to the input/output section. There are four screws to undo before you can lift it out. In my case I could see a cracked solder joint on the power input so I re-soldered it as best I could and confirmed the unit was now being powered up reliably.
5. To reassemble, reseat the input/output board, clip the unit back together, re-insert the 5 base screws + 2 input/output screws, then glue the rubber back on (it might be sticky enough not to need additional glue). The snapped screw mounts don't seem to matter as the remaining clips are strong. Just shake out any plastic pieces to avoid rattles.
Jun 13, 2015 | JBL OnBeat Rumble Wireless Speaker Dock...
Lost launcher on tablet. Dont know how to install one. My tablet wont open.
should have a tiny hole on back of unit press a paper clip or something like that in the hole, and it will reset the unit
Oct 14, 2014 | Tablets & eReaders
How do I get my Proscan 7" Google Play Tablet to open where i can use it
Somewhere on your unit there should be a pinhole. On my ten inch it is just to the right of the charger outlet. Open a paper clip and gently press it into that pinhole. That is there to reset the unit in case it hangs. Don't press too hard or you may damage the contact. You should see it shut down and reset. You may lose any data or apps you have.
Oct 02, 2014 | Proscan 7-Inch Android Internet Tablet,...
iHome iD9 Portable App-friendly Rechargeable Speaker System for iPad/iPhone/iPod Logo
830 people viewed this question
Top iHome Tablets & eReaders Experts
Brett Duxbury
Brett Duxbury
john cordey
john cordey
Are you an iHome Tablet and eReader Expert? Answer questions, earn points and help others
