Question about HP Pavilion a1720n PC Desktop
New case fan running but still getting error message system fan failed.
Was getting ERROR:System fan failed...F2 to continue because my PC had no case fan. Installed new case fan and it does work. BIOS reading system fan 425 rpm. Connected to mobo with 3 pin. Still getting error message when booting.
  • HP Master
  • 5,660 Answers
Did you try;
Power off, power unplugged to computer.
Press the Power On button, and hold it in. Hold for a count of 10 seconds.
Let go.
Do this procedure two more times.
Plug the computer back into power. WAIT 1 minute, turn the computer on.
This method clears CMOS Error Codes, and sets BIOS Setup back to the factory default settings.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864946&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3340228#N436
CPU fan spinning at required minimum RPM's?
Not talking about the SYS_FAN (Case fan)
Regards,
joecoolvette
Posted on Jan 18, 2013
  • 7 more comments
  • SJCadoo Jan 20, 2013
    CPU fan running just fine.
    Not very familiar with tech stuff. Nervous about reseting BIOS. I might just get someone to do that for me. Will keep posted on solution.
  • joecoolvette
    joecoolvette Jan 20, 2013
    I understand. But you're not resetting BIOS, just the BIOS Setup parameters. There is no way it wil harm your computer. However let's go with the person who will help you. Do appreciate hearing back on this. Regards, joecoolvette
  • joecoolvette
    Pggh! Multi-tasking and it isn't working very well, lol! The main thing is you are clearing CMOS Error Codes.
  • SJCadoo Jan 21, 2013
    Thanks for the advice joecool, I'll give it a try. (my buddy will)
  • SJCadoo Jan 24, 2013
    Had the Bios updated. All is good.
  • joecoolvette
    joecoolvette Jan 24, 2013
    Excellent! Glad to hear it! So you updated the BIOS, or did what I posted?
  • SJCadoo Jan 26, 2013
    Update.
  • joecoolvette
    joecoolvette Jan 26, 2013
    Thanks!
  • 60 Answers
SOURCE: when booting get msg: system fan has failed...
That is correct. Also, while you are inside the Pc check the connection to make sure it is tight. If the inside case is dusty, blow it out with a can of compressed air from wal mart. Most modern motherboards have sensors built in and software that monitors temperatures of your hard drive(s), CPU's, Inside case, and even video cards. It's nice to know that the software notified you as it was suppose too. Oh by the way, nice system! Hope this helped.
Posted on Jan 05, 2009
  • 189 Answers
SOURCE: Desktop PC system fan failed error
hello.. this means that the fan which cools your pc is not working, get a new fan for your mode and fit yourself if possible or go to computer technician.
do not keep it using as your pc may crash.
its very important to keep the cpu cool to keep computer working. hope this help.
Must rate me.....
Thanks
Posted on Mar 25, 2009
SOURCE: 920-fan command 2 pin connector not connected
It is a 2 lead wire (red/white and black) that connect right next to the memory slot. you have to connect the red/white wire to the 5v+ side of the 4 pin peripheral and the black lead to the com (black) on the same 4 pin peripheral. i can't really think of any way better to explain at the moment. but any questions. email @ forwardyourletter@gmail.com
Posted on Apr 28, 2009
DickCanFixIt
  • 948 Answers
SOURCE: Hp business pc/912: error while booting/ reset case disabled
Go into the BIOS and disable the error message. You will need to look around in the BIOS to find the exact location of the enable/disable setting for case intrusion.
Posted on May 22, 2009
  • 74 Answers
SOURCE: system fan has failed
When the system fan or cpu fan fails you will get this message, or sometimes the computer will actually start, but then shut itself down. The only way to fix this problem is to replace the failed or failing fan. If you don't know how to replace a fan inside a computer, then I highly reccomend that you hire someone to replace it, or get a friend who knows what they are doing, to replace it.
Posted on Jun 18, 2009
Help -- CPU Fan Failure bypass or pinout?
