Question about Texas Instruments TI-83 Plus Calculator
How do you use cosin-1 - Texas Instruments TI-83 Plus Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
To take the inverse cosine, press 2ND [cos^-1], enter the number or expression, then press ENTER. For example, to take the inverse cosine of .25, press 2ND [cos^-1] . 2 5 ENTER.
Make sure you have the proper angular mode set.
Posted on Jan 18, 2013
Sin, cos,tan don't work. For example, I click 1, 2nd and cos and I'm getting 1 instead of 0.54. In all other buttons the 2nd function is working but not for sin, cos, tan. Thanks for any help!
I wonder if your calculator is set to the wrong units. Your calculator can be set to degrees, radians, or gradians. I assume that you want it set to degrees.
When I click 1 2nd and cos, I will always get 0, because using the 2nd before the cos turns the function into cos^-1 (inverse cosine). The inverse cosine of 1 is 0 because the cosine of 0 is 1.
Good luck.
Let me know if you have any further questions.
Paul
https://education.ti.com/en/us/guidebook/details/en/ADF11FB65B284B6195B0A7E9502784BA/baiiplus
Dec 20, 2015 | Texas Instruments BA II PLUS Financial...
When ever i press sin^-1, and type in a number, the answer is always "domain error" on my ti 30x iis, how can I fix this problem?
Not quite true. (Explanation at the end)
The sine and cosine of an angle have values in the closed interval [-1,1]. That means whatever the value of the angle, its sine or its cosine cannot be less than -1 or greater than 1.
When you consider the inverse problem where you want to find the angle whose sine or cosine is known, you must take the values of the sine or cosine in the interval [-1,1]. That is the domain of the functions arc sine and arc cosine. So if you take a value outside the domain [-1,1], and want to calculate the angle to which it belongs, the calculator signals that there a domain error, because there is no angle that answers the question. Limit the arguments of the sin^-1 and cos^-1 to values in [-1,1]
For the inverses of arc tangent and arc cotangent functions there is no domain limitation because the range of tangent and cotangent is the whole real line ]-infinity, +infinity[.
Mar 30, 2014 | Office Equipment & Supplies
My TI-30XB WONT CALCULATE INVERSE COS OR INVERSE SIN
Does it refuse to do so or does it give an error message?
Three common errors:
  1. Not having the correct angle unit. Wrong result, No error message
  2. Confusing reciprocal of sine (1/sin(x) with arc sine (x) ,sin^-1(x). Confusing the reciprocal of cosine, 1/cos(x) with arc cosine (cos^-1(x)). Wrong result, No error message
  3. Taking the argument of the inverse sine and/or inverse cosine functions outside the interval [-1,1]. This gives a domain error.
Oct 28, 2013 | Texas Instruments TI-81 Calculator
Inverse sine function
The sine and cosine function have a range between [-1, 1]. The domain of their inverse functions is [-1,1]. So 20/1 which is 20 is out of the domain of definition of the functions. No limitations for tangent and cotangent.
Oct 22, 2013 | Casio FX-115ES Scientific Calculator
How do I input secant^2
Secant is the reciprocal of cosine
sec(x)=1/cos(x)
Do not confuse it with the inverse of the cosine function, which is arccos(x) =cos^-1(x)
Sep 24, 2013 | Texas Instruments TI-84 Plus Calculator
Inverse cos of 52 degrees
The cosine of 52 degrees is about .6157 . The inverse cosine of .6157 is 52 degrees.
52 degrees is a measure of an angle. .6157 is a distance. The cosine of an angle results in a distance, while the inverse cosine of a distance results in an angle. There is no such thing as the inverse cosine of an angle, just as there is no such thing as the cosine of a distance. It's like asking "How heavy is one hour?"
If you're asking how to calculate a cosine or inverse cosine on your calculator, please specify the make and model of the calculator.
Jan 08, 2013 | Office Equipment & Supplies
Cos -1
Is there a question? Why so secretive, spill it out.
To access the arc cosine (cos^-1) press 2nd COS and enter the argument. Make sure you are within range, because the domain of arc cosine is from -1 to +1. Any value outside of this closed interval will warrant a DOMAIN ERROR.
May 29, 2011 | Texas Instruments TI-83 Plus Calculator
I'm trying to do inverse sine and cosine equations but I'm receiving a message that there is a domain error. Is there anything I can do or press like a reset button?
The inverse sine and cosine equations mean "angle who's sine/cosine is:" The bounds of the arguments for these functions must be between 1 and -1, the maximum and minimum values of the sine and cosine functions, because no angle can have a sine or cosine that is greater than 1 or smaller than -1. Also it should be noted that the inverse sine/cosine function is not the same as 1/sine or 1/cosine, although the symbol makes it look like that.
Mar 08, 2011 | Texas Instruments TI-84 Plus Calculator
How to find cosine
Put in the value and press the COS key. For example, to find the cosine of 1, press 1 COS =
Bear in mind that the value of the cosine will depend on the angular mode.
Oct 19, 2010 | Texas Instruments TI-30XA Calculator
My ti30x will not do cos-1 when i type it in i get domain error
The cosine function takes its value on the whole real line, the angle domain spans ]-infinity, + infinity[. The range of the function is however limited to the [-1, +1] interval.
Thus if you want to calculate the arc (angle) from the value of the cosine, the cosine must be in the interval [-1, +1]. Any value outside this domain will give you a domain error.
Check that the values you feed to the arc cosine function are in the interval [-1,+1].
If the angle unit is the degree the value returned bay [cos^-1] is in degrees, and if the angle unit is the radian, the value returned is in radians
Mar 04, 2010 | Texas Instruments TI-89 Calculator
Texas Instruments TI-83 Plus Calculator Logo
65 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
