Problem with Bosch V694 flap to filter won't open
I can't remove the metal flap that covers the filter so that I can empty the filter. It runs along the full bottom of the machine.
  • 3 Answers
SOURCE: if filter cap is broken how do i open it on my bosch washing mach
I had the same problem. If it's stuck you may want a tool. I ended up using a pair of pliers on this plug. You may want to use a pair of vice-grip locking pliers and put a piece of thick metal on each side so you don't break the plug any worse (about 1/2" X 2" plate). MAKE SURE YOU TURN COUNTER CLOCKWISE! Wiggle it back and forth as you may have a wire or hairpin half in and half out of the pump filter area. It takes 2 full turns to get past the threads in order for the plug to come out. I had an underwire from a bra that gave me the worst problem. I worked on it for almost an hour. I have found change, jewelry, hairpins, BBs, small rocks, and a 4" long underwire from a bra. Please rate my solution if this gives you enough details to complete your task. THANKS!!
Posted on Apr 16, 2009
SOURCE: Bosch Exxcel Tumble Dryer lost manual, keeps
yes the bottom filter can be removed and washed out with warm water, this is the same problem we had
Posted on Jan 02, 2010
barkencoa
  • 3463 Answers
SOURCE: my Bosch Exxcel 1100 will not drain, after manualy
Could be the impellor is slipping under load, or there is a blockage between the pump outlet and the point it drains into the waste pipe.
Try blowing down drain hose to see if it is blocked.
Posted on Feb 22, 2010
Whispis2
  • 192 Answers
SOURCE: Cannot get out and clean
Manual is here...
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=rhdu2Hjcdcso0pdmdb---hNm&UMOBID=rhdu2Jhcdcso0pdmdb---hNm
Go to page 26 for instructions.
Posted on Mar 20, 2011
Macmarkus
  • 2605 Answers
SOURCE: I need to know how to unlock the door
Hello, welcome to FixYa.
I understand you are having trouble removing the filter access cover on your Bosch Nexxt washer, correct ?
I've posted my solution to error code E13 which should in turn explain to you how this covered should be removed...the first 3 steps should explain/illustrate how this is done, you can omit the rest if you like or review for cleaning procedure.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs, and a pair of mechanics gloves are recommended due to EXTREMELY sharp edges...safety first**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water that is typically the reason for a locked door, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine as you know (about 6" in diameter, lower right corner)
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free...it will not rotate unless the release tab is pushed in. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a green ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.macmarkus_28.jpg
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Oct 24, 2011
Bosch washer will not spin
Check the pump filter. This is located at the bottom front right of washer. Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean. Be prepared for a lot of water and junk. If you find a closed hose pipe when you remove the drop down flap it is to drain excess water.
The pump itself is directly behind the filter housing, check if there is nothing stuck in the housing, especially after you are cleaning out your filter after a long time. Clean out and refit carefully
Pl click if helped.
Mar 25, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Hi, i have a bosch classixx5 washing machine(1400) , it's going through it's cycles until it tries to drain & then nothing, it won't drain... Please could you offer suggestions & s
You first of all need to check the pump filter. This is located at the bottom front right of washer. Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean. Of course be prepared for a lot of water and junk. The pump itself is directly behind the filter housing, check there to see if anything is stuck in the plastic blades. It should turn freely. Your washer door will not open if there is water in the washer, just some kind of precaution, so don't force the door.
Pl click if helped..
Mar 17, 2013 | Bosch Washing Machines
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Can you tell me what e13 means on my bosch nexxt 500
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked. E13 means timed out on drain cycle, In other words its trying to drain and cant so it stops with that error code, Hope this helps,
Sep 19, 2011 | Audiovox Bosch 718 World Cellular Phone
My bosch maxx stops mid cycle and the spiral icon that represents spin starts flashing. Its seems that it can not drain or spin yet the drum rotates when washing. Now i have washing stuck and i can not...
This is almost certainly a simple problem with your empty pump filter being clogged. Without knowing the model I can't be certain, but I would suggest that the empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model, there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
In the event that this doesn't work and you just want to get your washing out, you will find that turning the machine off at the wall for 20 minutes will reset it and allow you to open the door (With the power still off). IF THERE IS WATER ABOVE THE LEVEL OF THE BOTTOM OF THE DOOR, then pull the machine out and (With some help, because it's heavy!) Tip the machine backwards at about a 45 degree angle, so that the water line falls below the door before you open it.
If the above doesn
Aug 12, 2011 | Bosch Washing Machines
My bosch classixx 1400 express washing machine stops at spin cycle..
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Jul 19, 2011 | Bosch Classixx WVF 240S Front Load Washer...
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
Bosch classixx 1200 express smells
If you have not already done so, then check and clean the filter.
This is usually located at the bottom front right of washer behind a drop down flap or cover.
Unscrew anti-clockwise to remove and clean.
Please rate my solution.
Thankyou.
Jan 28, 2010 | Bosch Washing Machines
Machine is a WFP3300 Hydrosensor, no spin and we cannot open the door
Remove the flap on the bottom which covers the drain pump & you will see a red tag which is the standby door release.Pull it down & you will hear the door unlock. Drain off the water through the small black hose then unscrew the pump cover & remove the cause of the pump jam (hair clip etc)
Sep 05, 2009 | Bosch Washing Machines
Washing Machines Logo
Top Washing Machines Experts
