Question about Alpine MRP-M1000 Car Audio Amplifier
No light on Alpine MRP-M1000
I was driving the other day, decided to crank up a portion of a song that had some bass and a few seconds of thumping later the sub-woofer cut out all together. When I had a chance to go into my trunk a little later noticed that the blue light on the sub amp (M1000) doesn't even turn on anymore. Checked the 4 fuses on it and they look fine. Also checked the power connection and everyting is tight. (other amp on same power supply is working fine) Any thoughts? This is a fairly new amp I just got a few months ago (brand new). Would love any help...
    Scholar:
  • 124 Answers
Ok. Have you check the Ground and the Power connection.
Posted on Jan 28, 2009
Will this amp push 2 2000 watt subs?
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
Turns on but no bass
MAKE SURE FUSES ARE GOOD AND YOUR RCA JACKS ARE GOOD AND CONNECTED,CHECK GAIN LEVEL BRING IT UP HALFWAY AND COSSOVER IS DOWN
Nov 12, 2010 | Alpine MRP-M1000 Car Audio Amplifier
There is a smell in my car every time I play my system for long periods of time. Its a burning smell. Everything is wired correctly and I have a separate battery in the back of my car to power my subs. I...
The problem could either be the amp over-heating or the subs could be over-heating as well. One of my friends owns an Alpine MRD-M1005, and one day they decided to clean it inside and out and realized they had some burnt spots on the circuit board, although they never smelt anything burning, and the amp still works fine.... As for the lights dimming you should probably buy a power Capacitor, atleast a 1 Farad or larger.
Hope this helps.
Nov 08, 2010 | Alpine MRP-M1000 Car Audio Amplifier
I haw alpine mrp-m350 amplifier how many sub can i
Hook up the MRP-M350 to one 4-ohm sub, and you get 200 watts RMS; connect a second 4-ohm subwoofer and the power output increases to 350 watts! All that juice means that your subs won't just be loud, they'll sound clean and thumping.
Apr 08, 2010 | Alpine MRP-M350 Car Audio Amplifier
Hi ive got a alpine mrp-m1000 it lights up no sound was woking fine in the car didnt use car for 3 months then i wouldnt work all wires are fine and so is the sub please help
If your not getting any sound make sure the sub input is in the right spot on you radio. if not check the speaker wires on your harness
Feb 14, 2010 | Alpine MRP-M1000 Car Audio Amplifier
How do i hook up the mrp-m1000 to 2 type r subs since it is a one channel amp? the subs r 4 ohms so it should work right?
hook the positive to positive and negative to negative on both subs then run wire to the amp the amp will see a 2ohm load
Jan 07, 2010 | Alpine MRP-M1000 Car Audio Amplifier
Bass will only output when car stereo is cranked
AMPS NEED AIR TO BREATH, AS THEY GET VERY HOT WHEN IN USE, DOES THIS AMP HAVE A COOLING FAN? IF SO CHECK TO SEE IF IT IS WORKING
Jun 19, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Amplifier wont move subs
I dont know if this will help you but start at the deck and make sure that the outputs(RCA) arent crossed over to highpass and do the same at the amp make sure that its set for lowpass- set half gain -bass boost half gain- subsonic minimum - If that doesnt help try using an i pod with an adaptor that you can play it right into the amp this is to see if you are getting signal from the deck to the amp if it doesnt work with an i pod or mp3 plugged directly into it then you may have got you a blown amp going on- good luck with that
May 29, 2009 | Alpine MRP-M1000 Car Audio Amplifier
When i turn up the volume in my car and the bass comes on the amp shuts off
You need a bigger amp or smaller speakers.
The speakers are pulling more power than the amp can supply.
Mar 04, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Alpine MRP-M1000 Car Audio Amplifier Logo
355 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