Yep I have a link below you can order the correct fan from.
http://store.cwc-group.com/y4574.html
I had the same issue here, we have 20 offices all running Dells. These fans seem to be used only on dell systems.
Feb 23, 2012 | Dell Dimension E310 PC Desktop
My dell gx 270 desktop shows alert! previous fan failer. Press F1 to continue and F2 to run setup utlity. How to solve it?
The fan failure alert on your Dell, is caused by the timings. There is no bios settings, for this. You need a new fan that runs at 1400rpm or more. This will solve the problem, also a clean install solves this problem. Best to buy a new quite fan, keep the 5pin header from the old fan copy the wire colour for the pins, make sure the fan is pwm. In the worst case, you will have to change fan, and overwrite harddrive and do a clean os install. This will fix problem, other methods, like fan speed software will redduce the fan speed cook your motherboard, but will not solve the fan failure alert. Also enter bios by pressing f2 and clear log error before you install new fan and os.
l
Aug 18, 2011 | Dell OptiPlex GX270 PC Desktop
When the computer boots up. It makes almost a grinding noise and I get an error msg, saying the fan is failing. But it does boot up by hitting f2 which is one of the options after the error msg. The other...
The only resolution other than replacing the fan by sending the PC to repair, is to clean the fan.
Power Off the desktop
Open the side pannel using the thumb screw or the philips screwdriver
You will see two fans in the unit, one on the processor heat sink (CPU Fan) and other on the back (System Fan)
Try to clean the fan by blowing air using a hair dryer or a vacum cleaner (in light mode)
Put back the side pannel
Power on the PC to check for error message
If it's still there, you need to replace the fan if it wont allow you to pass through using F2
Regards,
Shrey
Jun 01, 2011 | HP Compaq Presario SR1830NX PC Desktop
I have an HP M7100Y Media computer runnign XP and replaced the cooling fan but when I boot I get an error message System Fan Failure press F2 to continue. How do I avoid the error message?
Does the fan spin up? There is a third wire on the fan that is interogated by the uProcessor to determin how fast it is spinning. If it is spinning but not registering, there is an interface problem, maybe poor connecion on the socket it plugs into?
Hope this helps.
Dec 31, 2010 | HP Pavilion m7100y (PX189AV) PC Desktop
Have a Dell XPS 600 problem. I am getting a message when I turn on the computer, "Keyboard Failure Alert! System battery voltage is low. Strike the F1 key to continue, F2 to run setup utility." What should...
If you have another keyboard try swapping it out and see if it reads the new one. Also a stuck key could possibly cause this error. System battery message probably means you need a new battery for the motherboard. If you replace the battery get the new one before removing the old one. If you leave it out too long you can clear the CMOS
Oct 14, 2010 | Dell XPS 600 PC Desktop
Latitude delld610 Boots with the following
press F2 to get into the dell bios and be sure the HDD is listed as first to boot, Then if restart turns the same error, press F10 and run the pre-boot system assesment check. if error 0141 appears, your HDD is failing and needs to be replaced
Aug 24, 2009 | Dell Computers & Internet
At boot up, my Averatec 3150HS displays the error message "north bridge fan error, press F2 to continue" I can't find the fan.
Hello there:
boot into bios and look at the advanced section and see if the bridge fan is located there and if it is just enable it than press the f 10 key to save and than reboot the system
Aug 15, 2009 | Averatec 3150H Notebook
System fan has failed
Your system's fan has failed. If it is under warranty, you need to have HP made aware of this failure.
Jun 18, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
When powering up my computer, I get a failure. Primary hard drive 1 not found Strike the F1 to continue F2 to run the set up utility. I think the power supply fan is not working. What do I do?
your system can not detect your primary hard disk which host the operating systems,so you check the data cable to the hard drive and the power supply to the hard drive for supply
Jul 19, 2008 | Computers & Internet
HP Pavilion a1720n PC Desktop Logo
237 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
